I have had this problem and have been one of the lucky few to get round
it, however i believe i may know the cause or part of the cause for
this, and a way to get round it hopefully. I got this issue after an
unfortunate power cut, the system started up but then shut down again
unexpectedly, after that i got this 'black screen of death', i then went
on to many forums to find out the best options for solving this, i knew
there was a definate way to fix the problem with a full destructive
recovery with the recovery partition you get with vista, however i
didn't want to lose all my data so when the computer starts up tap f8
until you get several menu options. the top option should be 'repair my
computer', you should now have a very basic log in window which has your
username, (if you have no password just press enter). now you should
have several options of recovering or repairing your PC. the most
successful so far is a normal windows restore which takes the computer
back a few days, i would recommend a week to 2 weeks if available. once
completed this should get rid of the 'black screen of death'. once
logged on run command prompt with administrative properties then type in
'sfc /scannow' this will hoefully find anything else which is currupt. i
have found the main reason for this is actually vista's own way of
performing better... on most people with this problem i spoke to had an
option enabled on the hard drive by default : 'Enable write caching on
the disk' : 'this setting improves disk performance, but a power outage
or equipment failure might result in data loss or curruption' this
option can be found by going into device manager - find your primary
hard drive, right click, properties, policies. this is the closest ive
found to a cause of this 'black screen of death'
the fixist good luck and have a nice day
