The Intel ATOM is a great board but we have one issue. When we simulate a power loss and then re-apply the power the unit does power up and our application loads but the network port is not detected by the...
OK ... try this. The bios is not your problem (I'm pretty sure). The network port is driven by the network set-up in the original OS disk ... somehow the network software is not following thru. To mend this
1. go to the bios and set the first boot be the CD then make the hard drive the second.
2. put the orignal OS disk in , let it boot go to the install of additional software.
3. go thru all the categories and one by one reinstall then, but always go to the details and make sure all the entries are checked off ... when you get to the network, there are several check items. Make sure you check all the network items there. For this is where you lost the original networking abilities.
4. Go thru the rest of them and make sure you check all of the items and details, this is like starting the machine all over again as if nothing was installed. This is the most important step.
5. For example if you do not check off the internet explorer ... when it restores the internet explorer will not be there, alot of people make this mistake.
6. This process will be a little shorter in time than installing new hardware from the beginning.
7. When this is done make sure you have a good internet spyware, Do not use ad-ware or this junk they are trying to sell you on line, it is nothing more than another spyware to infiltrate your machine. Use alarm zone, mcfee, or norton ... again DO NOT USE online suggestions, it is proven that these are not what they seem, all they want is your money. if these keep poping up always chose cance. make sure you read the response because some of these say if you click away you will get these viruses anyway ... take the time and read the pop-up bulletin.
This should help you, been there and done that!
8. After all this go to the start menu, defrag your machine, and use the software error professional pro to keep this from happening again as this software has a restore to the last date in it.
9 Note that some of these wirus programs, when they enter your machine will blow the normal restore away theat comes with the os software in the start/system/restore. So you will need a software other than the system restore to sotre you restore file ... Oh yeh ... don't try to restore to your C drive, try to put in on another drive or usb stick, or some other media.
