Epson 7300 I need to reset the lamp timer...where is it?
Thanks for this info Guru
I had the same problem. Based on your above post, I did a work
around. (yes- the fuse does need to blow upon replacement)
Epson 7550C with an ELPLP07
I soldered an external fuse holder to the original lamp housing and
wired it outside the case. I put in a 500ma fuse, but it was too
strong for the ELPLP07 to blow. (should be 100ma I think)
(the projector goes to flashing red after 3 seconds)
So to cheat this, I powered on the unit, hit the projector-lamp-on
button, and then withing the first 3 seconds, I unscrewed the
fuse from the holder and removed it ...live.
This faked out the projector into thinking it blew the fuse.
Sure enough, the timer cleared, and I have 2000 hours again.
(And no more flashing yellow lamp light. All green now)
I would have never figured this out without your post above.
Thanks again...
Posted on Dec 03, 2009
  • 563 Answers
Hi there
The Epson Powerlite 7300's lamp has got a chip on the side of the lamp's bracket that resets the lamp timer automatically when a new lamp is inserted. And it only does it once - first time the unit is switched on after replacing with a new lamp.
The fuse on this chip blows and causes the lamp timer to be reset. Unfortunatelly this is the only way to reset the lamp timer on this model. There is no manual way.
So to cutt to the chase , you will have to buy the original lamp and replace it before it will reset.
Part Number is : ELPLP05
Posted on Apr 17, 2008
I have an epson powerlite 825 projector. I recently replaced the lamp and it came on but i was getting the overheating message. So i opened it and air cleaned the fans and filter. Now i get a solid red...
Well hopefully you didn't over spin any of your fans. You can reset the lamp timer with the buttons on the unit, but you have to be able to project. Its in the menus at the bottom called reset. The 825 has an over heating issue. If its in warranty it should go in. I was able to get a firmware update for it but you'd have to push Epson tech support on that. I wonder if you didn't do something to the lamp cover it depresses a switch.
Dec 07, 2012 | Office Equipment & Supplies
Reset lamp timer on epson 5500c after timer has expired
Could be a bad ballast. Did you get the door and latch closed completly?
Apr 26, 2012 | Epson Powerlite 5500c - Lcd Projector -...
I have a Epson lcd projector mp-x3 the lamp light is blinking so I replaced the lamp and the lamp light is still blinking and there is no light do I need to reset the lamp if so How do I do thatMukrray
Connect the power cable, power on the projector and then press the [Menu] button on the remote control. The configuration menu will be displayed.
Select Reset Lamp Timer from the About menu, and then either press the [Enter] button on the remote control or the [Auto/Enter] button on the projector's control panel.
Select Yes, and then press either the [Enter] button on the remote control or the [Auto/Enter] button on the projector's control panel.
The lamp operating time will then be reset.
Aug 11, 2011 | Epson EMP-X3 LCD Projector
I have a Promethean Interactive Board in my classroom that is paired with an Epson 83C projector. The picture that is blurry. How can I focus the picture on the Promethean Board? Thanks!
the light is blerry ,
Pls check the lamp,(if it is bright enough )
check the color if it is correct and brite-colored (if the LCD panels is work well)
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color
wheel,
motherboard, powersupply ... with high quality and competitive price.
Lampdeng Limited
Jerry
Oct 01, 2010 | Epson 5300 7200 7300 Replacement Lamp -...
Epson 7550c projector - ELPLP07 lamp fuse.
Have a nice day!
wheel,
Lampdeng Limited
Jerry
Oct 04, 2009 | Epson 5550c / 7550c Replacement Projector...
How do I reset the Lamp Timer on my Epson Powerlite 5000?
Have you replaced the lamp yet? You should replace the lamp because if you reset it with the old lamp, it could possibly wear out and explode inside the projector. Reset instructions are in the new lamp box.
Jun 10, 2009 | Epson PowerLite 5000 Multimedia Projector
Epson Powerlite 5350- reset lamp timer
5350:reset the lamp timer
1,While simultaneously holding down MENU and Help on the control panel
2,While simultaneously holding down MENU and UP on the control panel
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
Jerry
Lampdeng Limited
Feb 18, 2009 | Epson ELPLP09 Projector Lamp for PowerLite...
Epson elp 7200 projector
check power supply (electricity)in wall outlet by another appliance.
--check for defective power cord-test with another one.
=apply good brand of contact cleaner over power switch.and press it many times.
--check blown power fuse and change it with same rate if it is defective.--if all above did not fix the problem pass it to service center.
Oct 20, 2007 | Epson 5300 7200 7300 Replacement Lamp -...
927 people viewed this question
jasbo
jasbo
