Question about Dell InspironTM 1501 Notebook
Sorry, another problem
Ok now i have another issue that i hope you can help solve. (its different than the screen saver problem.)
i just put a DVD into my drive bcuz i wanted to watch a movie on my Dell laptop, and now i get a window that says "Windows Media Player cannot play the DVD because a compatible DVD decoder is not installed on your computer."
(i have windows media player 10--just FYI)
WHY does it say this?!!??!?!!? ive played DVDs on this computer many times in the past and never had this problem!!! i just watched a movie on this not two weeks ago and it was fine!!!!!!!
OMG what is going ON here!?!?! ( i am very frustrated) all i wanted to do was watch a movie on here. >_<
can you help with this too please? i would be so grateful.
  • 242 Answers
You need the correct codecs to play DVD's. The codec needed can be different for different DVD's. Just install K-lite codec pack. That should work fine.
Posted on Apr 20, 2008
How can i save a picture as my screen saver
Assuming you are using windows XP on this:
Create a new folder in "my pictures " folder
Copy the images you want to use into there
On your desktop, RIGHT click and choose "properties" to open the display settings
Click "Screen saver" and choose my pictures slideshow
Click "settings" to open the options for this
Click browse to point to where you saved the images
Set the duration and timings to suit your tastes
Exit by clicking Ok and the OK to exit the display settings
Apr 11, 2011 | Acer Aspire One PC Notebook
How to trun of screen saver
Hello, to turn off the screen saver just follow these steps.
  • Open Screen Saver Settings by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clicking Appearance and Personalization, clicking Personalization, and then clicking Screen Saver.
  • To turn off all screen savers, under Screen Saver, click (None) in the drop-down list, and then click OK.
    - or -
    To turn on a screen saver, click a screen saver in the drop-down list, and then click OK.
    Hope this helps!
  • Apr 05, 2011 | Samsung N150 (36725723009) Netbook
    The whole screen shifts so that there is now a huge block of black down the screen. Only happens with DVD player is on. fine when just cable.
    May be a problem with the dvd player, try connecting it by a different cable if you have one to rule out a dodgy connection, if the problem is still there try it with a different tv to rule out the television as a problem. If you still have the issue check if there is an alternate connection method than a scart cable (which im assuming you are using) give that a go and hopefully you can solve the issue. If still no joy the DVD player may be broken.
    Mar 06, 2011 | Televison & Video
    Screensaver not working
    In Windows XP, right click on your desktop somewhere, and choose Properties. On the Screen Saver tab, pick another Screen Saver from the drop down, and set the Wait time to 1 minute. Click OK and see if it works. You may have to drill into "Settings" next to the screen saver. Depending on your hardware, the 3D screen saver might be too much for it to handle. Try disabling some things in settings or choosing a different Screen Saver.
    Hope this helps! If so, please give a rating!
    Mar 06, 2010 | Compaq Presario 5000 PC Desktop
    I can not run my toshiba power saver nither can i change my power settings manualy. I cannot find where the tishiba power saver option is iv already checked control pannel.and one mor thing, the infra red...
    the infra red i dont know anything about, sorry. the power settings, most of the time are in control pannel .
    if you haven't already solved your problem, try going thru
    'control pannel', then ' performance & maintenance',
    then 'power options'. anyway, thats where mine are located so maybe you'll get lucky and solve one issue. good luck!
    Feb 09, 2010 | Toshiba Tecra M1 PC Laptops
    If I leave my computer unattended for maybe 15 min. this monitor turns itself off. Is there a way to fix that? Thanks, brumeister
    Screen savers can help protect your monitor from wear by showing a constantly changing display when your computer is not being used. Screen savers can be simple, like the Blank screen saver that turns off your monitor to save energy. To change your screen saver 1. Right-click your desktop, and then click Properties.
    2. In the Display Properties dialog box, click the Screen Saver tab.
    3. Click the Screen saver drop-down box, and then click a screen saver.
    4. Click the Preview button to see how the screen saver will appear on your monitor.
    5. Move your mouse or press a key to return to the Display Properties dialog box. To try a different screen saver, return to step 3. 6. Click the Settings button to change the standard behavior of the screen saver you selected. (Each screen saver has its own settings dialog box.) Then, click OK.
    7. In the Wait box, type the number of minutes the computer should wait to start the screen saver after you last touched the keyboard or mouse.
    8. If you are the only person who uses your computer and you are not concerned about security, clear the On resume, display Welcome screen check box. Otherwise, leave this check box selected. Note: If your computer is joined to an Active Directory, the Fast Users Switching feature will be disabled. This is a common change made to computers used for business, and it happens automatically when a computer joins an Active Directory domain. However, disabling the Fast User Switching feature is not the default setting. Almost all computers in home environments will have Fast User Switching enabled. When Fast User Switching is enabled, you'll see the On resume, display Welcome screen check box. If you're part of a domain, you'll see the On resume, password protect check box.
    9. Click OK.
    Jan 20, 2010 | Element Electronics FLX-3211B 32 in. LCD...
    Don't shoe the wallpaper Cyber home en modelo DVD-300
    when the a dvd is stop or not inserted press the setup button (depending on firmware version) you will see system menu the screen saver should be on the first menu press the enter button to access different menus and sub menus
    as for region i cant help you through traditional methods
    Apr 26, 2009 | Cyberhome CH-DVD 300 DVD Player
    How do i get my lock off
    right click on the desktop, properties, slect screen saver, setting, change the setting, you can put it never, so never will power off.
    Mar 14, 2009 | Acer Computers & Internet
    LCD-42XR7H
    Have you confirmed that the correct inputs to the TV are coming from the appropriate outputs of the DVD? If so, try removing the cables and putting them in a different input on the TV to confirm. If that doesn't solve the problem, try connecting your DVD player to a different TV just to test it out. My guess is that it is a cabling, issue, though, so hopefully it should be easy to fix.
    Aug 21, 2008 | Televison & Video
    Dell InspironTM 1501 Notebook Logo
    111 people viewed this question
    Alun Cox
