Question about Motorola Mobility RAZR V3
Red dot and an red arrow
Got this motoroala few days ago, without instructions, when i go into the menu at the top of the right hand side is a red dot with an red arrow. what is that or what does that stand for.
  • Anonymous Mar 28, 2014
    on the blurr phone
    motorola blurr phone
I cannot activate my gprs of motorola razor v3
Posted on Dec 05, 2008
    Sergeant:
    Champion:
  • 283 Answers
Is your gprs activated?
Posted on Apr 17, 2008
We have just installed a rainmaster tap timer RM1100 and have lost the instructions
C curved arrow button ( middle left ) SELECTS TIME, DURATION, DAYS, START & also SAVES SETTINGS
RIGHT ARROW button ( MIDDLE RIGHT ) SELECTS Day or hours or minutes to be changed
MINUS button ( top left ) changes backwards values of: days, hours, minutes
PLUS button ( top right ) changes forwards values of: days, hours, minutes
HAND button ( bottom ) manual turn on & turn off water flow through timer.
Aug 05, 2013 | Motorcycles
How to set picture resolution.
Turn the camera on and set the slide on the right hand side to the red camera icon, as if you are taking photos. Turn the dial on top of the camera to the red camera icon. Press the middle circle button (menu/set), you will see that the 'picture size' menu is highlighted. Press the right arrow key to view the different resolutions available, select with the up, down and menu/set button. Press the menu/set button again to leave menu. To change resolution in intelligent auto mode, do the same thing but turn the dial to the red camera with the 'iA' in it.
Sep 20, 2009 | Panasonic Lumix DMC-TZ50 Digital Camera
Folding the bebecar raider at
Press and twist the release button in centre of handle (twist towards seat), while simultaneously pulling up the secondary release on right hand side of handle (just where the rubber grip ends). There is a red dot on each of these so they can be identified.
We had the same problem a few months ago - hadn't used it in a couple of years - had to pull out the manual.
Hope this helps
Jun 13, 2009 | Bebecar Raider AT Stroller
Yello error icon on right side of copier that looke like a lid with an arrow pointing down
You have a door open on the machine, check all the doors on the right hand side. Open and close easc door, you have to move the sorter to access a door or two between the mashine and the sorter.
Hope this is of some help.
ed
Apr 20, 2009 | Office Equipment & Supplies
How to select Texting
I just got my Vizio 32" a few days ago, so this is fresh in my mind. When the tv is on and TV is selected from the top row of remote buttons, press MENU. Use the arrow keys surrounding the MENU button to select the WRENCH icon. Under this icon use the down arrow (surrounding MENU) to select CC. Use the right arrow to choose CC ON MUTE (closed captioning only when you select the MUTE button on remote) or CC where you can use the arrow key to change OFF to ON and closed captioning will be on all the time. Hope this helps!
Sep 28, 2008 | Vizio L32 32 in. LCD HDTV
Retrieving data from v330 with no screen
i) send out to a cell phone repair and they will print out contacts., will cost u $25-$50.
ii) hook up bluetooth to your pc (check your manual or one online) and download the numbers. this is pretty tough without see stuff on the screen, imho.
iii) check manual (online or yours) to save all contacts, at least as many as possible onto your sim card.
this actually just happened to me a week ago, but i have a backup prepaid v300, so i can put my sim in there for contacts. good luck!
Sep 05, 2008 | Motorola Mobility V330
Gateway Keyboard left shift key adds a pipe character
The driver will not fix the problem, as this is a mechanical problem. I had the same problem and was able to fix it. Instructions with pictures can be found at: http://lotus.kick-***.net/keyboard
Here are the instructions without the pictures:
I had a problem with my Gateway keyboard where whenver I pressed the left shift key, it type a pipe | (verticle line) character. This is the same character that is above the back slash character . I searched the internet and people were suggesting reloading drivers and apparently Gateway was suggesting a destructive reload of the hard drive. That's absolutely rediculous.
After some research, I determined that on some European style keyboards, the backslash/pipe key is between the left shift and the "Z" key. So, I removed the left shift key to experiment. The key simply pops off by sticking a screwdriver under it. (It is not necessary for you to do this).
When I used a little screwdriver to press on the center of the plastic (red arrow) I would get a proper shift key. However, when I pressed to the right (green arrow), I would get the backslash character. If I pushed at the red and green arrow together, I would get the pipe character.
Ah-hah! I determined the problem. The inside of the keyboard is a "universal" type and can be used with U.S. or Europeon keyboard layouts. For whatever reason, the left shift key was hitting both dots under the key. (The dots are visible in the pictures below.)
To resolve the problem, it is necessary to disassemble the keyboard. On the bottom of the keyboard is a bunch of screws. Remove all of the screws. If you have any rubber feet, there is probably screws under the rubber feet. The feet are just held on by sticky taope, so they peel right off.
Once all of the screws are removed the top and bottom halves seperate easily. The circuits stay in the bottom half of the keyboard, so set the top half of the keyboard to the side. The red arrow marks where the left shift key presses down.
Pull back the top layer and you will see the flexible circuits. These are also made up of multiple layers. When a key is pressed it pushes these layers together to complete the switch circuit. The red arrow marks the shift key. The green arrow marks the backslahs/pipe key for European style keyboards. The blue arrow is yet another key that is not used on U.S. keyboards.
Pull back the first layer of the switch circuit to expose the space between the circuit layers.
Place a small piece of electrical tape on the extra backslash/pipe circuit connection as marked by the red arrow.
Now simply reassemble the keyboard and that weird pipe character will never accidentally show up again.
Mar 08, 2008 | Gateway 2520915 Keyboard
Red Arrow
The red arrow should represent a recent missed call. To get rid of it, press the left soft key when you are at the home (standby) screen to enter the calls menu. Press the return (arrow) key on your phone to return to the home screen and the arrow should have disappeared.
Nov 25, 2007 | Sony Ericsson Walkman® W880i Cellular...
Red Dots on My Plasma.
Did you get this problem resoslved? I had the same issue a few months ago. I tech came by and took my TV to the shop, a few days later he said it was fixed as they needed to make some adjustments.....The TV has been fine up until a week or so ago and now the red dots have appeared again. Was wondering what happened to yours.
Dec 17, 2006 | Samsung HP-R5072 50 in. Plasma HDTV
Motorola Mobility RAZR V3 Logo
125 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
