Got it working. Thanks.
You are going to have to log into the router and check the wireless settings to make sure that the SSID Broadcast is enabled. If the SSID Broadcast is disabled, the router does not send out a wireless signal.
For information on logging into the router, you will need to refer to the router's manual. This usually can be accomplished by opening your browser and typing http://192.168.1.1 , or whatever the ip address of your router is. You will then need to provide a username and password. I believe the default on most routers is admin / admin. If you do not have the router manual, provide me with the make and model of your router and I will search for it.
enable ssid broadcast, enable security, and use wpa personal. You will need to choose a passphrase. Make up anything you like, but I suggest using at least 3 of 4 secure criteria.
1. At least one Capital letter
2. lowercase letters
3 one symbal, such as the @ symbol
4. 2 numbers
should be at least 8 characters in length, and you will need this passphrase to connect with your laptop.
choose any channel
it is wired to a modem but is now connected up to the router.
Thankyou. This is what it said:
Wireless 802.11g
SSID
dlink
Channel
6
Encryption
Disabled
So how do i enable it?
This is what it said for wi
These are the wireless settings for the AP(Access Point)Portion.
Wireless Radio:
On Off
SSID :
Channel :
6
7
8
9
10
11
12
13 Auto Select
set_channel();
disable_channel();
Super G Mode :
Disabled
Super G without Turbo
Super G with Dynamic Turbo
change_autoChan();
Extended Range Mode :
Enabled Disabled
WMM Function
(Wireless Qos):
Enabled Disabled
802.11g Only Mode :
Enabled Disabled
SSID Broadcast :
Enabled Disabled
Security :
Disable
WEP
WPA
WPA2
PSK / EAP:
PSK EAP
Authentication :
Open System Shared Key
WEP Encryption :
64Bit
128Bit
Key Type :
HEX
ASCII
Key1 :
Key2 :
Key3 :
Key4 :
Passphrase :
Confirmed Passphrase :
802.1X
RADIUS Server 1
IP
Port
Shared Secret
RADIUS Server 2
(Optional)
IP
Port
Shared Secret
*Enabling Extended Range Mode will not allow to disable SSID Broadcast mode.
*Super G with Dynamic Turbo only operates in Channel 6.
Is your main home computer wireless also, or wired?
