Question about Zenith R49W36 49" Rear Projection HDTV
My TV Zenith R49W36
Auto Conv not working to remove double look viewing with green and like red color.
My zenith tv model number r49w36 will come on with sound but no picture can someone please help
Posted on Jul 09, 2010
  • Zenith Master
  • 8,617 Answers
You need to replace both of the convergence ICs. The following link has replacement ICs and provide free tech support so you can do the repair yourself. If you dont know which STK numbers you need leave them an email and list your model number and they will contact you right away with the correct numbers.
http://servicemanuals.vstore.ca/
Posted on Apr 17, 2008
  • 34 Answers
Had the same problem with my Zenith TV. Convergence was all out of whack. I purchased a repair Kit from www.TvRepairKits.com. The kit had all the parts and simple step by step photos of the repair. I cant thank them enough for making this possible . At first the repair did not work so I emailed them and within an hour they told me to check two other items. Sure enough they were right! The set is now working perfectly.
Thanks Guys, I will spread the word.
Louis
Posted on Dec 13, 2009
The auto convergence not working, the colors not lining up together
Try this with TV off Press and Hold CH- and Vol- at the same Time untill TV comes on then release ,Now you should be in factory settings,set should do AutoConvergence .
Oct 31, 2010 | Zenith R49W36 49" Rear Projection HDTV
I need to know the parameter for configuration for a zenith tv 52 inches R49W36 ,because the colors and image are really bad thanks fredy
Sounds like a convergence problem. I had the same issue. I got a repair kit from the folks at TvRepairKits.com. Worked great for me and saved a ton of money.
Dec 31, 2009 | Zenith R49W36 49" Rear Projection HDTV
My zenith projection tv model R49W36 wont aline the colors green,red and blue
Its a convergence problem. You can get complete parts and instructiosn for this fix from www.TvRepairKits.com. They put together a kit for this. I used them for a convergence problem recently and they helped me fix my set.
Dec 22, 2009 | Zenith R49W36 49" Rear Projection HDTV
Double VIsion on Zenith R49W36
Your TV most likely has a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Jun 18, 2009 | Zenith R49W36 49" Rear Projection HDTV
DOUBLE IMAGEN My Screen is showing slightly double of all images plus one image is slightly red and the other slightly green!
Had the same problem with my Zenith2_bing.gif TV. Convergence was all out of whack. I purchased a repair Kit from www.TvRepairKits.com. The kit had all the parts and simple step by step pics of the repair. I cant thank them enough for making this possible . At first the repair did not work so I emailed them and within an hour they told me to check two other items. Sure enough they were right! The set is now working perfectly.
Louis
Jun 01, 2009 | Zenith R49W36 49" Rear Projection HDTV
Pic prob.
WHAT DO I DO FOR MY AUTO CONVERG IT NOT ON MY SETUP OR MY PIC AT ALL MY TV IS OUT OF LINE BAD
Aug 23, 2008 | Zenith R49W36 49" Rear Projection HDTV
Zenith R49W36 Rear Projection TV Convergence IC problem
Louis
Jul 27, 2008 | Zenith R49W36 49" Rear Projection HDTV
Picture is bowed and color is way off
i Would look for a loose connection around the convergence area.
Jan 21, 2008 | Zenith R49W36 49" Rear Projection HDTV
Zenith R49W36 49" Rear Projection HDTV Logo
610 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
