Question about Samsung HCL4715W 47" Rear Projection Television
Samsung model hcm4216w
Looking for repair manual for my projection tv 42" have a picture but the red is wavey
  • Samsung Master
  • 8,617 Answers
Go to this link they have the manual youre looking for.
http://servicemanuals.vstore.ca/
Posted on Apr 21, 2008
I have a HCM4216W rear projection tv. It was
The convergence IC have gone bad, bad solder connections to IC or probably both. The board as a whole can be purchased as complete (look to the web to find where to get) and is fairly easy to replace. Unless you have extensive experience with component level repair I would suggest you take the board to a TV shop to repair. This option maybe slightly less then replacing board. Check with your local TV repair shop to see which option is the best in your area.
May 06, 2010 | Samsung HCM4215W 42" Rear Projection...
Samsung hcm4216W turned off by itself loops.
Instead of typing model number of your TV (that located on right hand side and on the back of TV) you published here part number of your TV's remote control. LOL.
Anyway... If it is LCD/plasma panel that you talking about - than power supply have bad electrolytic capacitors that have to be replaced. You can recognize 'em by bulged/swollen tops (instead of flat tops of good capacitors).
This repair required soldering skills.
Mar 09, 2010 | Samsung HCM4216W 42" Rear Projection...
Picture shadow on rear projection Sony big screen TV
You have 2 distinct problems that should be addressed separately. Please repost the Samsung problem. I will address the Sony problem here.
If the "shadow" makes the picture seem somewhat of a 3D one, the problem is with the convergence circuit. This could be as simple as bad connections on the pins of the convergence ICs or defective ICs. If you can solder and would like to attempt the repair, update this and I'll provide more details and instructions.
Dan
Sep 25, 2008 | Samsung HCM4216W 42" Rear Projection...
No power; please help
Nicole,
Pull the back off the TV and locate the convergence board. It's up and to the right in the circuit board area and has two large black Ic's mounted on it. Locate the red colored plug to the left front of that board marked +/- 20v and unplug that. Now plug the TV back in and attempt to power it up - - - if it powers on the picture will be really messed up (unwatchable) but that will tell us if it's a convergence failure. This is the most common problem for these units with those symtoms...
Repairing it will be a snap then... Just let me know...
Bill
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
premtech@willapabay.org
Jun 15, 2008 | Samsung HCM4216W 42" Rear Projection...
Picture quality
chances are its the red CRT PCB or the red drive circuit. Go to the following link and leave an email with your model number and indicate your problem they can get the parts you need and supply the tech support so you can install them yourself which will most likely be cheaper than a service call to diagnose the problem. Heres the link.
May 16, 2008 | Samsung HCM4216W 42" Rear Projection...
Red blinking light
It's most likely convergence -- the small board up and to the right inside the back of the TV, which has two large amp Ic's attached to it..
Unplug the +/- 20v line on the fron left corner of that board (red in color) and then try and power on the set... If the set comes on the board needs to be repaired and it's an easy unplug and two screws that mount it inside.
Bill
PO Box 442
LOng Beach, WA. 98631
360-641-4993
Apr 18, 2008 | Samsung HCM4216W 42" Rear Projection...
Studioseries (samsung) 42" rear projection tv red duoble outline of picture
sounds like the red convergence Ic is weak ready to go out. try replacing the ICs around 10.00 do the blue as well as that will be next.
Mar 18, 2008 | Samsung HCM4216W 42" Rear Projection...
SAMSUNG HCM4216W has a verical line
the vertical line has nothing to do with the picture tube,Some component in the horizontal circuit is causing that problem,most likely an electrolytic capacitor
Dec 07, 2007 | Samsung HCM4216W 42" Rear Projection...
TV turns off by itself (not timer issue)
Probable bad green CRT. Also, look for coolant leak from
CRT onto PCB.......T
Oct 24, 2007 | Samsung HCM4216W 42" Rear Projection...
Blue and Yellow doubles
Well, fortunately the television that you purchased has an auto-convergence feature. What is happenning is that your color lamps are misaligned, did it get moved at all recently? Anyway, in your menu you should see a "Convergence" menu, and inside that menu, a section called "Perfect Focus". Run Perfect Focus in this sequence: Green --> Red --> Blue After that your picture should look great, if not try tinkering with the manual adjustments on the "Convergence" menu. Here are some URLs that you might find helpful: (just copy+paste into your browser) Your Television On Samsung's Webstire: http://www.samsung.com/Products/TV/ArchivedTelevisions_2002/HCM4216WXXAA.asp Your Television's User Manual (Download And Open With Adobe PDF Reader) (The "Convergence" Menu Is Section 3.3) http://www.usersmanualguide.com/samsung/tv__projection/hcm4216w
Apr 29, 2007 | Samsung HCM4216W 42" Rear Projection...
Samsung HCL4715W 47" Rear Projection Television Logo
69 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
