2006 Chrysler 300 Logo
Posted on Jul 01, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Vehicle stuck in park will not change gears. Will start fine
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 324 Answers
  • Posted on Jul 01, 2010
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
324
Questions
0
Helped
70890
Points
949
Does the gear shifter move? if the gear shifter moves and it wont shift then you have broken linkage, if it wont move you may have ignition linkage problems or the button may not be pushing in all the way, also the brake pedal is tied in too
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 23, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
908
Points
Remove the outer plastic chrome ring around the shifter. Inside you will see a pink plastic device on the drivers side of the linkage push this in and shift car into desired gear. You may have to do this for a few days and will have to do it everytime you shift out of park. It should reset it self back to normal in about 3 days. Worked for me. Good luck
5 Related Answers
Anonymous
  • Posted on May 04, 2009
SOURCE: 2006 Nissan X Trail Gear Shift Stuck in Park.
This is not a permanent fix, but you'll be able to shift and drive...this is a "safety feature" when you're break lights aren't working...it may be a fuse issue, i found that didn't help either.
How to drive it while it's "broken" On the top left of your gear shift is circle that looks like a button that is only 3/4 there...see picture (it's circled in red)
pry that off with a key or something... now restart your car, push on the break and at the same time insert a key or something into the now open hole...while pushing down use the other key to shift into reverse. You will need to do the same thing to shift back into park.
Good heavens that is the most inneficient safety feature I've ever heard of. How about instead of leaving the car immoble and keeping you in a scetchy neihborhood to get mugged they just "invent" a warning light notification. grr
Anonymous
  • 21 Answers
  • Posted on Jun 09, 2009
SOURCE: Car stuck in Park, wont switch gears
check to see if the brake lights come on it may be a problem with a brake switch under the dash not letting the shift lock release. there may be a seperate switch just for it so check and see it there is two switches touching the brake pedal lever if the brake lights come on.
Anonymous
  • 99 Answers
  • Posted on Aug 20, 2009
SOURCE: 2000 Hyundai Elantra gear shift stuck in Park.
check for the brake switch if this doesnt work wont release from park if this ok then i will check the shifter cable check for power and ground
Anonymous
  • 3 Answers
  • Posted on Dec 02, 2009
SOURCE: in my 2003 ford escort zx2, its stuck in park and
my car got stuck in park several times, i'm the brake lights would come on but i couldnt push the button to make my car move out of park...there's a tab on the right side at the top of the gear shifter console pop it out, stick a skrew driver down in and that should release it if that's your problem...it's a little bit of a rig, but it works, havent been stuck in park since
Anonymous
  • 715 Answers
  • Posted on Dec 17, 2009
SOURCE: Gear Shift Hard to get out of park.
check linkage
Testimonial: "Had to replace solenoid in the gear shift. The plunger on solenoid was sticking, therefore couldn't get vehicle out of park."
Gear shift stuck in park
Most vehicles have a small rectangular hole near the base of shifter for override. Sometime you need to flip up the little cover on it. Insert key into that hole and press shifter button and change gear. If the vehicle is not starting, try starting in neutral. Also, turn steering wheel and make sure brake is pressed while trying to start or change gears.
DISCONNECT BRAKE PEDAL 1991 SUBURBAN
98 Suburban 5.7L, automatic trans is stuck in park - no previous shifting problems, I know that the brake switch also operates the brake/transmission solenoid (BTS). Stepping on the brake pedal prior to starting the vehicle allows shifting from park to another gear. When I switch the key to the "on" position, I don't hear the BTS click. I can start the vehicle and the brake lights work fine. I just can't shift out of Park. I am unemployed and I am trying to troubleshoot this problem and fix it myself. Please help!
2helpful
3answers
Transmission in chevy silverado 1500 5.3L v8 will not shift from 2-3 gear transmission has been rebuilt and 2-3 shift solenoid was changed but still will not shift from 2-3 gear
For gear shift issues and gear stuck issues,the help links are provided below. Click the link below to go through troubleshooting procedure:---- ---- Car will not move when in gear?
http://repairhelpcenter.blogspot.in/2012/02/car-will-not-move-when-in-gear.html ---- transmission sticks in first gear? http://technoanswers.blogspot.com/2012/01/mercedes-benz-transmission-sticks-in.html ----- Transmission not engaging in first gear? http://technoanswers.blogspot.com/2012/01/mercedes-benz-not-engaging-in-first.html ----- Vehicle only goes in First gear?
http://howtobyme.blogspot.com/2011/11/chrysler-pt-cruiser-only-goes-in-first.html
Car is stuck in park and the shift will not move?
http://howtobyme.blogspot.com/2011/08/car-is-stuck-in-park-and-shift-will-not.html
---- Engine will not go out of park mode? http://technoanswers.blogspot.in/2012/02/2002-nissan-sentra-will-not-go-out-of.html ---- Car stuck in park? http://technoanswers.blogspot.in/2012/02/nissan-sentra-stuck-in-park.html ----- Car will not come out of Park?
http://howtobyme.blogspot.com/2011/11/car-will-not-come-out-of-park.html
Automatic transmission will not go into high gear?
http://howtobyme.blogspot.com/2011/11/automatic-transmission-will-not-go-into.html
--- Car wont downshift sometimes?
http://schematicsdiagram.blogspot.com/2011/12/car-wont-downshift-sometimes.html
---- Transmission will shift into drive?
http://schematicsdiagram.blogspot.com/2011/12/buick-park-avenuetransmission-will.html
----- Auto wont shift from park? http://schematicsdiagram.blogspot.com/2011/12/ford-taurus-wont-shift-from-park.html ---- Car Transmission will not go into Park mode?
http://schematicsdiagram.blogspot.com/2011/12/car-transmission-will-no-go-into-park.html
----- Shift indicator directly goes to 2nd when key is turned ON?
http://schematicsdiagram.blogspot.com/2011/12/shift-indicator-directly-goes-to-2nd.html
---- Third gear missing and engine losing power?
http://schematicsdiagram.blogspot.com/2012/01/third-gear-missing-and-engine-losing.html
------- Vehicle has whining sound in gear?
http://technoanswers.blogspot.com/2012/01/chevrolet-silverado-has-whining-sound.html
----- Hard to shift gears on Manual transmission?
http://technoanswers.blogspot.com/2012/01/hard-to-shift-gears-on-manual.html
------ Car hard shift at slow speeds?
http://technoanswers.blogspot.com/2012/01/car-hard-shift-at-slow-speeds.html
--- Automatic transmission shift lever hard to move on cold mornings?
http://technoanswers.blogspot.com/2012/01/automatic-transmission-shift-lever-hard.html
------ Gear shifts hard?
http://schematicsdiagram.blogspot.in/2012/02/2000-nissan-maxima-shifts-hard.html
------- Vehicle noticed sluggish delayed shifts while driving?
http://schematicsdiagram.blogspot.in/2012/03/vehicle-noticed-sluggish-delayed-shifts.html
This will help.
Thanks.
Shift solenoid on 1997 infiniti Q45
This will help.
Thanks.
2004 Trailblazer shifter stuck on Nueutral can't move to park or Drive
This will help.
Thanks.
96 e320 Mercedes benz stuck in park but starts fine.
This will help.
Thanks.
Top Chrysler Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Chrysler Expert? Answer questions, earn points and help others
