Question about Dishwashers
Have a frigidaire 3000 speedclean dishwasher - keep getting an "er" flashing signal mid cycle. and the washer stops- I think it is getting hung up during the sanitize signal
  • Anonymous Sep 23, 2008
    our dishwasher starts flashing all the options on the front panel and the sanitize light on the features flashes. The machine continues to run aimlessly (just spits out water unless stopped) when reset.
SOURCE: Frigidaire PLD3465REC dishwasher error??
Hi, I am having the same problem you describe above with the model nr PLD3460RDC1. Were you able to find out what it was? Thanks so much!
Posted on Aug 18, 2006
localwonder
  • 6784 Answers
SOURCE: Dishwasher during normal cycle gets hung up and does not advance
HI. this is just a control fault. you can try to reset the core program by unplugging this unit for 5 minutes. this will drain all power and reset the core on the timer/control.
If you experience the same situation after this reset, simply replace the control/timer module.
Posted on Jun 03, 2009
SOURCE: Dishwasher showing Er . Reads as
ER code, that indicates a keypad switch failure.
Below is a DIY self help Dishwasher repair help website.
http://www.acmehowto.com/howto/appliance/dishwasher/dishwasher.php
If you confirm the error code and it is an ER UO code then the vent fan assembly will need to be replaced.
If you can't verify the error code then I recommend a technician check this problem.
Posted on Oct 15, 2010
SOURCE: Frigidaire PLD4375RFC Dishwasher error "ER s" any
error message says ou-what does that mean?
Posted on Apr 23, 2011
Daniel S
  • 4323 Answers
SOURCE: Frigidair Gallery Supreme Dishwasher Users Manual
Hi
What is the error code? Are you talking about lights flashing? Please elaborate and post back its complete model no. for further assistance.
Daniel
Posted on Jun 03, 2011
Frigidaire dishwasher error code
Hello Teresa Ann - Typically error code UO indicates that while the dishwasher is in wash cycle, the main control board is not receiving signal from the vent assembly and that the vent plunger is in a closed position. A professional will need to check the wiring between both parts and depending from the results either part may need replacing.
Jan 19, 2013 | Frigidaire Dishwashers
My Frigidaire Dishwasher FDB1050RES2 gets stuck in a rinse cycle. The light on the front will be lit "clean" but the bottom of the washer is full of water. Opening the door does not turn off...
by the descrition you are giving you will need to replace the main control board.Part number 154568401.you may also need to check the float switch.The part will run about 110.00 dollars from a local parts store
Dec 29, 2010 | Frigidaire 24 in. FDB1050RE Built-in...
THe Dishwasher just keeps Washing And Rinesing
Turned Fridgidaire washer on last night before going to bed; this morning, it's running (at least making sounds) but did not wash; 4000 Series Frigidaire; display says Washing Drying Er Clean S; and two lights are flashing - Ultimate Scrub and Rinse only.
I tried turning off the breaker and restarting the machine but that doesn't work.
Sep 05, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Cannot clear PF light flashing on frigidaire dishwasher
Frigidaire dishwasher will not work at all it has PF blinking
May 27, 2009 | Frigidaire 30 in. Electric Gallery Series...
My dishwasher is flashing an ER signal
The moisture is probably getting in through a defective door gasket allowing it to leak.
It will burn out your computer board again if left unattended.
Mar 31, 2009 | Frigidaire 24 in. FDB635RF Built-in...
Frigidare front loader washer error message 20
If you open the top of the washer , there is a "tech" sheet in there to tell you how to reset the error codes.
My washer started this. Then stopped spinning. Now it will not even wash a load. It stops mid-cycle. The ER 20 means that something is not draining right. We checked all of the tubes leading to the pump. Nothing was clogged. The technition seems to think it is a motor controller error.
Oct 27, 2008 | Frigidaire Affinity ATF7000E Front Load...
Washer keeps stopping mid cycle
Bad timer motor or mechanism...accordianman
Mar 21, 2008 | Dishwashers
Dishwashers Logo
253 people viewed this question
Top Dishwashers Experts
