Zone 2 Can't Handle a Digital Input ? ! ? ! ?
Finally got around to hooking up (outdoor) speakers to Zone 2 on my Onkyo SR604 Receiver the other night and found there was no output for sources other than the Tuner. I found nothing in the Owners Manual that would have led me to believe that Zone 2 can only handle Analog inputs. Both my CD/DVD Player and my Satelite Box (through which I get XM Radio) are hooked to the Receiver via HDMI cables.
What options do I have to get XM or CD music on the outside speakers?
  • 2 more comments
  • T G OnkyoQ Apr 20, 2008
    I have the same issue with an Onkyo TX-SR601. Page 60 of the manual has a statement in the Notes section:
    "The ZONE 2 terminal is an analog output. Digital signals are
    not output. If no sound is heard from the selected input source,
    check if the component is connected to the analog inputs."
    I currently use optical cables for the digital signal from HD DVR and DVD . Can I run a set of RCA jumper cables also from those two sources so I can get analog to Zone2, or will the receiver only accept either the Digital OR the Analog signal?
    If the latter, can I run RCA jumper cables from the HD DVR and the DVD to different input sources on the receiver (for example, HD DVR into L/R analog inputs for Video 1 and DVD into L/R inputs for CD)?
  • JHackett75 May 06, 2008
    TG
    I did solve my problem by adding RCA cables from my Satelite Box and from my CD/DVD player to the Onkyo AV Receiver, and plugging them into different audio inputs. So that it looks like this:
    Sattelite Box --> Receiver [Video 1] HDMI cable: used for Zone 1 enjoyment of TV and Sattelite Radio
    Sattelite Box --> Receiver [Video 2] RCA cables: used for Zone 2 enjoyment of Sattelite Radio
    DVD/CD Player --> Receiver [DVD] HDMI cable: used for Zone 1 enjoyment of DVDs and CDs
    DVD/CD Player --> Receiver [CD] RCA cables: used for Zone 2 enjoyment of CDs
  • falcon86 Dec 21, 2008
    I'm having the same problem. Very frustrating. This industry takes 2 steps back for every step forward. My old Pioneer was able to send digital input to Zone 2. But now with HDMI inputs everything has changed? Ridiculous.
    The solutions offered here won't work with a PS3 since that analog output must be switched in the sound menu. It is a either/or proposition. You can't have both digital and analog output at the same time.
  • shaqfu Jan 28, 2009
    I had the same problem and this worked. I have a question though. When you have the RCA cable connected from the CBL/SAT to the receiver, does the audio still pass through the HDMI for Zone 1? I ask because once I disconnected the RCA cables after turning zone 2 off, the sound for zone 1 was not working. Hope this makes sense.
It is very frustrating... I just have discovered today. I can't solve this because my Itunes mac is only digital audio output, I can share its sound to Zone 2..
Posted on Dec 26, 2010
Pioneer VSX 1020K - Zone 2 Setup
I referred to a similar zone 2 arrangement for a Yamaha receiver. It shows a separate amplifier and notes that only analog signals are sent to zone 2. The analog output from a source must be connected to the analog input on your Pioneer unit for zone 2 to work. Your outdoor music environment will be limited to left and right front speakers and...alas...no surround
Jun 03, 2013 | Pioneer VSX1020K Receiver
Onkyo tx-sr604 help
You said you tried hooking the HDMI up directly from the TV to each component, and that worked. How is it usually hooked up - through some kind of switch? I'm not completely understanding your setup here.
Aug 10, 2007 | Onkyo TX-SR604 Receiver
I recently moved and just got my outdoor speakers hooked up. When I turn on Zone 2, I get sound from my Ipod, but when I set Zone 2 to have music play from my satellite box, I get nothing. The music will...
If your satellite box is connected using a digital cable to the 601 receiver you won't get any sound through zone 2.Zone 2 can process only analogue sound ( inputs ).
