Question about Toshiba TEC B-472 Thermal Label Printer
Error PV12; 0736,0548,0 this problem is on the screen and what can we do to fix it?
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Toshiba TEC Expert
  • 142 Answers
Check the syntaxe and the coordinates. You are may be defining a coordinate outside the label
you are printing at 73,6 mm from the left border and 54.8 mm from the top of the label.
Posted on Jan 14, 2014
How to Fix Mac Error Code 8084?
I don't know much about fixing this problem. But whenever I face such technical issue that time i take a print screen using best print screen tool and report it.
Best Print Screen or Snipping Tool for Mac Wetechtuts
Aug 31, 2017 | MAC Computers & Internet
Tip
How to Fix Blue Screen Errors (BSOD)
<p>Blue screen errors, or blue screen of death (BSOD) errors, are the most severe errors Windows can encounter. Since Windows can not recover from this kernel level error, a blue screen is displayed with the error details. The error details contain a STOP error code, which indicates the type of error.<br /> <p>There are a lot of possible causes for blue screen errors, but most of them relate to the computer hardware. The cause of a BSOD error can be a temperature problem, a timing error, a resource conflict, hardware failure, a corrupt registry, a virus or simply a device incompatibility or driver error.<br /> <p><b>How to analyze blue screen errors</b><br /> <p>The first thing to do to analyze a blue screen error is to check the meaning of the STOP error code. You need to stop Windows from rebooting when a STOP error is encountered. Once the blue screen of death is shown, you can check the meaning of the STOP error code. Together with the filename of the driver or module, this will give an indication of the error cause.<br /> <p>Another option to analyze the cause of the blue screen error is to look at the Windows system event log or to debug the memory dump (minidump) that Windows created when the error occurred. The event log can be viewed using the event viewer. Right-click Computer in the Start menu, and then select Manage. In the Computer Management window select Event Viewer. The information in the event log can be of great help to isolate the cause of the blue screen error.<br /> <p>Reading the minidump requires a bit more technical knowledge, but Microsoft has tools to read the minidump.<br /> <p><b>The most common cause of blue screen errors</b><br /> <p>In reality, the most common cause of blue screen errors is a device driver problem. Outdated, incorrect or corrupt drivers can cause the system to encounter a STOP error, resulting in the BSOD.<br /> <p>So the easiest way to try and fix a blue screen error is to reinstall and update your system's device drivers. This will ensure that all driver bugs are fixed and that all hardware has the correct driver.<br /> <p>If you know which device caused the error, you can update or reinstall that driver first. The file name in the blue screen of death can help identify the driver. Look for a file with the .SYS extension and search for that file name.<br /> <p>If you do not have the drivers for all devices, or are not comfortable updating your PC's drivers manually, you can use a driver update tool to find, download and update all device drivers for you. Such tools will accurately identify your computer hardware, including any device causing an error, and automatically install the latest drivers for it.<br /> <p>In most cases updating or reinstalling drivers will solve your blue screen errors.<br /> <p><b>Other causes of blue screen errors</b><br /> <p>However, if updating device drivers does not fix the blue screen error, there are a number of additional things to try:<br /> <p>Load the default BIOS values - resource conflicts and timing issues can be caused by incorrect BIOS settings.<br /> <p>Update the BIOS - especially after adding new hardware or installing a Windows service pack this can help fix issues.<br /> <p>Update Windows - missing updates, including service packs can be a source of stop errors.<br /> <p>Check your system - run a virus scan and spyware scan after updating your definition files.<br /> <p>Driver rollback - if you have recently updated a driver, you can use the driver rollback to revert back to the previous driver version.<br />
on Nov 29, 2010 | Computers & Internet
Tip
Fix all your PS3 Problems
Send Your Console to Sony = $150
You need a PS3 Repair Guide = less than $35
THE NUMBER 1 GUIDE IS YLOD REPAIR WIZARD
This guide has proven permanent fixes for the following errors:
In order of the most common:
1.YLOD (Yellow light of death)
2.Green/Red/Blue Flashing errors
3.Disk Read Error/Blue ray Drive Error
4.Hard Disk Corruption
5.No Display Error
6.Red Screen Error
7.Freeze ups
8.Fix All error codes (8001050F)
9.Sync error
10.Blank Screen error
Need More Info On PS3 Repair guides and the YLOD repair wizard
on Aug 25, 2010 | Sony Playstation 3 (PS3) Console
I wrote a text message to someone today and at the bottom of the message in a gray box popped the word Velkomin
Hi, you can try FoneDog iOS System recovery.
  • Fix with various iOS system issues like recovery mode, DFU mode, white screen looping on start, etc.
  • Fix your iOS device to normal from white Apple logo, black screen, blue screen, red screen.
  • Only fix your iOS to normal, no data loss at all.
  • Unfrozen your iPhone, iPad and iPod touch
Here are some articles for FoneDog:
Tips & Trick to Fix Your iOS System
iOS System Recovery Guide How to Fix with Various iOS System Issues
May 16, 2017 | Cell Phones
Dell Dimension 3000 blue screen error with writing that say attemp to fix windows
First of all you have to identify the blue screen error code. Blue screen errors normally occurs due to infected windows files. You need to scan PC to remove malwares, junk and virus.
Also update the drivers that control your PC.
To fix this problem instantly use system optimization tool like Reginout.
Mar 27, 2013 | Dell Dimension 3000 PC Desktop
My hp g61 will only display a blank/black screen with the cursor after it has finish booting
That cursor is the way in which the BIOS of the laptop is telling you that Windows is completely corrupted and unbootable. You will need to reinstall it so use the recovery cd that came with the laptop.
Dec 28, 2010 | HP G60-120US Laptop
The screen says lens error
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Dec 30, 2009 | Kodak Easyshare M753 Digital Camera
Toshiba TEC B-472 Thermal Label Printer Logo
54 people viewed this question
Top Toshiba TEC Office Equipment & Supplies Experts
matt
matt
richie46
Are you a Toshiba TEC Office Equipment and Supply Expert? Answer questions, earn points and help others
