Question about Insignia IS-DVD1001 DVD Recorder/VCR
Progressive scan mode
There is blue screen an dit says progressive scan mode and nothing shows up when i press any other button what can i do???
  • ouissallisa Jun 22, 2008
    same blue screen need help to put it back to regular mode
    President:
  • 1,768 Answers
Tis could be a dirty optical reader or a dirty DVD disk
need to be cleaned
DVD disk could be scratched on the header of the disk and the optical reader is unable to read>>>>>
hope this helps
Posted on May 22, 2008
I was playing with settings on my Zenith xbv342 and set the menu to progressive scan. I now have a blue screen with the words "progressive scan mode" I cannot get a picture and it is stuck in this m
Progressive scan mode is used by DVD players to artificially scale standard resolution DVDs to HD resolution, usually 720i. Is your set capable of receiving HD resolution? If not, that is probably why you are getting the blue screen.
Dec 18, 2014 | Zenith XBV342 DVD Player/VCR
Zenith XVB422 DVD VCR comb
Hi skielty58...I just saw your post, so I haven't done any research yet. However, IF should you see this post prior to my, or any other contributors forthcoming updates which should contain a certain resolution, I would like you to try something during the interim. Play a dvd, and although showing the blue screen, allow to play for about a minute. Now, using your remote, press and release STOP, and within 1 second, Press And Hold Stop for 10 to 15 seconds. This trick is reliant upon the timing sequence, so, you may want to try it more than once. Another trick that I'd like to suggest is that again, after allowing a dvd to play for a minute, simultaneously press select and stop on the player...Please update your post whether positive or negative so other potential contributors have the benefit of ongoing history...good luck my friend
Jul 31, 2007 | Zenith XBR413 DVD Recorder
I cant watch any dvds, it says its in progressive scan mode and the screen is blue. i can hear the movie but not see it
hi,
ur dvd is in progressive scan mode. u have to get out of that setting ,because ur TV dosen't supports the progressive scan. do the following to get out of the progressive scan mode.
1. power ON the dvd.
2. press stop button to stop any disc that is playing.
3. press stop again and hold it for five seconds.
the video out will be restored to the standard settings.
ok
Jan 13, 2011 | Zenith XBS444 System
DVD/VCR Combo - Zenith XBV342 Stuck In Progressive Scan
mi zenith xbv342 solo queda la pantalla azul y dice progressive scan mode como salgo de hay
Jun 14, 2009 | Zenith XBV442 DVD Player/VCR
Cannot turn off progressive scan mode on blue screen to play dvd
If you have not already seen this or done it - it worked for us:
On page 18 of the user manual under Progressive scan there is a Caution which says - If you set Progressive Scan to On in error, you must reset the unit. 1) Remove any disc from the unit and close the disc tray. See that "dISC " is displayed on the display window. 2) Press STOP (9) and hold it for more than five seconds before releasing it. The video output will be restored to the standard setting and a picture once again be visible on a conventional analog TV or monitor.
May 20, 2009 | Zenith XBV442 DVD Player/VCR
How to stop Progressive Scan Mode?
Yes, I found the users manual.
To fix it: Press and hold the STOP button (on the remote) for more than 5 seconds.
It worked!
Feb 05, 2008 | GoVideo Go Video DVD/VCR Combo
DVD player
unplug it and plug it back in and press the progressive button to turn it off, should work. Yeah that blue screen sucks, i would have thought you can get to the menu no matter what but that's sanyo for you, well most other brands also...
Jul 21, 2007 | Sanyo DVW-5000 DVD Player/VCR
Insignia dvd/vcr combo progressive scan mode
turn on dvd, make sure the disk is out, press and hold the stop button for 5 seconds and it should go back to the picture
Jul 04, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
Stuck in progressive scan mode
You need to be sure to remove the discs from the disc changer and close the disc changer. Make sure that your TV is on the Blue Screen and it should say " Progressive Scan Mode" Press and hold the stop button on the unit....not the remote for 5 seconds or more and it should reset. However, if your TV is a Progressive Scan compatible TV, you may need to refer to the user guide for the TV as well....Many newer TVs Use a Progressive Scan Setup, but this solution should still work for you. Make sure all discs are removed FIRST!!!
Aug 29, 2006 | NexxTech ESDVD100 System
PROGRESSIVE SCAN STILL ON- BLUE SCREEN ONLY
Cause: DVD+VCR was turned off while setting the Progressive scan mode. Correction: Keep pressing the STOP button for more than 5 seconds.
Oct 17, 2005 | Zenith XBV443 DVD Player/VCR
Insignia IS-DVD1001 DVD Recorder/VCR Logo
53 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Dave Naylor
Dave Naylor
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
