How to reset the mouse? My mouse isn't responding, sometimes flashing green, then red, then no red when I try again and then it stays lit on green. THe whole time the USB port is lit red, never blinking. What does this mean?
  • Swilin Sampson
    Swilin Sampson May 11, 2010
    what is the make and model of your mouse?
    President:
  • 2,712 Answers
What is the make and model of your mouse?
Posted on May 07, 2008
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    This thread has gone 14 days or more without a response.
    Please close the thread with a “FixYa” or “Helpful” rating.
    Or post back with latest developments, what steps you took,
    etc. and I will assist you further as best I can.
    Thank you.
    IrishDruid
Green power light comes on goes off then on again stays solid, moniter says no signal, mouse lights up, and three red lights on key board flash then nothing why?
If the monitor power light is on or flashing, but nothing displays, borrow a monitor from a friend. If that works, your monitor needs replaced.
Nov 21, 2012 | eMachines EL1852G-52W
Green light blinking very fadley pc will not turn on
Sounds like you might have a partial power supply failure. Try unplugging the power supply from everything. Ther should be a switch on the back that is red and says something like 115/220 just flip that switch over to 220 and wait 5 minutes then switch it back to 115 and replug everything in and then try it. If it doesn't work then unplug everything again and let it sit for about 30 minutes (this resets the power supply) and reconnect the wires and if that doesn't work try getting a new power supply. In partial PCB (Power Supply Board) failures the problem is that trere isn't enough power going to the system to start up so sometimes resetting the PCB will fix it temporary. You should get a new one anyway. that one will fail completely soon. Good luck!
Mar 15, 2012 | Dell Computers & Internet
I have a speedstream 4100 , it has 5 lights one for activity and the others are allways when its working right. sometimes the first 2 will be green and the dsl light will flash red then green & go normal...
You will need to contact your DSL provider to come out and physicly check the lines. I had the same issue, and it turned out to be a faulty line.
Also you should be able to reset your device by logging into it on the LAN connection by putting a spacific IP address into your address bar of your browser, common IP's for modem's / DSL routers would be:
192.168.1.0
192.168.1.1
192.168.0.0
192.168.0.1
192.168.1.254
192.168.0.254
Again, you may need to have your lines checked by yuor DSL provider to rule out improper line installation, or improper line filters
May 05, 2009 | Computers & Internet
Flashing red light
Check your connection at the back, if the mouse is in the mouse port and Keyboard in the keyboard port, these look the same at the back but they are color coded. green is for the mouse and the violet is for the keyboard.
Also check if you have the Cable which run from the monitor plug in the correct one. sometimes there are two port, one is built in the other is a card.
Finaly if the problem persist, there must be a loose connection inside. if you are computer savy and can open the pc check the memory and if there's a video card try to clean them both.
Mar 22, 2009 | E-Machines eMachines Desktop PC
My wireless optical mouse is no longer working
You replaced the batteries. Okay. Did you install drivers for the mouse from a CD? Are you using Windows XP? Do you notice any change if you use the mouse on a darker surface as opposed to lighter surface? If the computer installed the drivers for you, then you might want to delete them in Device Manager (might be called something like HID-Compliant Mice. Single click on that entry, press the delete key. You might have to reboot your PC after that. From there you might have to unplug, then plug in the mouse again and you should notice the driver reinstalling. Give it a second and all should be good.
*Access the Device Manager by right-clicking on My Computer, select Properties, go to the Hardware tab and select Device Manager.
Mar 20, 2009 | Computers & Internet
I have 2 comtrend dh-10pf powerline adapters. one of the adapters status is a red flashing light and the AP light and the Ethernet light are blank. the second powerline adapter has a solid red status...
To start you need to factory reset both adapters,
plug them both into a wall socket next to each other, press the config/f reset button, hold in until ap light goes off, repeat on the other one.
Now you should have a red status light on both.
Press the config/f reset button on one for about 5 seconds, wait until ap light stays on, this one is now your access point (ap) that should be plugged in to your router when you have finished config.
Now press the ap adapter config button again for about 5 seconds until ap light flashes, then press the config button on the other adapter until ap light flashes, wait until they both stop flashing, wait a few seconds, the status light on both adapters should be green, and one adapter should have an amber ap light.
Hope this helps.
Jan 28, 2009 | Computers & Internet
Mouse/keyboard
Normal 0 Make sure the batteries are good.
Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
Hope this helps. Bud
Oct 19, 2008 | Insignia D300a PC Desktop
MY mouse has a red light that continously flashes. I charge it at night and all day the red lit flashes. Time for a new mouse or what?????
You need to tell us more then "MY mouse"... but I'll try to help.
First: there must be button to power off/on your mouse, switch to off and then on. If red light continues to flash clean connections on mouse and on dock (where you charge mouse), try to charge it, if red light continues to flash check if you can replace battery if not it's time for new mouse.
May 31, 2008 | Computers & Internet
Computers & Internet Logo
Brian Sullivan
Brian Sullivan
David Payne
David Payne
