Computers & Internet Logo
Posted on Jul 01, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Will high density ram work on an ASUS A8N-SLI Motherboard?
Lee Hodgson
Level 3:
  • ASUS Master 4,810 Answers
  • Posted on Jul 01, 2010
Lee Hodgson
ASUS Master
Level 3:
Answers
4810
Questions
Helped
1781681
Points
15941
Possibly not.
Your best bet is to check the website of your proposed RAM vendor and see what their configurator lists for this board, then you will know if the RAM you want works with the board.
Regards.
I don't know how to plug in the wires for the ASUS a8n sli deluxe motherboard
Here is the manual for your motherboard (since describing a diagram probably isn't very useful...)
http://dlcdnet.asus.com/pub/ASUS/mb/socket939/A8N-SLI/e2024_a8n-sli.pdf
You want to look at pages 27-35, they describe what you need to plug into the motherboard. Basically make sure you have connected:
1) 24-pin power cable (from power supply)
2) 4-pin power cable (for CPU from power supply)
3) Any case fans with 3/4 pin connectors.
3) hard drives (SATA or IDE)
4) USB front panel ports
5) Audio front panel ports
6) Case plugs (power LED, hdd LED, power switch, and reset switch).
1helpful
A8N Sli motherboards graphic card and CPU capatibilies
Hi!
Nop, it takes only AMD
The infosite about that MB is still up, you will find it here:
http://uk.asus.com/search.aspx?searchitem=1&searchkey=A8N-SLI
There you will find all the info you want. BTW, its not only the MB's size if the nvidia card fits or not, its the size of the case to.
Good luck
Nic
Type of ram
ASUS A8N-SLI Premium Specifications
CPU: Socket 939 for AMD Athlon 64FX / Athlon 64 /Sempron / Athlon 64 X2
Chipset: NVIDIA nForce4 SLI
Front Side Bus: 2000/1600 MT/s
Memory: 4 x DIMM, max. 4GB, DDR 400/333/266, ECC, non-ECC, un-buffered memory, Dual Channel Architecture.
Expansion Slots:
2 x PCI-E x16
- SLI mode: x8, x8
- Default (single VGA): x16, x1
1 * PCI-E x 1/ 1*PCI-E x 4(x2 mode)
3 x PCI
Storage/RAID: nForce4: 4 x SATA 3Gb/s
NVRAID: RAID0, RAID1, RAID0+1 and JOBD span cross SATA and PATA
2 x UltraDMA 133/100
Silicon Image 3114R RAID controller
4x SATA with RAID0, 1, 10, 5
Audio: Realtek ALC850, 8-ch High-Definition Audio CODEC
LAN: nForce4 built-in Gbit MAC with external Marvell PHY MARVELL PCI Gbit LAN controller
or see this site:
http://www.ngohq.com/home.php?page=articles&go=read&arc_id=34
ASUS A8N-SLI memory issues
imondeau, do you still have you're manual for the ASUS A8N-SLI Premium? Please turn to page 2-12 & 2-13.
Need the manual? Click the link below & download it.
http://support.asus.com/download/download.aspx?modelname=A8N-SLI%20Premium&SLanguage=en-us
The QVL; Qualified Venders List, shows all the tested memory for this board. Edge memory is not supported. This is why the Edge memory only runs by it's self. Once you add the corsair memory they clash because they are not compatible working together in this Asus board. Both sets of memory could work in another board. (Maybe)! What is also needed is if the corsair & edge DIMMs are SS = Single sided or DS = Double sided. How many chips on the corsair? How many chips on the Edge?
They must have the same total chips each each DIMM.
Edge does not sell memory compatible for the
Asus A8N-SLI Premium.
See this for you're self. Click on this link:
http://www.edgetechcorp.com/memory/
Mike
Ram problems
Your memory should be in slots A-1 & B-1
You Asus board uses the Award bios. The link posted below will tell you what your beeps are saying.
http://www.bioscentral.com/beepcodes/awardbeep.htm
In your case do as I suggested above. I have two working
A8N-SLI Deluxe boards & the memory works fine in A-1 & B-1 slots.
Good luck & best wishes!
please vote.............................
Asus A8n-sli premium with amd 64 3700+ proc
Usally blue screen errors are from ram. Do you have the right ram for that board?. Is the ram set to the right speed in bios?.
1helpful
Ddr and ddr2
You cannot use DDR2 since your mother will only support DDR1 which is DDR400 compatible only.
Please don't rate me Inappropriate if you don't like my solution or rate me SOLVED if you accept the reality. Thanks
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
