Hello, I have a 1996 Sony rear projection TV and just recently the set will shut off on it's own. If you try and turn the set back on you have to hit the power button "on the set" twice before it will turn on again. The red "stand by" light turns on and then the set will take numerous tries for it to actually stay on. It will just keep shutting off repeatedly unless you wait for a while. Then even if you wait a while it only stays on for two min. or so before it shuts off again. Somedays though it will work just fine. Could this be a simple fix? Something like a relay or a fan is going out and something is getting too warm and shutting off? The model no. on my set is KP-46S25. I know this is an old set but I just had a child and would prefer not spending what it would cost to replace this set, thank you in advance for any help.
  • panelbeater Apr 17, 2008
    Thank you for such a quick response. No I don't think I've seen either of those problems "yet". If this were the problem how would I go about checking to see if any welds were loose? Is there any dangerous areas to avoid if I open the box? Last but not least are these bulbs expensive to replace? Can I do the installation myself?
  • 116 Answers
These sets have had picture tube problems. Have you ever seen the color change, or lines across the picture before it shuts down? If you have, then you have one or more picture tubes going bad. These pic tubes have been known to have loose welds in the gun assembly. Let me know.
Posted on Apr 17, 2008
  • Paul Buscema Apr 17, 2008
    To check the tubes, remove the front speaker grill. Most of these sets had a small screw at the bottom of the left and right side of the grill to remove. Then remove the access panel. With the set running, carefully tap the neck of each tube to see if the picture has lines or changes color. Tap just above the picture tube socket printed circuit board. If you see any change, that picture tube is bad.
Stuck in video1 and video 6 mode. Can't get to tv
ok, all sony sets for the last 20 years or so have had a reset feature that ought to clear this up:
Set turned off and using Sony original remote:
Display, 5, volume up, power-----listen carefully this should take you to the tech menu.
hit 8 and reset should appear on the screen in red
hit enter and the reset should turn to green and set shut off.
Turn back on and see if it cured the issue or not.
Dec 22, 2012 | Sony Grand Wega Kds-60a2000 60-inch Sxrd...
Sony KP-46WT510 Rear Projector TN
Try to hard reset the TV that is Unplugg the device for 30 mins or an hour and then connect it back..It will help you essentially..!..Thank you..
Please post back on how things turned or for further assistance..!..
Regards!!..
Jul 23, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Sony kp 51hw40 rear projector turn off problem .
T8005 etc is NOT the issue.
This set was prone to bad picture tubes (has 3) and can flash bright blue (most common) and set when this happens detects too much current being drawn and shuts down.
There is a fairly easy way to try to deal with this and return set operation to fairly normal.
Not technical and no parts are needed.
Let me know if you want to know with a comment here and I will explain.
Apr 17, 2012 | Sony KP-51HW40 51" Rear Projection...
TV Turns Off On Its Own
Standby light flashing is error sign and shows tv got problem some where in its circuit boards.
You will notice 3 seconds long pause between red standby light flashing so count pause to pause and post how many times it flashing to diagnose problem of tv.
Thanks.
Jul 01, 2010 | Sony KP-65WS500 65" Rear Projection...
Got picture, no audio, checked all menu audio connections on Sony
Is there a speaker switch in the back, and if so check to see if it is set to internal.
Nov 10, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Problem for Sony Grand WEGA KDF-55WF655. Hello,
5 times Red LED blinks means Lamp Driver Error. (KDF-55WF655)
2 possible reasons, either Lamp is gone or Ballast Supply got bad.
Replace lamp first, in most cases it solved the problem.
How old is this TV and did you replaced lamp recently?
Thanks.
Oct 21, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
TV flashes blue and then shuts off!!
this is most likely a short in the screen grid of the crt open the front lower under speaker cover and adjust the blue screen control .. turn it down with tv on might solve the problem
Mar 02, 2009 | Sony KP-57WS500 57" Rear Projection...
50" Sony rear projection only 2 years old, will not curn on..
Your Fan could be bad, pull back off watch when you turn set on if fan stops running lamp and set will not come on. I had set that fan would sometimes run for all day then set would go back to not turning on. finally would not come on at all It was fan going bad.
Dec 20, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
RCA Projection TV
ok lets begin... shut off? ...is the set staying off. NO POwer at all.. does the set try to come on. does the set have a blinking led on front. have you tried unpluging then waiting 30 min then trying to turn it on again.. this set has a processor and when it detectect any fault will shut the set down
Mar 03, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
1996 sony projection tv model kp46s17
does the tv realy shut off or does the pic go away sounds like bad tube
Nov 03, 2007 | Sony KP-61V75 61" Rear Projection...
Televison & Video Logo
104 people viewed this question
Top Televison & Video Experts