Jul 06, 2011 | Onkyo TX-SR601 Receiver
Can i connect 2 sub woofers to my onkyo receiver model tx-sr604 ,and if so how. and is bi wiring of front 2 speakears and surround 2 speakears any good iam using polk audios tsi300 as both front and...
You can hook as many subs as you like since the Onkyo only provides the Pre-Out Line Level to the amp(s) that drive it (them). I run two myself.
Bi-wiring is a personal choice and some swear by it while some of us swear at it in a modern home environment. The premise of bi-wiring is that your amps or crossover networks **** to start with so you have to do all this work-around.
My $.02 is you add complexity, waste speaker wire (which can be expensive if you subscribe to the theory that wire can change the sound other than at the cash register, but don't get me started on that), amplifier resources, and MAYBE you'll think you hear an improvement. Perhaps if you lived in an anechoic labratory you might. I think it's a crock.
http://www.brilliancehifi.co.uk/how-to-bi-wire-speakers.htm
If you look at the second diagram you'll notice the fundamental electrical circuitry of the speaker wire is essentially unchanged except you now have twice as much speaker wire. The same amplifier output posts still feed the same speaker input posts. How can this be electrically different?
You'll rarely find anyone who can produce a measured audible difference with any of the snake-oil schemes to get into your wallet. It's always flowery prose and faith.
Aug 11, 2010 | Onkyo TX-SR604 Receiver
Hi, this is not really a problem. I have an Onkyo TX-SR604 receiver. I had polkaudio speakers RTi8 speakers that are no longer working properly. I am looking for recommendations for new speakers that can...
A receiver with the specs...
* "90 watts minimum continuous power per channel, 8 ohm loads, 2 channels driven from 20 Hz to 20 kHz, with a maximum total harmonic distortion of 0.08%"
(*) The only acceptable statement of its power bandwidth in the manual.
... when fed an undistorted audio signal, used properly and not driven abto clipping is not particularly dangerous to any reputable speaker.
Driving any amplifier, even a modest one, into high distortion is more dangerous to any speaker than a high-powered amp pumping pure undistorted power.
Choose any speakers but low efficiency models if you want loud and clean sound.
Jun 10, 2010 | Onkyo TX-SR604 Receiver
I have a Onkyo TX-SR604 Receiver. I get no sound
Hello Fixya customer,
Thank you for your question.
A point to keep in mind here is that Zone II will only feed through an analog source. Since the Video 1 input is using the digital (coax, optical) input that that is your most likely issue.
Thank you for using Fixya, and please let me know if I can firther assist.
May 01, 2010 | Onkyo Audio Players & Recorders
Zone 2 audio output is for analog only? The only reason I bought this receiver was to be able to play my ipod on our outdoor speakers.
David is wrong. My Onkyo is the same way. The receiver will only provide a signal to zone 2 speaker outputs from analog sources. I assume this was because of concerns with digital rights management, which caused some odd decisions for a while by hardware manufacturers. Newer receivers should not have this problem.
Apr 26, 2010 | Onkyo TX-SR606 Receiver
Zone 2 on Onkyo TX SR805 inoperable
HI pull down the flap on your amp and you will see buttons for zone 2 settings,press zone2 then level up this should work.
hope this helps .
CABLE GUY.
Aug 03, 2008 | Onkyo TX-SR803 Receiver
No zone 2 sound coming from yamaha amp rx-v861
Had same problem. A and B speakers are basically connected together, and there is no way to get the same volume out of each speaker. This is not a multi-source receiver like Onkyo. Zone 2 needs to go to a seperate amplifier and select teh correct source on the fornt,
Jun 29, 2008 | Yamaha RX-V995 Receiver
No sound from receiver TX-SR604
Make sure that the zone 2 audio source is not digital
Dec 16, 2007 | Onkyo TX-SR604 Receiver
1,766 people viewed this question
 Grubhead
Grubhead
