I have a videorecorder panasonic omnivison model PV-V4021. I want to record a specific time like from 13.00 to 16.00 hours. I leave home 05.00 clock in the morning.
no model told
is this home VHS play relic day:>
nobody uses VHS now.
I converted all mine to DVD-R 22 years ago
and not those are in trash, video tape movies are ugly.
what's up doc. what are you attepting to do.
watch
record or copy
or?
Unfortunately, you can not do a programmed recording with the PV-7450 without the remote. You can do a one-touch (current channel/time) recording. To do this, use the channel buttons to select the desired channel and make sure that a tape with the record tab is in the VCR. Then press Rec/Time (the right-most button) several times to select the recording length. Press Stop to end the recording.
To do a programmed recording, you need the Prog button on the remote. (You may be able to find a universal remote that matches the function if you try enough of the codes for Panasonic VCRs.) There is no matching button on the VCR front-panel.
The problem with universal remotes is that unless you enter the correct code for that model not all functions will operate. You need to try every Panasonic code in the code book, untill you find one that works the guide function. Otherwise the only real solution is to get the original remote.
Actually George, You should read the supplied Operations manual. In that you will find a chapter for using the Remote as a Universal remote, and a list of codes will be give. Check out the code for Misubishi TVs and feed that.
Daily recording Mon - Fri Same time and channel each day.
