Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Washer wont go
My machine is full. Used to go to next stafe if i banged on the top. Now nothing... help?
    Genius:
  • 1,073 Answers
Check the lid hinge screw for looseness if they are tight replace the lid switch
Posted on Apr 23, 2008
Have a GE washer that has small, medium, large, and super load size. It's a top loader. When machine starts wash cycle, it bangs on the cotton and permanent press setting?
Probably out of balance, if in the spin cycle. If not, a "bang" corresponding with agitator reverse, you may have a transmission problem. Override open lid off switch with a pencil or used toothbrush in the small hole upper left location just under lid when closed so you can see the agitator action. If so run it till it breaks. Then replace. Otherwise, call your friendly appliance repairman and ask for a repair estimate first. If it is an ageing machine consider repair cost versis a lightly used one or new.
Oct 30, 2014 | GE G.e. Gtwn4950lws He Top Load Washer
This Charlie from Az. I have a Kenmore Elite washer MOD#-110.24946301. It will fill only with water but it won't drain or spinn...in the past we would bang on the top of the washer and it would work now...
Hi Charlie...the first thing I go to if a washer does not spin is the
belt...but since you would get it to work by banging on it suggests
a faulty lid switch which may be beyond banging. I am not familiar
with your machine but most switches are under a cover just under
the top of washer....fastened by a couple of screws...unplug the
washer and examine the switch for unsecured wires...you may
have to replace the switch. There are about a dozen other possible
causes but you would need a manual to explore them all.
Regards,
Dennis
Aug 26, 2014 | Washing Machines
Spin dry wont work
It seems most likely transmission or clutch or motor problem after checking out lid switch
Dec 09, 2013 | Amana 3.2 cu. ft. Top-Load Washer
GE top loading washer turns off by itself
How about a lid switch. Try pushing down on lid to restart.
May 10, 2010 | GE WBSR3140DW Top Load Washer
Washer filles with water but wont change cycles
start filling the washer on the warm cycle,turn washer off,if the water keeps filling then you have a bad water inlet valve,if it turns off then you have a loose water level hose or the water level switch is bad-mike
Jul 21, 2009 | Kenmore 22422 Top Load Washer
Kenmore top load washer- have to bang lid several
This is most certainly caused by a faulty micro switch on the lid. Have the switch checked out and replaced if need be.
Best wishes,
Graemevm
Jun 06, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Washer Doesn't move from cycle to cycle
this washer has a problem with the lid hinge screws coming loose. check the left hand hinge and you will find the screws loose.
this cause the lid switch to not engage and then nothing will happen until it thinks the lid is closed.
try to tighten the screws and listen to see if the switch "clicks" when you open and close the lid.
that should fix it until the screws come loose again.
Jan 30, 2009 | Whirlpool LSR6334LQ Top Load Washer
Kenmore Oasis top load always out of balance and bangs
First just to let you know, the oasis is very sensitive to the load level and water ratio if its too heavy the load has to be perfectly balanced inside the tub. Next check to see if any of the straps are broke. The next thing is that the newtator has tighted up all on its own so when it spins the newtator grabs the tub while it spins at high speed. I have never had to fix this but i know it is a common problem. I hope i helped a little. Good luck!
Jan 14, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Washing machine fills, but won't agitate
Lid switch if its a Maytag Alantis... You said you have a GE top load in the start of your problem and ended witha maytag?
Dec 18, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
16 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
