Question about Brother HL-2070N Laser Printer
Replaced Drum in printer won't print
I replaced the drum in my 2070N now won't print?
Prior to replacing drum the paper light wouldn't shut off
  • Anonymous Apr 25, 2008
    RED PAPER LIGHT WANT GO OFF AND I CANT PRINT HELP
  • cheshire-gal Jun 26, 2008
    Said the toner was out, replaced it and now the paper light won't go off despite restarting it. I have looked it over and there is NO paper anywhere it shouldn't be. Please advise ASAP as this is the only printer I have at my art gallery and I REALLY need it.
    Thanks,
    Sonya Chappelear
    Cheshire Gallery
    cheshiregallery@gmail.com
  • 85 Answers
Unplug it then plug it back in and check for anything in the device. Or leave it unplugged for a few hours and try again.
Posted on Apr 17, 2008
When I replaced the drum and toner the paper jams. their is a silver bar that doesn't locks in place. what should i do?
The silver bar is part of the drum assembly, if the holders are broken you need to return the defective drum. That part of the drum case can't be repaired.
Jan 30, 2010 | Brother HL-2070N Laser Printer
Paper jammed in my 2070N printer & I don't know how to remove it
That machine doesn't have a release lever, you need to pull the paper out, as straight as possible trying not to tear it. There probably is a problem with your fuser, and it will need to be replaced. Even getting the paper out, it will probably jam again on the next print.
Jul 22, 2009 | Brother HL-2070N Printer
Brother HL 5250 red light flashing
I found this solution on the web-- Hope it helps.
The HL-2070N gets stuck in a toner end-of-life error condition. Perform the following to clear :
With paper loaded, new toner in,
Open front door
Turn off printer
While holding down the GO button, turn printer back on
When all four LEDs light up release GO button. All LEDs will turn off
Press the GO button 2 times. The 3 LEDs (toner, drum, paper) will light up solid
Press the GO button 5 times
Paper light will be blinking
At this point the toner end-of-life condition has been reset. Close front door.
BTW, I got this from Brother Support. Also, just a reminder, timing is important here so don't pause between button presses.
Jan 28, 2009 | Brother HL-2070N Laser Printer
Brother HL2070N printed 1 page fine,then nothing but light streak
turn off printer, remove cartridge and drum and clean internally.
reinstall drum and cartridge and do a test print, hopefully all will be better.
Jan 18, 2009 | Brother HL-2070N Laser Printer
Brother printer HL 5250 DN. The drum light was flashes and I have replaced the drum kit and toner cartridge.
Brother Drum Reset Instructions
The Drum LED continues to blink if the drum counter was not reset when you replaced the drum. To reset the drum follow the instructions below:
Press the cover release button and then open the front cover of the printer.
Press and hold down Go button until all 4 LEDs are lit. Once all 4 LEDs are lit, release the Go button.
Close the front cover.
Make sure that the Drum LED is now off.
Reset the drum counter only when you replaced the drum unit with a new one.
Dec 05, 2008 | Brother HL-2070N Laser Printer
Replaced printer drum but still printing with vertical lines
Hi dermtex,
since the faint lines are vertical, I think there is some thing distored the laser beam, try clean the lenses of the laser unit by clean soft cloth.
hope this helpful for you,
thanks
Hamedo
Aug 18, 2008 | Brother HL-2070N Laser Printer
HL 2070n
Copier tech here. :P I just had to look this up. looked to the internet first, before going to find a manual.
open front door (the door for toner and drum units)
hold Go untill all four lights are on.
Release Go
Shut door
good to go.
Have a good night ya all.
Mar 28, 2008 | Brother HL-2070N Laser Printer
Brother HL 2070n
Check the website of brother. If they allow you to download and update its firmware. Update the firmware and driver as well.
Mar 24, 2008 | Brother HL-2070N Laser Printer
Toner light still on after replacing with a new one
Drum counter usually has to be reset.. Check user manual or go to Brother's site if you want to drive yourself crazy Ed
May 04, 2007 | Brother HL-2070N Laser Printer
Printer drum light on
Have you already replaced the drum? If you have not replaced the drum that may be why you are getting smudges. If you have already replaced the drum, here is the reset procedure. The Drum LED blinks if the drum unit is near the end of its life. Use the drum unit until you have a print quality problem, then replace the drum unit with a new one. The Drum LED continues to blink if the drum counter was not reset when you replaced the drum. To reset the drum follow the instructions below: Open the front cover of the printer. Press and hold down Go button for about 4 seconds until al the LEDs light up. Once all 4 LEDs are lit, release the Go button. Close the front cover. CautionReset the drum counter only when you replaced the drum unit with a new one.Related Models HL-2030, HL-2030R, HL-2040, HL-2040R, HL-2070N, HL-2070NR http://www.tonerovernight.com
Mar 31, 2007 | Brother HL-2040 Laser Printer
Brother HL-2070N Laser Printer Logo
128 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
