Magnavox 50mf231d/37 plasma has vertical line on right side, apx 1/3 from end. line is from top to bottom. fivedtv@fairpoint.net
  • 8,596 Answers
See if the vertical line appears when you press the "Menu" button on the Magnavox. Also, see if the line appears when you watch a dvd on the maganavox. If it does not appear, then the problem is the cable wire or cable/satellite box. You can reset the cable box and the TV by powering them both off, and leaving them unplugged for 20-30 seconds, and then replugging. See if that works.
Posted on Apr 16, 2008
  • Corey Knoettgen
    Corey Knoettgen May 30, 2008
    I tried to help you and you rated me "inappropriate". I can't believe the nerve of you, so i'm going to unload on you. All of the methods that I gave you were valid troubleshooting methods. They were appropriate with the information that you gave me, so you should have given me at least a "thanks for trying" Did you expect me to give you a free service manual and a soldering iron? good luck with your problem, pal.
Any advice on what board I should replace if the left half of the screen is no good, just showing white and black vertical bars? Right half is fine. Is the panel kaput?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 29, 2015 | Panasonic TH-37PH9UK 37" Plasma Display -...
Does the Blinking Light on the Asic Main logic board mean bad Logic Board?
Check all the capacitors one might be bad find out if it is bad it should bulge on top of the capacitors
Nov 04, 2017 | Magnavox Televison & Video
Vertical Line on Phillips 42PF7320A/37
Hold down the cursor button towards the green line, it's really that easy...
Mar 07, 2010 | Philips 42PF7220A 42 in. Plasma Television
Black vertical line appears on plasma tv screen
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jun 03, 2017 | Philips 42PF7320A 42 in. Plasma HDTV
I have a Magnavox 50MF231D/37 plasma tv that won't turn on. I have to unplug it and let it sit. The green LED light changes to red and flashes. I upgraded the software but still have the problem.
you have some bad caps on the power supply board these can like devices will have a puffed up top where it vented the value is written on the side of the part
Nov 24, 2009 | Televison & Video
I have a magnavox tv model # 27MY6005D/37. Where can I get an owners manual and I have a line two inches on top like the tv bottom is on the top. How can I adjust that? Thank you
According to the model# you have a 27 inch TV so this would mean you have a bad capacitor in the vertical circuit 100uf 35v and you may need to replace vertical IC as well.Call Mats for parts 1-800-628-1118 for owners manual try Encompass Parts 1-800-638-3328.Somtimes if picture pops back to normal then resolder Vertical IC but if thats not happening, replace parts.
Nov 17, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Plasma TV technical difficulty
if you can still see the picture its most likely the control board that's going bad, you will still need a tech out to fix the issue.
May 19, 2008 | LG 42PX5D 42 in. Plasma HDTV
Vertical bar on Daewoo Plasma screen
YES YOU HAVE DRY JOINTS UNPLUG FROM POWER SUPPLY REMOVE THE BACK/ INSIDE YOU SHOULD SEE AT THE BOTTOM SEVERAL RIBENED CONECTORS FROM THE SCREEN ITSELF? UNDERNEATH YOU SHOULD BE ABLE TO SEE 2 OR 4 COMPONENTS CAREFULLY APPLY A HOT SOLDERING IRON AN SOLDER THE ONE THAT YOU ARE HAVEING PROBLEMS YOU SHOULD NOW HAVE FULL PICKTURE AGAINE ANY PROBS email me andymay2@msn.com
Mar 09, 2008 | LG 42PX5D 42 in. Plasma HDTV
Televison & Video Logo
195 people viewed this question
Top Televison & Video Experts
