Question about Mitsubishi WS-55805 55" Rear Projection Television
Screen goes black
I've got a Mitsubishi WS-55805. This week the picture started going black as if the TV was off. If I turn off the TV and wait a minute, then turn the TV back on, the picture will return. So far this only happens once, maybe twice a day. Any thoughts?
  • 8 more comments
  • mcravenufo Apr 17, 2008
    Thanks. I might be able to look tonight and get back tomorrow.
  • Guwanna G Apr 17, 2008
    My problem was sudden, without warning. No picture problems, then one day no picture at all. The kids were playing Wii and the screen went black. I haven't been able to get the picture back. Tried suggestion and I do not see any sign of coolant spill. Any other suggestions?
    I removed the speaker grill and board behind it to look for coolant drops. The television was working when I looked and I didn't see any coolant drops.
    You say this could cause intermittent problems. I had a different problem occur on this tv a couple of months ago that seemed to clear up. The top 6 inches of the picture would distort and almost look like a curved bent picture. It would flicker like this for a while and then the picture would return to normal. That has not happened for quite a while. I am now dealing with this black screen issue.
  • danmoore88 May 05, 2008
    My screen on the WS-55805 goes black as well after usage for some time - but the sound remains. When the TV is turned off usually for a 5-10 minutes, the screen will come back on. For a while it would run for days before the problem would occur again, Now it is happening more frequently. Has anyone determined the reasin for this problem, and what is required to fix it?
  • kjphotog77 Jul 03, 2008
    my problem is similar, but is preceeded by a single vertical line down the center. then several lines and static that gradually gets worse. occasionally the picture will just cut out. It comes back after being turned off 5-6 minutes, but after maybe 10 minutes of play, it starts again.
    I've heard about coolant drips, didn't see any. Also the hard restart, taking power off for couple hours and trying it again. That seemed to  work for a while, but problem is not solved. ANY IDEAS would help. I'm not planning to fix myself, but would at least try to narrow down problem for tech that will have to come out.
  • TraderGordo Aug 14, 2008
    WOW - anyone figure this out yet? My problem was sudden also, no problems from this TV for almost 9 years, then last night without warning the picture completely disappears but there is still sound. I tried changing inputs, turning it off/on, unplugging, nothing helped. Like the previous guy said, I had no picture problems leading up to this, screen just went black while watching.
  • ckpi Nov 07, 2008
    I have a Mitsubishi WS 55805 which also has the problem with the screen going black, for a few months the picture started changing colors, then the scree would go black but the picture was on, I could turn the tv off and after a couple of minutes turn it back on and the picture would be back. Now the picture goes black after an hour or two of viewing and I have to leave it off 30 mins or so before I turn it back on and the picture will be back.
  • tmac3 Dec 04, 2008
    I have removed the grill and rectangluar board.
    What does the coolant look like and what do I do to keep the coolant off of the pcb?
  • aftershock83 Mar 25, 2009
    I was watching a movie the other day and then the picture just went out but there was still sound. I checked for coolant didnt see anywhere. Don't even see where there is coolant? Is there any other solution?
  • jkndrs Apr 17, 2009
    screen goes black can shut off tv for about 30 minutrs and turn back on and picture reapears
  • 116 Answers
If you are willing, remove the speaker grill and the rectangular board behind that and look very, very carefully underneath each of the three picture tubes for evidence of coolant drops on the printed circuit boards. These sets have been known to spill a few drops of coolant onto the boards and this causes intermittent problems such as yours. This is my first direction in your case. Let me know.
Posted on Apr 17, 2008
ONLY HD picture does not fit on WS-55805
To be kind you are wasting your time, This is a 1st generation HD set not designed for the modern equipment you are using---You cannot turn a Model A Ford into a Roll Royce.
I has only one HD input designed for a set top HD box providing it a 1080 I signal.
Dec 04, 2012 | Mitsubishi WS-55805 55" Rear Projection...
Mitsubishi WS 55805 nothing but blue screen and black square in middle
A full service manual is available online---I will presume you tried to unplug it for a while and then power back to see if will reset itself.
This set has three hidden menus---one is the OPTION menu--in that menu with the Mitsubishi remote you can do a hard reset of the entire set= sets all back to factory except convergence adjustments which are stored in another area--cures all kinds of oddball issues.
I can give you a link to the manual and the page numbers for the OPTION menu.
Note: the other two hidden menus are Convergence and adjustment--do not go into adjustment menu as one wrong move and poof!
SD TECH
Apr 20, 2012 | Mitsubishi WS-55805 55" Rear Projection...
I've had my Mistsubishi 55"
The main board has an issue which has most likely blown a fuse. Those boards have been discontinued so repairing that one will be at least a couple hundred depending on the shop doing it.Or yo umay be ble to locate a used one on ebay .
Jun 24, 2011 | Mitsubishi WS-55805 55" Rear Projection...
On certain channels, a black box apears, like picture in picture. will go away if i turn up the volume, but comes back,
You have some how turned on the closed caption (cc) either on the TV or cable box,first go into tv's menu under closed caption and select off,that should take care of it,if not try the cable box.
Mar 21, 2010 | Mitsubishi WS-55805 55" Rear Projection...
Mitsubishi WS-55805 CRT projection TV with
This problem is most likely caused by damage in the convergence output amp IC's; this model uses STK392-040. Fairly common for various fuses that protect the DC supplies for these amp IC's to open as well.
Mar 03, 2010 | Televison & Video
Picture Problem
i have the same problem. what was you solution? did you get it fixed?
Dec 24, 2007 | Mitsubishi WS-55805 55" Rear Projection...
Blurry Image problem with Mitsubishi WS-55805
Hello, if you want I can supply you with the service manual, please leave your email. Best regards, Arpi
Aug 14, 2007 | Mitsubishi WS-55805 55" Rear Projection...
Won't turn on - green light blinks
Call a repair shop there's nothing you are goeing to be able to do to a Mitsubishi Pro Jo Good Luck Walter Grzybowski
Sep 25, 2006 | Mitsubishi WS-55805 55" Rear Projection...
Mitsubishi WS-55805 55" Rear Projection Television Logo
285 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
