I have an industrial 8.2 kg speedqueen washing machine and the water on completion of wash cycle is not exiting the machine. my machine is a top loader
5E. Water Drain Error. 5E is displayed if the water level frequency detected os 25KHz or less in the initial phase of the UNB - detecting cycle. The WATER DRAIN ERROR can be rectified by turning the POWER SW OFF AND THEN BACK on.
These YOUTUBE video MAY help you!
Here is another YOUTUBE that discusses "Pressure Switches"... and that MAY be your problem. KNOW this is general information and not specific to your Hoover!
Another snip-it:
..."Kg MODE Indicator". On Cotton and Synthetic cycles, during the first 4 minutes of the cycle the intelligent sensor will weigh the laundry and adjust the cycle time, water and electricity consumption accordingly. ...
More: The intelligent KG Mode sensor weighs the laundry and adjusts the cycle time, water and electricity consumption to suit the size of the load. This gives you the optimum consumption even if you are only washing one shirt.
During the first minutes of the cycle, the "Kg MODE" indicator remain on while the intelligent sensor will weigh the laundry
• Through every wash phase "Kg MODE"
allows to monitor information on the wash
load in the drum and in the first minutes
of the wash it:
- adjusts the amount of water required;
- determines the length of the wash cycle;
- controls rinsing according to the type of
fabric selected to be washed it;
- adjusts the rhythm of drum rotation for
the type of fabric being washed;
- recognizes
the presence
of lather,
increasing, if necessary, the amount of
water during rinsing;
- adjusts the spin speed according to the
load, thus avoiding any imbalance.
Your question is not easy to answer. An average washing machine is 8 kg. The smaller 6 kg will use less water and detergent, but you will be limited to 4 or 5 pair of jeans at one time...unless your children are small. A front loading machine may be a better choice for you. It can do very large loads, 12 kg, and still use less water and detergent than most top loaders, but be prepared to pay three times the price of a top loader.
It could be the heater element, if the wash water does not reach the temp selected by you within a certain time period, the w/m could abort the cycle.
The pump or outlet hoses could be blocked and the w/m cannot expel the waste water between rinses.( This would be if the machine stops and is still full of water). Try running a cold wash cycle and this should confirm if it is the element as it will complete the cycle ok.
Hope this help
Hi, The drain hose is either sitting in water with no air gap or the hose is not going up high enough...either way it is causing the water to siphon out of your machine... The hose should go up higher then the highest water level and have an air gap where it goes into the drain pipe or it will not work..
