Question about Dryers
Whirlpool clothes dryer, model ler5636eq0, does not go through the full cycle before stopping. it will restart, and then quit again. I have have had the thermal units tested in the vent and heating element container. any ideas?
    Problem Solver:
  • 5 Answers
Use an amp meter check the amp draw of the motor if in check its possible the overload is bad since i couldn't buy a replacement overload i removed mine after seeing amp draw was fine. But i never use my dryer unless i am home and i would not recommend this to just anyone. also if the idler wheels are not moving free or anything is causing excess drag on the drum this will also cause the problem and blow out all lint with an air hose or canned air.
Posted on Jan 08, 2010
    Genius:
  • 1,073 Answers
Motor overload seeing high temp in the motor, replace the motor
Posted on Apr 16, 2008
Started a quick was cycle to test washer without cloths. It agitates for about 10 seconds, stops for 5 seconds and agitates for 10 seconds again. The light array is suggesting it is going from wash.
new washers usualy start a brief agitate then locks the door and then starts watering again. depending on washer model it can do this a couple times to evenly soak the clothes at the start of a wash cycle. it is advised to not run full cycle in the washing machine with no clothes for it can damage the unit.
Jul 07, 2016 | Whirlpool Compact Stackable Front-Load...
How do you dry clothes in this machine please
A fairly common problem! The official instructions are
Before using your dryer, wipe the dryer drum with a damp cloth to
remove dust from storing and shipping.
1. Load clothes loosely into the dryer and close the door. Do not
pack the dryer. Allow space for clothes to tumble freely.
2. Turn the Cycle Control knob to the recommended cycle for the type of load being dried. Use the Energy Preferred Automatic Setting (,) to dry most heavyweight and medium weight loads. See "Drying, Cycle, and Temperature Tips."
3. Select a temperature setting on models with a Temp/Fabric selector. The cycle descriptions include temperature setting suggestions.
4. Push the START button.
Stopping and Restarting
You can stop your dryer any time during a cycle.
To stop your dryer
Open the dryer door or turn the Cycle Control knob to OFE
NOTE: The Cycle Control knob should point to an Off area when
the dryer is not in use.
To restart your dryer
1. Close the door.
2. Select a new cycle and temperature (if desired).
3. Press START
Extracted from
http://www.manualslib.com/manual/511763/Whirlpool-Lte5243dq.html?page=10#manual
Nov 14, 2015 | Whirlpool AWZ410 Front Load Washer/Dryer
We have an estate by whirlpool dryer that quit working. During last cycle it made a loud bang noise that ended the dry cycle and the clothes inside were dry. When we tried to restart it, it wouldn't...
The fuse is tied into the door switch circuit and looks like this:
Unplug the dryer and remove the rear cover. All the heater components is back there.
Service manual and more info are HERE at my FixYa tip.
Jul 17, 2011 | Estate TEDX640JQ Electric Dryer
My dryer is a whirlpool electric dryer that was brand new in 1998. The dryer was on, working fine...suddenly it just stopped. It was making a clicking noise. It refused to cut back on when I pushed the...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 27, 2011 | Whirlpool GEW9250 Electric Dryer
Whirlpool washer periodically will stop mid wash cycle. And won't restart until hours later. Seems to only happen when I need to do lots of laundry what is going on
THIS IS A BALANCE PROBLEM, IF YOU ARE PUTTING A LOT OF CLOTHES IN AT ONE TIME, YOU WILL HAVE TO BALANCE THE CLOTHES WHEN IT STOPS, DONT OVERLOAD IT, AND MAKE SURE YOU ARE EVENING THE CLOTHES OUT IN WASHER ESPECIALLY BLUEJEANS AND HEAVY THINGS, I KNOW MY WIFE DOES THIS HA, TRY THIS AND LET ME KNOW THKS LARRY
Apr 26, 2010 | Whirlpool Kenmore 5.9 cu. ft. Extra-Large...
Clothes dryer drum stops turning during drying cycle
your motor is going out , it doesn't have wenough to keep going.
Jun 26, 2009 | Dryers
Dryer overheats, stops mid-cycle
Hi, Will the dryer restart right away? Sounds like a motor going bad. With a model #, I can get you part#s if you need them. Is this a whirlpool brand?
Let me know if I can assist you further.
Thanks
Vic
May 17, 2009 | Dryers
Whirlpool Thin Twin WET3300SQ (water stops coming in)
  • We are sorry to hear of the problem with your Whirlpool washer. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Digital@Whirlpool.com with your name, phone number, address and the model and serial number for your washer.
Apr 07, 2017 | Whirlpool LTE6234D Top Load Stacked...
Water fills the washer during spin cycle
defective timer...a model # should be under the lid...or open dryer door and on front dryer panel right hand corner..onthejob
Jan 16, 2009 | Whirlpool LTE5243D Top Load Stacked...
Clothes Dryer will not stop or be quiet
On some Kenmore which is made by whirlpool, there is a resistor connected to the timer control. when the machine is off can you listen to the timer switch and hear it running, making a clock ticking sound? If so, you need a new resistor. Being a dryer, when you open the door and it stops the button needs to be reset before it starts again, right? So I wouldnt be looking at the door switch as much as the start button. It may be the evil one.
Dec 23, 2007 | Kenmore 63942 Dryer
Dryers Logo
242 people viewed this question
Top Dryers Experts
