Question about Acer AL1912 19" LCD Monitor
Need to know how to Disassemble AL1912 19" LCD Monitor
I cannot figure the dang thing out. It must snap together somehow after removing 4 back screws and 2 screws under the stand. Can anyone help, possibly send me the service manual, or an explanation of how to disassemble this bastard?
My screen went out after the power in my house flickered, and i want to figure out if it is the backlight that got fried or a component somewhere.
Thanks. Email service manual to Daveman123@hotmail.com if anyone has it. Much obliged.
  • 1 more comment
  • Firehawk734 Apr 17, 2008
    Ok Thanks so far guys. I was able to get it to pop apart all the way down to where the buttons are. It seems like it's alot more solid there than everywhere else. SHould I continue to apply alot of prressure to get it to pop all the way off or is there something else I should do?
  • futureid Jun 15, 2008
    have the same problem after a power surge. Took the screws off the back and its still not opening. Can anyone help me. my email is futureid@aol.com. -thanks in advance
  • whalil Aug 10, 2008
    I've been able to get the bottom and the right and left sides apart, but I can't seem to get the top of the monitor case apart. Is there a trick or hidden release that I'm missing?
    Thanks,
    Genius:
  • 1,554 Answers
The ones I take apart have a snap on front bezel.
gently pry at the lcd edge with fingers in center left or right to get it to bow , dont damage the lcd with too much pressure.
it will start to separate ,put a plastic knife or such in the outside crack and work your way around once you have one side the rest will be easier. you have to bow the inside edge out(away from the lcd) because of the plastic clips.
luck.
Posted on Apr 17, 2008
  • 472 Answers
Ahhh too funny =) They don't make them adult proof for nothing.
Ok, get a towel, lay it on a flat surface.
Place the monitor screen down onto the towel
Looking from under the monitor there will be 2 main ways to "Disassemble the bastard" heheh Ahhhh ..anyway
Look closely where the front and back panels join. You should see two notches possibly holes there. If so then insert a flat blade screwdiver about 1cm into the hole and lift upwards. It should pop. Do the same for the other side, then gently just using your hands pop it around the rest.
The "theres no bloody notches here method"
Insert a flat blade screwdriver between the case and the top of the power socket. Again, just 1-2cm. Lift up (gently) and this should begin the popping operation.
Just becareful not to jam the blade in too far.
  • Peter Thompson
    Peter Thompson Apr 17, 2008
    Coldcut is correct... it could be either way with Acers. The last AL1912 I did was the back panel that popped, but I have had a few AL1911 that had both options between them.
    Possibly the factory getting rid of old parts. Who knows what they are thinking when they slap half of these things together =)
  • Peter Thompson
    Just double check there isn't a screw from the back of the monitor right in the middle at the bottom. It would have been initially hidden by the stand.
Follow the directions above for removing the four screws on the back, and then the four screws underneath the plastic clip at the top of the mounting stand that secure the stand to the monitor frame.
There are eight plastic clips that hold the monitor together - they are three on either side and two on the bottom.
They are located 2.5", 7" and 11" down from the top on the sides, and 5.25" in from the sides on the bottom (none on the top)
Use a plastic tool (such as an auto trim toll that you can get a Harbor Freight) to push in at those locations on the side seam and gently pry apart the monitor's two halves.
The power supply and video board are underneath a metal cover - it is attached by two screws and the turn nuts that hold the VGA connector in place.
Posted on Apr 26, 2013
I have just taken mine apart there are four screws on back for the bezel also four more that hold the base stand on these are behind plastic cover that clips on over swivel mount
Posted on Apr 21, 2008
How do you disassemble the monitor? I want to repair it...I have taken all the screws out of the back of the monitor, but I can not figure out how to pop off the back without damaging the monitor. Please...
I use thin flat blade screw driver to crack it open at the bottom edge so any scratch will not show up as bad, not much you can do from not scratching it up due to the way the front and the back are snapped together with plastic fingers. It is worst on the newer one.
Look for bad caps in this model.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Jan 03, 2011 | Gateway FPD1960 19" Flat Panel LCD Monitor
NEED TO CHECK FOR BAD CAPS IN VIEWSONIC vp2130
To disassemble your monitor follow these steps.
