Question about Archos Clipper MP3 Player
When i try to play my music it seems to play a tune then stops and just bleeps even though i have hade it on charge for 24 hours and some times it will play more then one tune but nevre has go on for more then 10- 15 minuies
    New Friend:
  • 8 Answers
That means the problem is internal, what you can do is save your music onto your hard drive and then format the player and copy back your songs
tom
IT SUPPORT
Posted on Jul 01, 2010
Testimonial: "Thanks for that. I did however get in touch with archos and they basicly said the samme thing,as i said to the guy i was not that good on computors any way tried it on my tower pc from windows works a dream as you say it must be formated differant on my lap top. hay ho you learn somthing new every day. cheers"
    New Friend:
I had this same problem; the Clipper can only play files that are mp3 or wma which I had thought mine all were but on closer inspection I discovered a few were mp4. Once I ensured the correct format of all the files the player worked without issue.
Posted on Feb 05, 2011
    New Friend:
  • played some tunes one day i carnt get them the next day ?
Posted on Sep 26, 2010
SOURCE:
Why does my casio p-45 piano only play one demo song? There are 16 available. I followed the instructions in the manual. Any ideas...?
Well friend,
According to page 24 of the manual here http://support.casio.com/pdf/008/ap_45_e.pdf
It says
Demo tunes
While holding down the MUSIC LIBRARY button,
press the PLAY/STOP button
.....and try to play a specific demo tune ........
After playback starts, press the tone button that
corresponds to the tune you want to play.from the list.
ALSO in the Troubleshooting section page 35 For DEMO tunes UNPLUG HEADPHONES
If it doesn't work, then you need to get a Technician to look at it.
Sep 18, 2014 | Music
My Samsung ES63 camera won't turn on even though it's fully charged. It makes a weird bleep instead.
did the camera sustain any drops or water damage?
if not then i would recommend to take it back to the manufacturer and request a refound for the defective equipment.
Jan 31, 2012 | Samsung DigiMax Cameras
Hi My wife and I have just bought 2 Archos 2GB
MP3 players can only play music files in mp3 file format.
You need to convert your CDs to mp3 music files onto your computer or download them from the Internet and then copy them to your MP3 player using the supplied USB cable when you connect the MP3 player to the computer.
Click on this link for instruction on converting music files to mp3 file format :-
http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
Feb 13, 2011 | Archos Clipper MP3 Player
No music just bleeping
If your mp3 is not playing any music and just beeping, first you need to be sure that it is well charged. Then you connect it to a computer, open the file to view folder once the mp3 driver opens its auto run, then you format the mp3 and copy new songs to it. Then you safely remove the hardware from its generic connection then you try to play your music. This time it will play perfectly fine.
Hope this information helped you. thank you for using fixya.
Jan 21, 2011 | Archos Clipper MP3 Player
Wont charge properly, music only last 5 minutes or so
Hello there :)
Try to chance the battery and see if it helps or read this site :
http://rubensmenswear.com/pages/photographs/oakley/mp3/oakley%20thump%20faqs.htm
The write on the site :
5. I'm sure my THUMP is fully charged, so why doesn't it play music?
  • Make sure the volume is not set too low to hear.
  • Make sure there are song files stored on THUMP. Connect THUMP to your computer and open the folder that shows the contents of the THUMP memory
  • Make sure you have the correct music file formats loaded into the THUMP memory. Currently, THUMP plays MP3, WMA and WAV file formats. No other music file formats are supported at this time.
  • Make sure the WMA music files you are trying to play are not protected by DRM. (See below for more information on DRM.) If the song files are protected by DRM, you need to download the DRM Enabled Utility found at www.oakley.com/thump.
6. Why can't I get a full six hours of song play time out of THUMP?
  • Many things affect play time, including the volume level, file compression and music file format. Also, lithium ion polymer batteries gradually lose their charge while not in use. These batteries are also susceptible to temperature.
  • Even though they represent the best technology available, lithium ion batteries do not perform best in high heat.
7. Is it best to completely drain the THUMP battery before recharging?
  • It makes no difference. Lithium ion batteries have no "memory effect" like older technologies such as nickel cadmium, so you can charge them at any time - even when they are not fully discharged.
Hope thats helps
If not then try to return here
Please rate my answer :)
Jun 10, 2010 | Oakley Thump MP3 Player
LG Viewty battery discharges quickly .....
Charging duration does not connect to battery lasting duration in any way.Optimal charging time is 3 to 4 hours.your battery will drain soon if you keep your touchscreen pressed continuously in your jeans pocket.Keep bluetooth switched off. Reduce the brightness of your mobile display. Play music threw headphone rather than using loudspeakers.
Jul 19, 2009 | LG KU990 Viewty
My iDog Portable won't play music!
try holding down his/her tail she/he may growl but then she/he will stop barking, it works on mine! :)
Feb 20, 2009 | Hasbro I-DOG AMP'D
Nokia Supernova 7610
are you connected to to the computer by pc suite. If so try deleting the tunes via nokia phone browser in my computer. if you once played the tunes and closed them in between the music player remembers that and every time you touch the music player key on the right side the tunes may start even in silent mode.Check the music player if one of the tunes is still in the playing menu. Once listen to the tunes completely and then close the music player. Removing them from the playlist may also help.
Jan 12, 2009 | Nokia 7610
Doesnt play music
See this "ticking sound" thread; probably the same issue.
Aug 28, 2008 | Bose SoundDock Digital Music System for...
I cannot charge it (USB car charger) and listen to the music at the same time
don't think it's possible. -when you charge and play via your laptop, the player is acting as a USB key and the laptop is doing the playing. -when you charge it via your in-car port you do not have a 2nd device on which to play tunes. it's either charge or play i'm afraid
May 22, 2007 | Samsung YP-U2X Digital Media Player
Archos Clipper MP3 Player Logo
547 people viewed this question
Top Archos Audio Players & Recorders Experts
Marvin
Marvin
 Grubhead
Grubhead
Harrie
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
