Question about Kitchen Ranges
Oven was getting to warm and now it will not light at all,but I still have a pilot light
    Genius:
  • 1,073 Answers
Need your model number
Posted on Apr 17, 2008
Although pilot lights are lit, only one burner works the other 3 do not??? also do not see pilot light for oven??? does it even have one or light by match only??
Hello Linda
All burners have a small hole in the flame spreader which directs a jet of gas to the pilot lights when you turn the burner knob. These get clogged by food residues over time.
Remove all the burners and give them a good soak in hot soapy water. Sometimes you need oven spray first.
All modern ovens have a pilot light. There will be a red button which is usually hidden below the front removable panel or just inside a warming drawer at the top. You press and hold the red button and then light the pilot inside the oven. You continue holding the button for the flame to heat up a gadget called a thermocouple. This is a valve that only allows gas to the main burner if the pilot light is alight.
Take a look at the videos in the link.
pilot lights Google Search
Aug 23, 2016 | Kitchen Ranges
Just started renting house that has the Maytag Performa Electric Range and I noticed last night that the "on indicator" light is on (and still on tis morning); however, none of the burners nor the sto
The pilot indicator is powered by a contact in the thermostat or control board. It is usually not powering the oven but it could be allowing 120 volts to the element this would make the oven very warm. If you unplug the stove for a while and then plug it back in and the oven gets warm again I would have it checked. It may be drawing power.
Sep 24, 2014 | Kitchen Ranges
My pilot light comes on< but the oven will not
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
May 13, 2010 | Magic Chef 31000 Gas Kitchen Range
Pilot light is lit both on oven and stove top... previous user says to turn on gas and lite "sensor" or "2nd pilot" it stays lit as long as oven knob is on but oven burner does not light. "sensor" goes out...
On standing pilot ovens the maker uses a safety device to kill the gas in case the pilot blows out. As long as the pilot is lit the gas safety magnet hold the gas flap open inside the safety valve.To save energy the pilot has 2 flames. The standby pilot keeps the cooper/nickel probe/sensor warm so the oven will light faster, the 2nd pilot is much larger, only appears when the oven control is turned on and this is what opens that valve. So when you turn the oven knob on the gas leaves the control and goes downtown to burner land. If that pilot is lit and that slow opening flap inside that valve is open, then the gas will enter the burner tube and ignite when it hits the pilot. Pretty slick ain't it? So what can go wrong? With age the flap inside the safety valve will wear out, get weak, work a little, then take forever to light and eventually just goes bye bye. When you get ready to replace the valve it ain't gonna be adjusted exactamundo, you gotta tweak it. To do so after bubble testing for leaks and lighting the pilot you turn it on and observe the flames. It needs to be not more than half way up the flame spreader. If it is to small of a flame it will take forever to bake even a pie shell, if it is too much their could be burned bottom and in some cases fire hazards. OOPs.
Apr 06, 2010 | Magic Chef 9122 Gas Single Oven
The oven does not warm up. Pilot lights seems to
I wrote a tip that addresses the problem you are having...
Check it out here..
Heatman101
Mar 10, 2010 | Maytag Ovens
Stove works just fine/oven does not warm up - pilot light is on, but turning on oven does nothing but make the pilot light glow a little bigger. Oven will not ignite.
Hi, The ignitor is getting weak and will not open the gas valve. Replace the ignitor and you will be back in business. This is a very common problem with the gas ovens.
Please let me know if I can assist you further.
Vic
May 29, 2009 | Ovens
Blodgett 961-P pizza oven
Go here find what you seek.
BLODGETT
44 Lakeside Avenue, Burlington, VT USA 05401
Toll Free: (800) 331-5842 Phone: (802) 860-3700 Fax: (802) 864-0183
Great Co.
Sep 30, 2008 | Blodgett 911-DOUBLE Gas Oven
Oven pilot light won't light
you must push and hold the button on the bottom fo the safety valve until the thermocouple is warm enough to keep the safety valve open. @ 25 - 30 seconds
Dec 13, 2007 | Garland H283 Gas Kitchen Range
Kitchen Ranges Logo
54 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
