I have a 'Sharper Image Jumbo Universal Remote' and I have lost the code book. I need to program the remote for a Phillips Television
If you call their customer service or go into a local store, assuming there is still one near you they should be able to supply you with a copy of the manual. You might also want to try their website.
Former employee...
Posted on Apr 17, 2008
Sharper image jumbo remote to work with dish network
I can help you with your Sharper Image Jumbo remote control.
There are two Sharper Image Jumbo Remote Controls: a Sharper Image Jumbo Touch Remote Manual, and a Sharper Image Jumbo Remote Manual. Click the above links to download these remote manuals. The included code lists will give you the correct codes you require.
The Jumbo Touch also has a learn function, while the standard jumbo does not.
I hope that helps.
Apr 04, 2010 | One For All URC-9910 LCD Remote Control
Need instructions and codes to program Sharper Image Jumbo Remote
I can help you with your Sharper Image remote control.
There are two Sharper Image Remote Controls: a Sharper Image Jumbo Touch Remote Manual, and a Sharper Image Jumbo Remote Manual. Click the above links to download these remote manuals.
I hope that helps.
Mar 22, 2010 | Sharper Image TI150 Iron
The sharper image jumbo universal remote jvc tv
I found that this website should have all the codes and instructions for most remotes
http://www.xdiv.com/remotes/
Jan 04, 2010 | Televison & Video
I have a sony tv and lost manual for my sharper image jumbo remote can you help me with what to do
I have the manual and codes in a pdf. If you would like a copy just email me at 585@snet.net and I will send it to you. All I ask is that you leave great feedback on this site.
Regards
AL
Jun 13, 2009 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Programming
i need codes to jumbo sharper image universal remote
Jan 27, 2009 | One For All URC-9910 LCD Remote Control
INSTRUCTIONS NEEDED FOR THE SHARPER IMAGE - JUMBO UNIVERSAL REMOTE
Hello kls1996... programming your remote is rather easy. The easiest way (thanks to The Sharper Image Jumbo Remote being a LEARNING SMART remote) is to do the following:
1 - Point the head of your Sharper Image remote at the head of your Sanyo TV remote (nose to nose so the clear bulbs on each remote are facing each other).
2 - Press the "TV" button on your Sharper Image remote (located in the upper left-hand corner).
3 - Hold the "LEARN" button on your Sharper Image remote (located in the left edge under the volume buttons) until the red light flashes.
4 - Press the key on your Sharper Image remote (e.g. Volume Up or +VOL)... the red light will go solid (indicating that it is waiting for a signal from the other (in your case Sanyo) remote.
5 - Press the key on your other remote (in your case the Sanyo remote) that you want programmed in your new Sharper Image remote... the red light will flash rapidly again.
6 - Repeat step #4 until you have programmed each key.
7 - When done... press the "LEARN" key on your Sharper Image remote. Your Sharper Image remote should be programmed to operate your device (in this case, your Sanyo TV).
NOTE: You can program other devices such as your VCR, DVD, VHS, SAT, CABLE, etc. and not just one device.
Dec 27, 2008 | Televison & Video
I Am trying to program the sharper image jumbo sized universal tv remote.I can;t get the Samsung dvd/vcr combo to except any code listed in the instruction manual
The Jumbo Touch remote does have a learn function which may be helpful in controlling your Samsung DVD/VCR combo.
I hope that helps.
Sep 12, 2008 | Sharper Image Professional Plus Ionic...
..check it out....
http://www.blurtit.com/q717681.html
Feb 17, 2008 | Televison & Video
The "auto" mode isn't quite presented correctly in the documentation or posts I've seen...after MUCH trial and error (and about 3 hous) I've been able to set-up ANY infrared device, either by "auto" or learn. (Although maybe not "fully".)
AUTO Method
1. Press & Hold (about 3 sec.) the [DEVICE] button on the JUMBO Remote....llight will stay solid.
2. Now just press the [POWER] button (only) ONCE while pointing at the device...it will start sending codes approximately every second. (Don't keep pressing the power button as instructions indicate.)
3. TIMING IS EVERYTHING HERE. (It may take 5 minutes to find your devices code.)
4. AS SOON AS the power goes off...press the [ENTER] button on the JUNBO Remote.
5. Now pressing the [POWER] button should power up/down the device.
---- any buttons not programmed will have to be handled using the LEARN method ---
LEARN Method
1. Press & Hold (about 3 sec.) the [DEVICE] button on the JUMBO Remote....it'll stay solid.
2. Press the [LEARN] button on the JUMBO Remote. (light will immediately blink rapidly.)
3. Now Press the {NEEDED} button to program. (light will stay solid)
4. Now (1 to 2 inches away) have the ORIGINAL Remote pointed at the JUMBO Remote and press the {DESIRED} button on the ORIGINAL Remote.
5. It blinks rapidly while sending...then a slower steady blink once "LEARNED" correctly.
*** Not all buttons work properly with the "LEARN method". Some you will need to "associate" with an alternate button on the JUMBO Remote. ***
I sincerely hopes this helps anyone & everyone.
Feb 09, 2008 | Televison & Video
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
Electro Med Services...
