John Deere Lawn Tractor Seat F710 F725 F735 Slidetrack () Logo
Posted on Jul 01, 2010
When I engage the pto clutch, it does not activate. What would cause that? This is for a F725 John Deere Front Mower
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 23, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1457
Points
If your talking about the mower blades, it can be a weak battery.
My John Deere f725 starts up but the blade won't engage
Check fuses, see attached pic. If fuses are intact then further troubleshooting is required. Check the PTO switch connector is properly attached and not burnt or melted (common failure in older machines).Same for the electric clutch connector.
You can make an audible test of the PTO clutch with key ON engine OFF. Turn ignition switch to run position but do not start the engine, then move the PTO switch ON. The clutch should make an audible pop sound.
If no sound then use an automotive style test lamp or a DMM to check for power at the clutch.
If power (batt +) and ground (batt-) at the clutch, then disconnect the connector at the clutch and measure resistance of the clutch winding. Typical resistance is 2-4 ohms. If it reads 0 ohms, reverse leads and re-measure. If it reads open (infinity) then likely clutch winding has failed or wire has broken.
John Deere x320 PTO switch not getting power. Mower blades will not engage. Replaced PTO clutch and PTO switch. Have checked seat safety switch and RIO switch as well.
Just out of curiosity check your pigtail that plugs into the pot harness. I have ran into a broken wire inside that pigtail before.
John Deere Z840A Z-Trak mower. Why does engine die when PTO is engaged?
A possible cause is an open seat switch (operator presence). Locate the switch under the seat & unplug the switch from the harness. Place a small jumper wire into the female socket leads to the wire harness. If the PTO engages without engine shutting down, replace the seat switch.
Check to see if the mower deck is plugged or a piece of wood/debris is wedged between the deck and a blade, or some wire/rope is wrapped around a spindle. If the blades don't turn by hand, it'll stall your engine when the electric PTO clutch is energized.
Lastly, a discharged battery will cause an engine shut down if there's not enough reserve when the PTO is engaged. Measure the battery voltage with a meter. If the voltage is below 11.5 volts, you may have to replace the battery.
1helpful
2answers
F525. Updated mower switch by John Deere is not engaging mower
The John Deere F525, a front cutting machine, has 3 fuses.
20 Amp
15 Amp
10 Amp
Check the 15 amp fuse. I believe this supports the PTO clutch. If you replace the fuse and it blows again, check the electric clutch. You will likely find burnt or melted wires. The bearings do go out on these clutches causing them to run hot and eventually burn up.
PTO Clutch will not engage: There is a very fine one page discussion on evaluating electric clutches at this site:
http://www.messicks.com/Articles/FixingElectricClutch.aspx
My JD tech manual, which covers the entire LA 100 series, agrees with the electrical specifications. It states that the Electric PTO Clutch should show the following:
Resistance 3.7 ohms
Current Draw 3.25 amps
It does not give the air gap.
It does include a note to check the PTO Clutch Key for damage or if missing. So there is a drive key between the PTO Clutch and the shaft. Additionally, it recommends checking the tightness of the cap screw. That's the screw or bolt that holds the clutch on the shaft.
Cap Screw torque 55 lb-ft (75 N.m).
If the fuse blows, I recommend you check the resistance of the clutch. If the clutch is shorting to ground it will show zero resistance when you ohms the connector wire to a ground position. In which case, you will have to replace the clutch.
Fixing Electric Clutches
Other possibilities.
On the F525 there is a cut-off switch in the hydraulic system. It is a low pressure cut off. If you were running the mower and deck and then it suddenly stopped, it may be low pressure in the hydraulics. It will not automatically reset as you are using the same volume for the drive pumps. Once the oil gets low enough it cuts out the deck drive 1st, then the drive pumps.
I need a diagram that shows me how to replace the belt on my F725 front deck john deer mower
hi there pauly46 here
type f725 in the search box - under j/d cataloue
here is web site adress to go to that page
http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt?search=model&model=f725
select f725 ,select sectional index , select mower deck and lift linkage,select mower drive belts sheaves and spindles ,
then a window with deck parts and diagram will appear
print this off
it will give a good idea of belt routing for deck
take a look and hope it helps
cheers pauly46
7helpful
Mowerdeck will not engage...
I own a similiar John Deere model (L130, 23HP with a 48" deck). I would check the electric clutch (called a PTO). To do this check the wires to this clutch and look for something disconnected. These wires (to this PTO clutch) should have twelve volts with the key on and the blades engaged.
2helpful
Mower dies when pto is engaged blades move freely
Could be the seat switch. Your operator present switch only comes into play when the clutch is engaged. If the drive clutch is engaged, and the pto is engaged, the operator present switch has to be moade.
Top John Deere Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a John Deere Garden Expert? Answer questions, earn points and help others
