Question about Ovens
GE Profile Oven Error Code F5
I have a GE Profile oven and it started flashing "oven locked". The manual indicates it's an "F5" error, but it doesn't tell me what to do to clear it. Any suggestions before I have to call a repair man to come out?
  • James811 Sep 19, 2008
    I have a Jenn-Air double microwave and oven model WMG3020 and keep getting a F5 code warning when trying to turn on oven. There are no trouble-shooting solutions in the manual. Any suggestions?
rickzilla
  • 706 Answers
SOURCE: GE Profile double Built-In Oven error Code
According to the GE User manual... any F# error code means you have a function error and they suggest you press the CLEAR/OFF pad and allow the oven to cool for one hour. Then put the oven back into operation. If the function code repeats, disconnect all power from th eoven for at least 30 seconds and then reconnect it.. If it still comes back.. call for service.. however it has been my observation that F0 is usually a shorted off key on the keypad. Hope this helps..
Posted on Sep 22, 2008
SOURCE: Our GE Profile JTP18 keeps flashing "door lock" since we ran a self clean
It was a "reset" switch in behind the control panel that went off when the self clean cycle increased the temperature in the area behind the control panel got too hot. After flipping the breaker, and then flipping it back on the oven finally unlocked. I pulled the control panel off and pushed the reset switch. Everything fired back up great. I just won't use the Self-Clean ever again.
Posted on Oct 23, 2007
aborcass
  • 2651 Answers
SOURCE: F3 Error Code - GE Electric Oven JTP18
all ge codes f3 are saying ot replace thermal sensor, you can check the harness connecting them for a pinched or burnt wire i guess, as far as getting a part number , you can enter complete modle number her e and look for the sensor, i checked just the partial number you gave and a few different ones showed up
http://www.searspartsdirect.com/partsdirect/index.action
Posted on Apr 23, 2008
  • 3 Answers
SOURCE: ge profile oven loc
hey - I figured it out! hold down the 9 and 0 at the same time for 3 seconds! or it might be another combination depending on your oven - it is probably the 2 keys that the messge is under
Yay!
Island2
Posted on Oct 03, 2008
  • 111 Answers
SOURCE: F7 Code on my GE Profile Oven
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Posted on Jun 18, 2009
Ge oven jkp27 code f5
Hello Donald,
The F5 error code means that the control board has detecteda error within it self and theirfore the control(also called clock or EOC) needs to be replaced. The F5 error code can be cleared by pushing the cancel/off button and if it returns a short time later their is defiently a malfunction inside of the clock and it would need to be replaced.
GENE
Sep 28, 2011 | GE JKP27 Electric Double Oven
I have a F5-E0 error and it locked the oven door, i turned the over range off and on to unlock the door and kept the range off all night, when i put it back on this morning the oven started to heat up on...
Hi
Error code F5-E0 indicates that there is an issue with the door latch switch assembly; if the switch tests open then the door lock assembly should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 04, 2011 | Whirlpool RBS275PD Electric Single Oven
Aeg b5741-14 oven has code f5 -what does this mean?
Here is a list of oven error codes for your model Kenmore oven.
  1. F0 indicates a Stuck key pad.
  2. F1 and F7 may mean relay is turned on.
  3. F2 indicates that the oven is over temperature in one of the following modes within either cooking or cleaning mode of operation. The control is sensing over 615 degrees with the door lock circuit in the unlock mode. Control senses oven temperature above 915 degrees with the door in the locked mode.
  4. F3 and F4 indicates an open or shorted oven sensor or sensor circuit.
  5. F5 indicates a loss of relay drive circuit.
  6. FF indicates a loss of door motor safety switch.
  7. FC indicates a door lock circuit problem.
If the display of your control is flashing "F" followed by a number or letter its a range malfunction. Press the clear/off pad. Let the range cool for 1 hour and place the range back into operation.
If the problem repeats, call for service.
Jul 16, 2011 | AEG B5741-4 Electric Single Oven
I was cleaning my self cleaning whirlpool accubake oven and a F1 and E7 code appeared. I have just bought my house and the prior owner did not leave any manuals. Help please
Most Whirlpool appliance manuals are available from Whirlpool: http://www.whirlpool.com/owners-center/owners-center-homepage.content.html . You will need the model number from the oven. This should be located behind the oven storage drawer on the rim. It will usually be on the left for a range and on the right for a wall oven. On rare models the plaque with the model number will be behind the door. If you add a comment with the model number, I'll try to post a direct link to the manual.
Are you sure about the error code? F1 and E7 aren't in my code books. I have an F7 and E1 code that indicates a short between the door switch or latch switch and the chassis or ground. (For double ovens, there are two of the switches for each door. The code doesn't specify which oven has a bad switch.) The F5 E7 error is a door latch that will not unlock. An F3 E7 error indicates that the warming drawer sensor has shorted out.
For the F3 E7 error, simply replace the sensor. For the other two errors, the solution depends on the door lock state. You start by unplugging the oven and checking all the wires and their connectors. See http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Whirlpool%20Range%20/%20Stove%20/%20Oven%20Fault%20Codes for the complete set of steps. If the wires/connectors are okay, you probably need to replace one of the door switches if the oven door was locked when the error occurred. If it wasn't locked, then you can check the voltage to the various switches and replace any that are bad. If it isn't a switch, then it is the control that has failed and must be replaced.
I hope this helps.
Jul 02, 2011 | Ovens
My GE Profile oven is beeping every minute. I've
if its an f-7 error code its due to a stuck error code
Feb 06, 2010 | GE Profile JT955 Electric Double Oven
F7 error code
Hi
On a GE range oven F7 indicates either a function pad button is stuck or the clock on the oven is malfunctioning
On the 99 Range oven F7 indicates a shorted Clear/Off Key due to membrane switch or a shorted control or connector
On the GE XL44 Self Clean Oven F7 is Stuck keypad or control relay malfunction
check out more detail here
http://www.fixya.com/howto/h155060-dreaded_f7_error
hope this helps
Aug 14, 2009 | GE Profile JTP56 Electric Double Oven
F0 error code on ge profile oven
Could be a stuck keypad. Try pressing all pads at random several times each to clear it.
If that does not work the ERC(clock) must be replaced.
May 26, 2009 | GE Profile JTP18 Electric Single Oven
GE True Temp Profile Oven, Locked Door Light stuck on
there should be some type of button that the door hits to turn it on and off
Mar 24, 2009 | GE Profile JTP18 Electric Single Oven
Sep 21, 2008 | GE Profile JTP56 Electric Double Oven
Inglis F5E1 Oven model: IJP85801
The error code F5 E1 is normally associated with problems cleaning
in this case latch not locking. If you did not initiate the cleaning mode then (as u indicate - was baking) then we have a bigger problem. The controller (clock) has malfunctioned. Press any key for about a minute - F2 should appear - then press cancel observe for about a minute - try operation - either back to normal or change control board
Aug 18, 2008 | GE Monogram ZET3058SHSS Stainless Steel...
Ovens Logo
502 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
