Back to:
Tags:
Samsung SlimFit HDTV TX-T2782 TV
TV won't turn on (by 6 users)
posted by Moiz da Boss on Apr 17, 2008
TV wont turn on with the remote or manually. No lights are showing on the TV, the red standby light is off too. Changed the power supply fuse but it keeps blowing up. What is the problem?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
5 Other Users Have The Same Problem
Comment by Guest, posted on Jul 19, 2008
I have the same problem. No idea.
Comment by sportsmom3, posted on Jun 06, 2008
My t.v will tun on briefly then shut off and not come back on until you unplug it and plug it back in and then it repeats the same process again.
Comment by Guest, posted on Jun 04, 2008
I have the same problem. Repaired once. It happened again within 3 months.
Comment by Guest, posted on May 19, 2008
I have the same problem - it will not turn on - it's only 2 months old!
Comment by jwy569, posted on May 11, 2008
tv workrd one day. the next day it wouldnt turn on
Solution #1
posted on Apr 17, 2008
Not Rated (0)
rickzpert
Rank:Guru Guru
Rating: 85%, 20 votes
Shorted problem. Maybe in primary or secondary power supply. Need a repairman. Busted regulator, or shorted diode.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on TV won't turn on:
I don't want to Accept this solution
Can you Help with these Standard Televisions problems?
samsung tv When I turn it on it goes to menu with double...
My son's television has just gone blank (had a trial code...
i have no power at all, no stand by voltages, no voltages...
On standby LED is red. When I turn TV on, there's no...
makes a high squealing sound when you turnit on. Makes the...
Loading problems.
Repair Service
Find Standard TV Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
