Question about Kenmore 95022 / 95024 / 95029 Electric Kitchen Range
Kenmore electric range 95022
I try to start the self cleaning cycle, but I'm getting display:
E1-F5
The cycle dont start.
  • marek alarmi Apr 17, 2008
    The kenmore and it's Sears service plan it's a just a joke!
    I think the codes are for the customers and we should be able to get the quick answer from the manual.
    If it required a service- that's fine, but if it's just a simple procedure, why spend a $100.00 for a 5 minute service man show-up?
    Marek
    Genius:
  • 1,073 Answers
There is a problem with the door lock switch assembley a bad switch or the lock motor or the oven light switch
Posted on Apr 17, 2008
Self cleaning cycle doesnt work. I keep getting an E1 F5 error. How do I get the self cleaning cycle o work?
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!$WR
Sep 24, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
I did the self clean on my oven, and now the oven door will not unlock (E1-F5-) pops up onto the oven screen.
Hi
Error E1 F5 means that the control has detected a problem with door latch switch. Switch off the power and unplug it from the mains. Check after 5-6 minutes whether the error has disappeared. If the error is still there then once again start the self clean cycle. Press the self-clean button to start the cycle. The panel becomes blank (---), then press the up arrow (^). The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning. After self cleaning is done wait for 15-20 minutes and open the door. Try moving the latch manually to unlock it. hope this helps...
Daniel
Aug 28, 2010 | Kenmore 92002 / 92004 Kitchen Range
Kenmore 95024 Electric Range The self clean cycle Door stuck shu
Jun 27, 2010 | Kenmore 95022 / 95024 / 95029 Electric...
Trying to self clean my kenmore electric oven get error msg e1 f5
Oct 22, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
My display is showing E1 F5 and the self cleaning cycle won't start. HELP? this is on the 75004 model
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!@#$R
Jun 10, 2009 | Kenmore 75002 / 75004 Gas Kitchen Range
I tried to set my self-cleaning on my Electric Kenmore range model # 66592012100 and I get the error message E1 F5 I can't set my oven to self-clean just my luck
May 13, 2009 | Kenmore 91112 / 91114 / 91117 Electric...
E1 and F5 are on digital read out instead of 500degrees and cleaning
The E1 and F5 is a code that the door latching system is creating a fault. YOu might be able to take apart the door latch mechanism, and recondition it.
Apr 26, 2009 | Kitchen Ranges
I have a Kenmore self cleaning electric range # 95014. When I try to start the cleaning feature it seems as if it is going to start then it beeps and E1 F5 comes on. What do I need to do.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.DGF$^%&*
Feb 25, 2009 | Kenmore 95822 / 95824 / 95829 Electric...
Problem codes for self-cleaning ranges
My experience (Kenmore Ultra-bake Model 665-72002102) was that E1 F5 meant an error with the oven lock switch. In our case, the latch was partly stuck from food or other debris. Just moving the latch back and forth loosened the scale that was making it stick, and it worked again.
Dec 05, 2007 | Kitchen Ranges
Kenmore 95022 / 95024 / 95029 Electric Kitchen Range Logo
113 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
