Question about Refrigerators
Water leaking below the freezer unit - Refrigerators
  • 9 more comments
  • Anonymous Jun 07, 2008
    Haier refrigerator leaks LOTS of water from the freezer, apparently. Started as soon as I brought it home.
    The unit is useless as is, soaks everything.
    Help,
    Mike
  • Anonymous Aug 03, 2008
    occasional water dripping from freezer
  • peternagy Aug 03, 2008
    Every 3-4 days water leaks from the inside bottom of the freezer side through the door onto floor. Seems to be coming from the bottom of the unit that sits at the back ?
  • Anonymous Aug 14, 2008
    Water collects and freezes in the bottom of the freezer, then leaks out at the door, collects in front and under freezer. Have tried turning freezer off to completely dry out.
  • lalit3100 Aug 23, 2008
    I have exactly the same problem but do not know how to fix it. Can some one suggest it. please send me email.
  • MrsMac2411 Oct 07, 2008
    I have an Amana bottom freezer unit and the water collects in the bottom of the freezer until it's a solid block of ice and then it leaks out onto the floor. I emptied the entire refrigerator and freezer. Turned it off and let everything melt and then dried it all. I don't see any type of drain in the bottom which would explain why any moisture getting in is freezing but I don't know where the water is coming from. My refrigerator is 7 years old.
  • zberta Oct 25, 2008
    I have ice collecting on the bottom of the freezer than it spills to the floor.
  • Anonymous Nov 11, 2008
    Just as everyone posted above my freezer has ice built up on the bottom and is leaking water on the floor every day.
    I have no clue how to fix this.
  • dhs19791 Nov 12, 2008
    I have the same problem. Water leeks from freezer, top back inside of rerigerator, onto shelves, within 4 or 5 days the bottom is over flowing onto the floor. HELP!!
  • sid_669 Nov 15, 2008
    water leaks out of left front corner/ freezer side. have no idea where it comes from. water to fridge is completely shut off.
  • SDC8857 Apr 03, 2009
    REPLACED FREEZER COMPUTER BOARD AND STOPPED FREEZER FROM OVER FREEZING ONE YEAR LATER WATER ELAKING FROM THE FRONT UNDERNEATH ONLY ON OCCASSION
I have a GE side-by-side refrigerator/freezer and have had the same problem with water pooling at the bottom of the freezer and running onto the floor. The solution is easy. There is a drain tube just behind the pull out drawer at the toward the bottom of the freezer. When that tube get's plugged, it does not allow for water to drain out into the drain pan. To solve the problem, first remove any ice build up from the bottom of the freezer and from around the drain tube opening. Then pull the freezer away from the wall and remove the cover from the bottom of the appliance. You will see a drain tube on the bottom right side. This is the tube that is plugged. Simply use a turkey baster to squirt warm water down the tube from the inside of the freezer (or anything that will allow you to squirt water into the drain tube) until water flows from the tube into the drain pan. It usually takes me 3-5 times to clear the line and once it is cleared, I run a little additional water through the line to make sure it's cleaned out well. The repair is simple and only take about 15-20 minutes.
Posted on Aug 16, 2008
  • 21 Answers
Water is designed to flow into a collection pan. The drain is plugged with some sort of build up. Mine was ice. I took the shelves out of the freezer and unscrewed the middle screw out to back panels. Behind this is the frost/moisture remover. It has a drain at the bottom and if it is plugged with ice it just needs to be melted. I used a hair dryer. Either way a hair dryer will be needed to find out why the drain is plugged. Once the drain is free the problem of water on the floor will go away.
Posted on Nov 13, 2008
    Problem Solver:
We had the same problem with our 12 year old GE side by side with water leaking into and from the bottom of the freezer. My husband used a wire fish to unclog the drain then flushed it with a little hot water from a turkey baster. Problem solved in less than 5 minutes.
Posted on Apr 19, 2010
How do i solve it
Posted on Mar 03, 2009
  • 4 Answers
Normally depending on the model there might be a condens catch tray, if it's full and for some reason condens didn't dry out it will leak underneath.
Posted on Apr 17, 2008
Plugged drain line
Posted on Oct 16, 2009
5 Suggested Answers
  • 1073 Answers
SOURCE: frigidaire frs26zthb3
icemaker is iver filling and running down through the freezer, some of the water runs out into the floor since the door gasket does not provide an water proof seal just an air tight seal
the ice maker can be adjusted, remove the cover off the frount of the icemaker and back the screw on the right side so that the indicator in the middle is twards the minus sign and you need to clear the frozen water out of the freezer drain pan so it can go to the drain pan down at the compressor
it might take a few adjustments on the ice maker to get it right
Posted on Apr 30, 2008
  • 192 Answers
SOURCE: Water leaking from freezer
During the defrost cycle heaters inside the walls of the freezer turn on to melt the frost. The melted frost "water" is supposed to drain into a pan under the fridge where it will evaporate. I think the drain line from the freezer to this pan may be blocked. I'd also check the seal on the freezer door. If it's not sealing well it lets a lot of moisture into the freezer which means more water during the defrost cycle.
