This problem should be removed because:
Problem with Toshiba Projection Televisions
My Toshiba CZ27V51 television won't turn on - all we get is a blinking red light by the on/off button.
Suggested Solution (3)
3 blinks is short protection on this model---98% chance one of the two STK-392-110 Convergence chips it uses has shorted.
If you unplug set and look inside you will find two black chips that have that number printed on the front of them in white letters. Right in front of them you will find about a dozen light blue resistors---most are marked 2.2 ohms---look if you get a chance---if even one of those resistors is white in the middle (discolored) you have found your problem.
Both chips and any bad resistors need to be replaced.
The repair involves getting at the parts and replacing them--the chips each are mounted side by side on metal heat sinks with fins--each has 18 pins.
Most shops get 300 or more for this repair but the actual parts cost if you or someone you know can do it is under 30 dollars.
I have START TO FINISH, STEP BY STEP INSTRUCTIONS FOR THIS REPAIR IN THIS SET. I got a notice from a lady who used them to fix the same set you have---she saved the set and a lot of money.
The instructions tell you everything you will need and how to do the repair----clearly I do not know how much skill you have---it involves soldering etc.
If you want the instructions I will post them here for you to look at and copy/ paste them. Once you read them you should know if you can do the repair------they are my own instructions based on doing this repair hundreds of times.
I will also post a photo here showing what the chips look like.
Repair takes me about 1 hour; if you are doing it for the first time it will take you longer.
I also know the best place to get the chips at reasonable price.
If this information has helped you rate this solution as I do this here for free.
SD TECH
Testimonial: "Very Helpful information and willingness to help."
Source: Television is not turning on
how many times does it blink? try to unplug it for a few hrs. and see what what happens
Refer to owners manual ! Blinking indicates the type of fault that is occuring on all your tv sets. example : power light on red - indicator light beside it green but blinks rapidly for half a second rapidly then shuts off. This refers to a faulty lamp or a lamp that is near its expiration. Read your manuals if indicators refer to easy repair sweet, but if it says call tech then bummer...
Source: Hitachi 55VG825 rear proj television blinking light and screen doesn't light up
Theatre View Toshiba Rear Projection TV 50 Inch...
I have a Theatreview Rear Projection TV 50 Inch Toshiba Today I could not get it to power on- Each time I pointed the remote or attempted to...
Red power button blinking but tv won't power...
push the on button red light comes on then starts to blink but no picture>> help please. toshiba model TZ50V61. red light continually...
REd light blinking on my 50HX81 CRT TV- Toshiba,no
REd light blinking on my 50HX81 CRT TV Toshiba,no picture,no sound
I have a Toshiba Projection
I have a Toshiba Projection TV model # TP55H60. When I turn it on a red light by the power button blinks and it will not turn on. My...
My Toshiba television (46HM95) won't
My Toshiba television (46HM95) won't turn on. When power button is pushed, one light stays green, the other blinks red. Tv will not turn...
Tips for Helping lrob752553 With Their Issue
- Give detailed step-by-step instructions
- A picture or video is helpful
- Use plain language not industry jargon
- Check spelling & punctuation
Add Your Solution
pc wont fire up
When I press the on button the machine fires but instantly dies and tries again but nothing. In the lcd display top...
how to setup a kds mentor on a hk600gt with...
How to set up a flymentor to rc hk600gt with turnigy 9ch radeo
toshiba 52hmx94 green screen
trying to use hdmi for ps3 it worked for a minute the other day, i can read and change menus so i don't think...
my RCA tv green power button flashes and beeps,...
2004 HD tv large box
I have a 50 Inch Toshiba DLP. The red light would...
I have a 50 Inch Toshiba DLP. The red light would come on and them blink and them turn itself off and start all over...
Fix-O-Meter
49
49 people viewed this problem
- 0 people are following this problem. Be the first!
