Question about Casio Exilim EX-S880 Digital Camera
Overexposure for pix mode.video seems okcamera 2 yrs old casio EX-S880
  • lch198
    lch198 Jun 14, 2012
    This WON'T work!! i have the same problem with my 2 Casio S880 cameras. Nothing seems to correct the problem whatever you do with the settings. The CASIO people should come out with a solution, maybe a version update. My version is 1.1 which is the latest!!
    Good luck!!
    Brigadier General:
  • 11,967 Answers
Check your "exposure compensation" setting. It should be at "0". You can set it lower if your pics are still overexposed and see if you can find a setting you like.
Posted on Jul 01, 2010
SOURCE:
How do i take black and white photos with the EX S880
In the recording mode, press MENU. On the "Quality" tab, select "Color Filter" and press cursor-right. Use cursor-up/down to select "B/W" and press SET.
It's in the "Using the Camera's Color Filter Effects" section of the manual (page 139 in my copy). If you need a manual, you can download one at
http://support.casio.com/pdf/001/EXS880_e.pdf
Nov 14, 2010 | Casio Exilim EX-S880 Digital Camera
Have Casio Exilim EX-Z750, 4 yrs. old. Every time
read the manual again. and reset to automatic update
Apr 07, 2010 | Casio Exilim EX-Z750 Digital Camera
Casio EX-Z600 overexposured pics on some zoomlevels
might be the same problem with my Exilin S500...the shutter is the problem. I saw in the net in some shop fixing it for $60...it might be worth for you. here is a link http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Aug 16, 2009 | Casio Exilim EX-S600 Digital Camera
The red light that indicates its charging keeps flashing
How old is the battery? Keep in mind they aren't meant to last for more than a year or two, regardless of how often they're used. Generic replacements are actually inexpensive these days. Here's some from Amazon:
http://www.amazon.com/s/ref=nb_ss_e?url=search-alias%3Delectronics&field-keywords=s880+np-20+battery&x=12&y=22
Jun 06, 2009 | Casio Exilim EX-S880 Digital Camera
Battery Problem Casio EX-S880 Digital Camera
Ive had this happen twice. The first time I went back to the store and talked to the tech people to see if it was a problem with the camera itself but ended up buying a new battery. About a week ago, I finally found my charger to plug in the camera that I hadnt used in weeks to find the same problem once again. It must stem from long periods of non use. After finding this question I continued my research and the Casio website tells you to call 1-800-435-7732. Dont know if that helps much but I will be calling them in a little while. Good luck.
Mar 08, 2009 | Casio Exilim EX-S880 Digital Camera
Camera comes on, the screen (or lens) does not.
the camera need to be serviced the lens repaired or replaced. do a google search for mike's digital camera repair. for low cost repair.
Feb 26, 2009 | Casio Exilim EX-S880 Digital Camera
Casio Exilim EX-Z75 Showing colorfull blotches on...
Try doing this.....
Turn the camera on and in picture taking mode press menu. Go to the 3rd tab (setup) and then go down to reset. Press right and make sure ok is highlighted and press the select button. Then try taking some more pictures and see if that helps. If not then that would be something that would have to be sent in for repairs.
Aug 28, 2008 | Casio Exilim EX-Z750 Digital Camera
Casio Exilim EX-Z60 - severe overexposure - entire image is white
Yes the place sold you a camera with a bad CCD. They should replace it for free.
May 30, 2008 | Casio Exilim EX-S600 Digital Camera
Overexposed photos in otherwise normal settings in casio ex-s500
It is the shutter (or at least it was for me) I found a simple test here: http://www.mydc.com.tw/repair/knowledge_en/casio-exilim-ex-s600-overexposure-t17.html
I repaired it myself, but it took me a whole afternoon and lots of patience.
The hard part is taking the camera apart, once I got to the shutter I just activated it manually so to dislodge any pieces that might have gotten jammed, then placed it back together again and it worked! :).
It's really hard to take apart, it's like a puzzle sometimes, to find which screws are keeping it together. I also had a bit of hard time when it came to put the zoom back together again.
But I guess it beats throwing the camera away.
I'm still puzzled on how the CCD works so that an overexposure would make horizontal overexposed lines, but everything points to that. Fixed shutter, lines be gone.
Apr 29, 2008 | Casio Exilim EX-S600 Digital Camera
Casio Exilim EX-S880 Digital Camera Logo
232 people viewed this question
Top Casio Cameras Experts
atollminsk
Level 1 Expert
Parshiv Luthra
Steven Wander
Steven Wander
Are you a Casio Camera Expert? Answer questions, earn points and help others