Posted on May 18, 2009
Sea Breeze
  • 4655 Answers
SOURCE: water leaks out on floor on freezer side and ices
You possibly have a defrost drain problem or your ice maker is leaking. I will help you through this if you like. Let me know, Thanks, Sea Breeze
Posted on Jun 16, 2009
aaronbeth
  • 110 Answers
SOURCE: There is water leaking below
It's probably thawing out because the freezer is not cooling enough. Check for dirty condenser or faulty condenser fan motor.
Posted on Jan 26, 2011
Older ge refrig, freezer at top leaking water into refrigator compartment below. otherwise its working fine.
Its the defrost problem. The drain hole is clogged and water is leaking in fridge section instead of draining through drain hole.Defrost the unit and check, for defrosting procedure , click the link below and follow the procedure:--- http://technoanswers.blogspot.com/2011/07/ge-refrig-freezer-at-top-leaking-water.html --------- This should help.Thanks.Helpmech.
Jul 08, 2011 | Refrigerators
I have water collecting on the bottome of my side by side refrigerator on the frigerator sided un the crisper.
Hello and Welcome to FixYa!
Actually the leaking water is from the evaporator coil unit....(it is located at the back wall or underneath the freezer compartment). Under normal conditions,Self-defrost refrigerators usually dispose the water generated during the defrost cycle through a tube or channel that directs the water a pan (Known as Drip pan), commonly below the refrigerator unit....
The channel or tube is clogged and the water is leaking to the refrigerator/freezer unit, so you need to clear that blockage/contamination....Once the blockage is removed, the generated water will move through that channel/tube directly to the drip pan and there will no water on the floor in the refrigerator/freezer compartment. This is all you need to do....
Best of Luck,
Your token of appreciation in form of rating would be highly obliged,
Concerned.
Sep 17, 2010 | Frigidaire FRS6R5EMB Side by Side...
JDC2389GES side by side fridge Water is leaking inside the freezer and pooling at the bottom.
Best of Luck,
Concerned.
Aug 25, 2010 | Jenn-Air Refrigerators
I have a whirlpool imperial refrigerator; freezer on top; with icemaker....water is leaking from the freezer section down onto top shelf in refrigerator, near back, any help??
Actually the leaking water is from the evaporator coil unit.... Under normal conditions,Self-defrost refrigerators usually dispose the water generated during the defrost cycle through a tube or channel that directs the water a pan (Known as Drip pan), commonly below the refrigerator unit....
The channel or tube is clogged and the water is leaking to the refrigerator unit, so you need to clear that contamination....Once the blockage is removed, the generated water will move through that channel/tube directly to the drip pan and there will no water on the top shelf in the refrigerator compartment. This is all you need to do....
Best of Luck,
Please do Rate the solution, if you feel that this helps you,
Concerned.
Aug 10, 2010 | Whirlpool Refrigerators
MTB2656G Top Freezer Refrigerator: Water is leaking and pooling below crispers in ref...
Clean the drain pan and drain line in the back of the freezer section underneath the evaporator coil. Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - make sure to put the tube exactly where it was.
Good luck! :)
Vlad
First Choice Appliance
May 06, 2010 | Maytag MTB2656G Top Freezer Refrigerator
Water leaking below the freezer(In the chiller compartment)
if this is a bottom freezer and you have an icemaker, possibly the icemaker is allowing to much water in the tray, shut off the supply water to the unit and see if the problem persists
Oct 30, 2009 | Refrigerators
There is water dripping (might be from the freezer above) along the back of the refrigerator and pooling at the bottom. There is no water attached to the unit. Wendy
There are many reasons for this happening for example water leaking from a water supply line for the dispenser or ice maker, a crack in the defrost pan, water leaking inside and draining through the refrigerator cabinet, but most are cased by a defrost drain line blockage. Below is a link that may be helpful so try to take it all in and use the parts that most refer to your specific problem, Thanks Sea Breeze
click on link below
HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
If you have more questions or need help feel free to let me know, Thanks, Sea Breeze
appliancepartsse@yahoo.com
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com
Aug 30, 2009 | Whirlpool Refrigerators
Inside leak
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Aug 18, 2009 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
3,554 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
