Question about Toshiba 65H81 65" Rear Projection Television
Power led blinking
Willtab,
I have this toshiba 65h81 and the power light keeps blinking. This is happened the second time. First time I have replaced a couple of fuses on power board and I was ok for a year. But this time was no go.
Would you suggest the convergence ic's? What would be the part #
many tanks
nic
  • laucalin May 01, 2008
    Thanks, willtab, I'll check them again. I had replaced the old ones with '180' s
    Genius:
  • 1,030 Answers
Possible.. convergence ic can cause this problem if they become shorted
Posted on Apr 28, 2008
Red light blinking
google to see several posts on projection tv red light blinking from several different manufactures (sony; toshiba; samsung; philips; you name it) and several models.
http://www.avsforum.com/forum/63-rear-projection-units/975795-toshiba-65h81-went-black-blinking-red-light-help.html
Apr 16, 2016 | Televison & Video
I have a toshiba 42HL167. Love it but recently when the power is off iget a repeating blinking yellow light. Blinks 3 times pauses blinks 3 time pauses blinks either 2 or 3 times then stops for 25 seconds...
Yes. The Yellow LED blinking 3 times is a normal boot-up, but if it keeps doing it -- it needs the firmware "update" (which is more like a reload because it got corrupted.) The problem is, no one talks about how to do that. (there is a PDF and firmware on toshiba's website, but it lacks some crucial details.)
My friend gave me his 42HL167 after this problem started after a power event during a storm and I managed to fix it by reloading the firmware.
I posted instructions on my website at:
http://www.benjammin.net/www/pages/techtips/Toshiba-Regza-42HL167.html
Once I figured out some of the facts, it was a breeze...
Nov 06, 2009 | Toshiba 42HL167 42 in. LCD Television
RED POWER LIGHT BLINKS
Red power light blinks and tv will not turn on it is a 65h81 Toshiba HD
Jun 19, 2009 | Toshiba 65H81 65" Rear Projection...
Toshiba 65H81 blinking power light
Hello
I have the same thing going on with mine. What it is the SLR main Reg. is bad. The only way you can fix it is you can't put just one part in it you have to replace one of the boards. When you open the back panel up you will see three boards in a roll the one that needs replacing is the power board you have to get the model number. My Tv is a 65 HD model 65h81 the board on mine has a part number of PD 7400 yours will have something like that. Well let me know how it's goes my E-Mail is kenjr1@iwon.com
Feb 14, 2008 | Toshiba 65H81 65" Rear Projection...
Picture went off then Red light blinks all the time
Not an easy fix....requires chassis pull, careful soldering and
replacement of parts and fuses.....would you like step-by-step?
........................T.
Jan 12, 2008 | Toshiba 65HX81 65" Rear Projection...
Toshiba 65H81 blank screen and red blinking light....help
I don't think is any lamps.
If you are handy try to open the back of your tv, (unplug it first) don't touch anything just yet, you need to make sure you discharge any static left on the power board (the first from your left )Unplug power cord from the board. Take a heavy long screwdriver (Isolated) and lightly, touch a few parts on the board including the thick red wires that go to the lamps. Once that's done its time to put your dexterity at work. You need to lift that board (PD 0074) so that you can check some fuses like F850, F852, etc. for continuity. Mine were out. I had replaced those two and I had tv for another year. Remove the screws that hold the board. Now, this board PD0074 is connected to the next board by two white connectors and one blue. ....lift them up from one side with your finger nail. Don't unplug anything from the power board, just loose some wires so that you can lift the whole board on one edge. Get a voltmeter and set it to check continuity. Mine has a buzz. Look for them fuses if they are bad , ....replace them. (You can buy them at Partstore.com.....punch in "fuses"or "125V 2A")
In my case that was the only problem a year ago. Now I also have the same problem but this trick didn't work for me anymore. The Power Co,. messed me up big this time. In fact the problem with these Toshiba rear proj. is that when the power in your house goes out and comes back right a way in a split second and you don't have a power regulator, guess what : 'red led blinking'
In my case this time the whole power went on and off a few times within 10 sec. and by the time I got to the TV to unplug, it was to late. I think I have to replace the whole PD0074 board....and that's expensive.
Good luck
Jan 12, 2008 | Toshiba 65H81 65" Rear Projection...
Str reg.
No need to take the front screen out. The power deflection board is messing up with that red light.
Nic
Aug 19, 2007 | Toshiba 65H81 65" Rear Projection...
Toshiba 62HM14
What are the labels on the lights? Timer/Lamp/Service and what color is wich?
Jun 03, 2007 | Toshiba TheaterWide 62HM94 62" Rear...
Toshiba 65H81 65" Rear Projection Television Logo
166 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
