Question about Hobart D300 Stand Mixer
Hobart d-300 mixer
Why does the motor for d-300 mixer run in reverse?
    Scholar:
  • 127 Answers
If it is a three phase machine, switch any of the two hot leads to reverse the motor rotation. You can switch them either in the plug or the receptacle.
Posted on Dec 24, 2008
ON my D300 the problem might a run start capacitor in the base on the back side is a access plate and that is where you will find it ,,what happens is that your mixer starts and will bind on the load in bowl then it will stop the trans. and torq and will spin backwards and will run in that condition the capicitor stores a load of voltage to energize the motor and over come that inital torq ...by the way it is a simple fix about 15 bucks at the hobart parts place
Posted on Dec 05, 2008
To Whom it May Concer: At the school I work we have a Hobart D-300 Mixer. When we mix bread dough it pulls alot of current and trips the breaker. The max current draw on the name plate is 10.1 amps. I have seen the current go over 30 amps during the mixing process. Under no load the mixer pulls 7.8 amps. I dont have any information about this machine on paper and I can only go so far with troubleshooting.
My questions to you are: Is it normal for the mixer to draw 7.8 amps under no load? And is their a manual online I can look at so I can check the oil levels and make sure I do not have a low oil/needs greasing condition.
Thanks for your help and time,
Kenneth Clayton
Spartanburg Schools Dist#2
Posted on Apr 22, 2008
3 Suggested Answers
  • 1218 Answers
SOURCE: need to know what type motor is in a hobart D 300 mixer
Look on the I.D. plate. Voltage should be listed. "PH" is for phase. It will either be single (1), or three (3) phase. "AMP" is for ampacity or the amount of power it consumes. Hobart's manual does not list the motor as an entire replacement unit. It only lists parts as if you were to rebuild the motor. Sorry.
Hope this helps some.
Posted on Apr 18, 2009
  • 73 Answers
SOURCE: Hobart D-300 Mixer
https://feg.hobartcorp.com/resourcecenter/Discontinued%20Product%20Documentation/F-3492-N.pdf
click on the link above for parts catalog.
hope that helped.
Posted on May 23, 2009
My Hobart D-300 keep stop after running about 10 minutes and stay idol about 5 minutes then I can push start button to run another 10 minutes, it seam like control unit stop after it getting over heat and...
If your mixer's motor was built by Hobart; there are thermsiters built in to the stator's windings that can cause this problem. Check the amp draw while it is running. Also if your are over loading the mixer or using the wrong speed,, that will cause an over heating problem. You should be able to get on the ITW Food Equipment Group / Hobart web site(s) and get capacity chart.
Mar 01, 2015 | Hobart Food Mixers
How do i put back togeather Hobart 300-d mixer
http://www.hobartservice.com/Parts/
Go to this page and click on Hobart Smartparts System. Select Food Machines, Floor Mixers, D300 and you will eventually find parts breakdowns.
Feb 25, 2010 | Hobart D300 Stand Mixer
Can you use a spiral dough hook when the mkixer runs in reverse?
You can but the dough would ride down towards the bowl instead of up and your mix would not turn out properly.What kind of mixer do you have?i'm a hobart tech and repair these mixers often.Let me know.
Nov 04, 2009 | Hobart H600 Stand Mixer
Hobart mixer A200 Rotation
Assuming the unit is 120v, single phase, my money is on a bad electronic start switch (not to be confused with the on/off switch) It's not visible without some disassembly. Usually, it is located at the rear of the motor cavity. Take note of all the info on your model data plate then go here to obtain a parts breakdown on your particular mixer. http://www.hobartservice.com/Parts/
I'd suggest replacing the capacitor as well.
Sep 28, 2009 | Hobart A200 Stand Mixer
Need to know what type motor is in a hobart D 300 mixer
Apr 11, 2009 | Hobart D300 Stand Mixer
D 300 hobart mixer
All that I could find for you is the manual
seems their website is not up and running at the momment sorry I Could be of any more assitance to you nice mixer by the way.
Aug 02, 2008 | Hobart D300 Stand Mixer
Drive settings for Hobart Legacy HL-200
That software is proprietary. The only way to get a properly functioning drive is to order one from Hobart. www.hobartservice.com
Apr 21, 2008 | Hobart HL200-1STD Mixer
Hobart D300 Stand Mixer Logo
399 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