1. Remove the stand, usually 2 to 4 screws
2. Now there will be screws in each corner on the back of the monitor.
3. Take a small flat blade screw driver and seperate the two halves of the case. The front and back are held together by plastic latches spaced several inches apart around all four sides.
4. After the back case is off the boards you will be looking for are under the metal shield, remove the screws that hold it on.
5. Check my web site at www.ccl-la.com , we have pictures of what the bad caps look like if you are not sure.
6. Be sure to replace any capacitors that have raised and blown tops.
I hope this helps, If so please rate my solution.
If you need more info let me know.
Buddy
Corporate Computer
www.ccl-la.com
Jul 03, 2009 | ViewSonic Pro VP2130b 21.3" LCD Monitor
Remove the back on NEC LCD 2010X
Remove the 2 screws from the bottom of the screen at the back of the monitor. Half way between where you removed those screws use a flat tip screwdriver or similar to push the back plastic shell in & up to release the clip holding the 2 parts together. Similar clips also hold the top sections together. Good luck
Mar 19, 2009 | NEC MultiSync LCD2010 20.1" LCD Monitor
Acer 1717 monitor- removal of base
At the base you want to remove - in order to pack the monitor - if you se at the rear left and right there are a tiny opening about 3 cm long,put inside a screw driver and it will open very easly the plastic cover.Then inside there are four screws,two on each side,remove them and the arm of the screen will be dis-attached.
Dec 21, 2008 | Acer Al2416WD LCD Monitor
Can't remove cover of Westinghouse LCM-22w2 monitor
Hey Ed,
I hope I can help, It doesn't open from the back, it opens from the front.... carefully! There are four support screws, which hold the LCD screen to the desk stand,after removing all the support screws (4) on the back under the support stand cover.(which pull up to remove) (Remember! the whole case and face frame is plastic, so take your time). Work to separate the black face frame around the LCD from the silver case. Its held together by small plastic clips on the face frame to the wall on the LCD case. Start at one of the corners and slowly pry the face frame and silver case apart. (separate it inch by inch, work your way around the case carefully. If one corner doesn't give, go to another side.
Putting back together works reverse, the face frame and the case snap back together, Carefully! And replace screws (4).
Russell
P.S. I have three LCD models from Westinghouse, LCM-22w2, L2210NW and the L1916HW. They all open the same way.
Dec 07, 2008 | Westinghouse 22" Widescreen LCD Flat Panel...
How to disassemble 900w
The proview trims have to be slid upwards to remove them once the 4 screws are out of the bottom.
You'll need to lift the top part slighty away from the lcd to allow the sides to slide up.
If you don't slide it , then yes, you'll break tabs.
ebays bammbammfran
Aug 25, 2008 | Gateway FPD2275W LCD Monitor
Remove the back to an HP CRT Monitor
first of all u have to tell me the way it's gone dead. is it damged due to excess power supply or in a running mode (suddenly). You have to tell me the major component used in power supply unit, only then i can give u the complete guidence and solution.
Feb 06, 2008 | Gateway FPD2275W LCD Monitor
Getting the monitor apart
It is clipped on, or there is a hidden screw underneith a sticker or something.
They make these things hard to disassemble for a reason. There is very little you can do one you've got it open. There's almost nothing inside that can be serviced by any normal user.
Jan 23, 2008 | Sceptre X9G-KomodoV (Black) 19 inch LCD...
Remove cover
Its a snap together job But unless you know where to start something will snap. Try the Samsung Tech support for this product. Even if the Back light or inverter or some other do able thing is doable- getting parts may not be so easy for you. So follow their advice for service.
May 15, 2007 | Samsung SyncMaster 540N 15" LCD Monitor
Is there an easy way to open this monitor?
-Flip the LCD face down and remove the screws that hold the base in place. -looking at the top edge of the LCD monitor you should see a small notch on each end between the front bezel and the back cover. -Using a plastic tool or a flat blade screw driver insert the tip and gently pop the case open. -Work your way around the edge of the case. -Once the LCD monitor is open unplug the control panel connector from the right side and remove the front bezel. Let us know if you have any other questions and please don?t forget to rate this post.
Dec 28, 2006 | Dell E173FP 17" LCD Monitor
Acer AL1912 19" LCD Monitor Logo
3,520 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
