Question about Breville CBL10 BlendMaster Classic Work Top Blender
Received the Breville Ikon 600 blender as a Christmas present in 2006 and have used it 3 times, with the third time being this past weekend. The product is now out of warranty and low and behold, it stopped working as I was trying to use it. I started blending and within one to two seconds, it just stopped and will not turn on. The LCD panel will not light up and none of the buttons work! Is there any kind of troubleshooting that I can do to solve the problem? This blender was recommended as the BEST and it was quite expensive. I am extremely disappointed with the short life that I got from this blender!
  • 3 more comments
  • Anonymous May 19, 2008
    exactly the same problem...1 month out of warranty.
    I have receipt. I expect a blender that cost $229 would be of better quality.
  • Anonymous Sep 27, 2008
    Yep same thing happens. When I try to blend it turns off after a second or two. Not impressed Breville. This was supposed to be your top of the range blender. If there is a reset button on the base, well I can't seem to find it. Looks like i'm going to have to get it repaired as it's also out of warranty. It's as they have almost planned it.
  • theeaglenest Jan 24, 2009
    Same thing... what the heck do i do...?
  • Anonymous Feb 17, 2009
    Same thing happened to me this morning. I've only had this blender for two months so it should still be under warranty I think...
  • Anonymous Feb 19, 2009
    I also have the same problem, just past warranty, sometimes works but then other times turns itself off after 2 seconds, even tried it with just water and same thing. Can't find any reset button.
My IKON 600 Blender fuse had blown. It was located on the circuit board and can be found by removing the bottom of the blender. Fuse is Fast Blow 10A, metric 5mmx20mm. The fuse blew because the bearing in the bse of the jar froze. Bearing # 608-RS. The beraring froze because the seal in the base of the jar was leaking. Solution: Clean seak surfaces, replace bearing and fuse. Total cost of $6 with my labor.
Posted on Feb 11, 2010
The fuse button of the blender may have been triggered, try look at the bottom of the blender to see if there there is a hidden button like "reset" and press it, then connect the blender to the electric outlet again...
Posted on Jun 11, 2008
I have a Breville 800BLXL/B blender that won't power on. When plugged in, the power button will not illuminate.
Most likely its the large yellow capacitor on the main circuit board. I've had this fail on my Breville coffee machine and blender.The coffee machine was a 1.5uf capicitor nd the blender 1.0uf.rated at 275vac. what happens is over the years of power spikes and surges etc the capacitor breaks down to a lesser value than its original "capacity. ie 1uf down to 0.3uf it provides enough power to drive the display electronics But not enough to power the relay to turn the motor on.
. there are 3 screws under the label. Peel off the label . remove the 3 screw. remove the fan cover.
to remove the fan . hold on to the blender jar mounting drive and unscrew the fan. a small square nut is what holds the fan on. remove the rubber feet an the 4 star screws under the rubber feet.
you can then remove the base.
Most likely the fuse is OK. However I've found ( in repairing mine) the big yellow capacitor 1uf 275vac is at fault. over time and power surges it breaks down and cannot pass enough "power:" for the power supply to call the relay to turn on the motor. You van get a new capacitor from Jaycar ( aus or NZ ) for about $6.00 . unsolder the capacitor and solder a new one in. reassembly is reverse. Just be careful not to trap the micro swicth wires ( black) under the motor surround.
Jan 21, 2017 | Breville Blenders
I have a breville kinetic blender - not used for a while. Gives a nasty burning smell when used. Anything I can do?
Unless it is food stuck around the blender bottom , you have parts burning up inside. Its not safe to use. Check to make sure it is clean top an bottom if smell returns stop using. Could burn house down.
Jan 29, 2015 | Breville Blenders
MY BREVILLE bcs500xl hand blender will not keep a charge
Hello, chef
I was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about blenders andpossibly yours, from
repair to trouble shooting it. http://home.howstuffworks.com/how-to-repair-small-appliances5.htm
Please if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Sep 26, 2011 | Breville BCS500XL Single-Speed Handheld...
My breville blender model#bbl600xl leaks every time I put liquid in it, the gasket is in place and it is tightened as much as possible, what is the problem.
It leaks if you over tighten it. So try to just do it finger tight. I was having the same problem, once I eased off on the tighten if stop leaking. I assume you are getting it correctly aligned as that can be the other issue.
May 14, 2011 | Breville BBL600XL. 5-Speed Blender
Breville blender won't turn on. The on light is flashing red instead of solid blue. Worked fine a few days ago.
FIXED IT - It's the screws on the bottom of the jar assembly, where the blades are attached. There are 4 Torx screws - star-shaped - and when these come loose over time the Blender will start to operate only sometimes. Eventually it will be never.
Tighten these four screws and everything will be fine!
Oct 02, 2010 | Breville BBL600XL. 5-Speed Blender
I need to acquire a glass jug for a breville BLR-3 Blender. Any suggestions would be appreciated !! Thanks
Hello. The best route to go is to work directly with the manufacturer. here is their contact info
  • AskUs@BrevilleUSA.com
  • 1.866.BREVILLE (1.866.273.8455)
  • 8a to 5p Pacific Time
  • Mar 22, 2010 | Breville CBL10 BlendMaster Classic Work...
    Breville Blender
    I need the blend jar for Breville Blender electronic Model BL3. I did not notice that a stainless steel spoon was in the blender. When I switched it on the crossed blade broke off.
    Oct 15, 2009 | Breville ikon Hemisphere Blender - Silver
    The power switch lights up ok, then if I try to use any speed or Pulse the blender runs for approx. 2-3 seconds, then the power cuts out. How can I dismantle the unit to check the problem.
    I have the same problem. 4 of the screws underneath are star-shaped and you will need the appropriate screwdriver for it. I purchased a "set" with heaps to choose from. The other 6 or so are normal. Don't forget to remove the rubber feet and get to the screws under there, too.
    Hope that helps! I've had mine apart 3 times trying to fix this problem. Hint: It's probably not the power cord - I tried that already. If you figure it out, let me know, because I'd love to fix mine!
    Aug 08, 2009 | Breville BBL550XL 5-Speed Blender
    Jack La Lanne's Health Master 100
    First determine..if it is indeed the motor that is fried. Do this by not using the caraffe. Plug in the motor and run it by itself. If it runs fine without smoking again..It is the caraffe that is defective.
    If its the motor you are out of luck completely. Jack Lalanne is out of business.
    If it is the caraffe..which I suspect it is not...oil the rim of the bearing that is on the outside of your caraffe ..it surrounds the knurled part that is inserted into the blender...even if you are able to get the motor repaired..get in the habit of oiling the caraffe bearing after each time you use it. If you dont it will fail within months to a year of use
    Lalanne had they made in China..and using unsealed bearinga that rust out and the contents of the blender come out!! So I discovere dthat oiling that part each time after use..keeps my blender running smoothly.
    You might want to take yoru motor to a small appliance repairman..he might find something simple happened.. like a loose wire connection inside! If he does...you have a simple solution and a motor that works!
    Remember to oil the bearing a couple drops each time after use...and if yoru caraffe ever fails you can buy a new one..( Oil that one too!) at Cooking Toys..you can google for the address
    gmcgeary@gmail.com
    Jan 06, 2009 | Jack Lalanne Health Master 100 Blender...
    Breville CBL10 BlendMaster Classic Work Top Blender Logo
    1,037 people viewed this question
    Top Breville Blenders Experts
    Mike
    Joseph Hoffmann
    Are you a Breville Blender Expert? Answer questions, earn points and help others