Top Toshiba Projection Television Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
What you will need;
Two new STK-392-110 convergence Ic’s
Solder
Liquid solder flux
Desoldering braid or wick
A good soldering Iron
Some denatured alcohol
A small toothbrush
A Philips screwdriver or screw gun to REMOVE SCREWS
A PAIR OF GLOVES
grill on set(it pulls off and may resist being removed)
wires (they are plugged into the main circuit board).
that come from the Front keyboard—two of them have to be unplugged from
the main board(all plugs are different sizes but note where they go)
machine bolts from the front of the set (behind the grill).
the set; two are located at the extreme back edge of the plastic frame and
hold the chassis down; two more are located on either side and also go
straight down; note which are which and set them aside.
metal box (it is called a light box) out of the set; there are hand holds
on either side—careful as the metal has sharp edges.
and locate the two Convergence IC chips; they are located on identical
metal heat sinks with fins and they should have the STK-392-110 number
clearly printed on them in white (they are black)
its side and UNSOLDER ALL 18 PINS ON EACH IC. It is a good idea to apply
liquid solder flux to the pins on both chips now. I recommend using a
de-soldering braid for this—get all the pins completely de-soldered.
blue resistors in front of them; most are marked 2.2 ohms—if any are white
in the middle you will need to replace them at the same time; best way is
to check all of them like checking a fuse----they protect the set if one
of the STK’s shorts in any way.
unsoldered turn the box upright and remove the two screws on each IC. If
the chips have never been replaced you will need to tap them loose with a
putty knife or flat bladed screwdriver.
Normal
0
false
false
false
font-size:10.0pt;
two new IC’s and install them one at a time; this part can take some time
and it is important the pins on the new IC’s are perfectly straight---once
you get them in, Hand tighten both the screws on each IC---do not use a
screw gun—you can strip the screw holes out. Clean the bottom of the
circuit board where the chips were soldered with some denatured alcohol
and apply liquid solder flux to all the pins.
found/replaced any bad resistors turn the box back over and solder
carefully both of the two new IC’s in, --do not short any of the pins to
each other when you do this and when you are done it is a good idea to
take a close look at both to make sure all pins are soldered and not
touching each other with soldering you have just done. I suggest you do
clean the pins on the bottom of the circuit board again with denatured
alcohol.
into the cabinet.
removed when you removed the box. At this point take a lens cloth or a
paper towel with glass cleaner sprayed on it and clean the three large
black lens-if they are dusty the picture will be darker and not as clear
as is should.
the way in place and none of the wires or plugs are pinched.
the set on before I replace the Six bolts that hold it in—2 from the front
and the four in back----this way if you have a problem you can remove the
box faster.
has normal Convergence go into the customer menu and adjust the
convergence in the multi-point mode----CAREFUL! THE FIRST OPTION this set
usually offers is a green cross in the middle of the screen—do not adjust
Green!
Blue in the center adjusted find the second convergence mode---it will
give you 8 or nine points on the screen with instructions on how to change
from blue to red---use the original remote with the thumb wheel or cursor
buttons to adjust.
to have the Convergence adjusted in first: full/4:3 and second in the
other two zoom/wide zoom and third on the HD input with a HD signal coming
in. There is also an option at this point to go into the Technical menu
and fine adjust the convergence all over the screen—if you need this I can
give you instructions based on the model you have—most of the time
adjusting the set in the customer mode will produce a good result.
complicated to you, but this repair should take about an hour or so and
just take your time when you get to adjusting the set.
set off and Unplug it; install all 6 of the chassis bolts back; replace
the back cover and the Speaker grill and plug the set back in.
over the convergence Adjust again—to get all the points as good as you
can. There is a hidden Tech menu that will allow a finer adjustment of the
entire screen----it is somewhat difficult to access and there are a lot of
buttons on the remote that then do different things.
Most of the time adjusting in the customer menu will
give you a very acceptable picture
These are the instructions---ignore the true/false stuff--there because document was composed in MS word.
Copy and paste and save. On EBAY--select advanced search, then to the left search by seller sewsales55 is the seller I buy from---SUBURBAN ELECTRONICS in Maryland.
You can find a pair of the chips and some of the other items there--if you want to upgrade from the 392-110 chips--use STK-392-150 ---SAME PART BUT LONGER LASTING.
LET me know if you have any questions or need advice.
SD TECH
