Question about HTC TyTN Smartphone
TyTn II unresponsive touchscreen
My touchscreen is not responding
  • 2 more comments
  • Anonymous Apr 29, 2008
    the phone keeps on freezing and wont respond to anything what so ever
  • Miggs58 Sep 25, 2008
    While I'm typing an sms with the stylus it just dosen't respond. I have to touch the stylus down on the specific letter and kind of like rub it up and down like I'm colouring it in befor eit responds. Its not always an issue but often.
    Thanks.
    Miggs
  • Anonymous Oct 11, 2008
    touch screen stops responding, tried to align screen and hard rest with no luck...
  • tomrd Oct 28, 2008
    The screen on my HTC TytnII does not respond properly to taps. It opens the Start menu when I press firmly anywhere on the screen but does not access any other functions.
  • 6 Answers
Check the front display frame unit, the frame and the display are separated by a thin layer film that maybe spent on several point of contact, so the frame became too close and stay always in touch with the screen making it unresponsive.
Fix is simple: disassembly the front layer and replace the thin layer with a new one, you can use a thin adhesive foam, buy it in your hardware store for less than 1 Eur/Usd.
Posted on Feb 25, 2016
Htc tuoch not responding and it is locked
Posted on May 04, 2010
  • 85 Answers
Try to calibrate the touch screen. Also clean it with a soft cloth. But calibrating it should help the film when you tap the screen.
Posted on Apr 17, 2008
How do i insert sim card
In the past, some HTC devices have been affected by problems with touchscreen alignment, but you shouldn't have any problems with the TyTN II in this department. The 240 x 320 display is clear and bright and also seems not to suffer from yellow colour cast that has been common on earlier devices.
The keyboard has a nice positive action to it and works extremely well. It's virtually identical to the HTC Herald, and very similar to the HTC TyTN. Holding the device in both hands it's easy to type at a fair rate using just your thumbs.
Finally, to insert a SIM card you have to slide the keyboard open and then look on the rear of the screen. Under a flap you'll find the SIM card slot.
Car Tuning
May 24, 2012 | HTC TyTN II Smartphone
My htc tytn II screen suddenly became unresponsive to the stylus or even my finger. I can only open my screen lock through the keyboard which worked but takes longer time to use. many commands can only...
Hi. You need to replace the digitizer. This happens to many touch screen phones from all brands.
you can purchase from:
http://cgi.ebay.com/US-NEW-HTC-TyTN-II-TILT-8925-TOUCH-SCREEN-PAD-DIGITIZER-/350435156469?pt=LH_DefaultDomain_0&hash=item51979021f5
After purchasing you can have it replaced in a cell repair shop or similar shop. Or you can chose to replace it yourself.
Thank you for using fixya.
May 24, 2011 | HTC TyTN II Smartphone
How to unlock free HTC tytn II
There's no free unlocking solution for it yet. In order to be able to use the phone on almost all GSM carriers worldwide, you would need the unique unlock code of the phone.
Unlock HTC TyTN II
Feb 15, 2011 | HTC TyTN II Smartphone
My htc tytn II touchscreen is not working.
Possible failure of the touch screen or the main board. But since this job is adviced to be looked into by the company specially if spares are required, the opttion to remove must be reconsidered.
Try and warm up set to confirm if any moisture set on has resulted in the prroblem.
Sep 19, 2010 | HTC TyTN Smartphone
Looking for HTC TyTN II software to connect to PC.
Hello
If you need software on your HTC TyTN II software to connect to PC go to the sitr below and download varieties of software.
www.htc.com/europe/supportdownloadlist.aspx?
Thanks.
Sep 06, 2010 | HTC TyTN II Smartphone
HTC TyTN II flashed memory no sound
Check if you coincidently mute the phone. If its not the software then looks like the speaker is bad. Send your HTC TyTN II for repair to Dr. Cell Phone.
Dec 31, 2009 | HTC TyTN II Smartphone
TyTN II - Keep the phone screen alice during a call
Received the following reponse very promptly from HTC Support
---Quote---
This is actually a function of the phone and not a fault. It was designed so that when you were on a call and had the phone against your ear that you didn't accidently tap on the screen and open functions or end the call etc. If you wish to access the touchscreen while on the phone you can press the power button on the side of the phone to turn the screen back on. I have attached a 3rd Party Application that allows the screen to stay on while you are on a call. Follow the below steps to install the program. Attached is a patch for the TyTN II screen blackout issue.
This is not an official fix.
  1. Copy the KaiserTweak.zip folder to your pc's desktop.
  2. Connect you device to the pc via ActiveSync.
  3. Use the Explore function in Active Sync to copy the KaiserTweak.zip folder to the windows directory on your TYTN II.
  4. Disconnect your TYTN II from the pc.
  5. Open up file explorer on your TYTN II and go to the windows directory
  6. Unzip the folder to the windows directory on the TYTN II
  7. Run the Kaiser Tweak.exe to install the patch.
  8. Adopt the recommended configs, not the default.
  9. Soft reset the TYTN II by pressing the stylus into the little circle hole on the bottom of the handset.
If it doesn't work first time hard reset and try again. ---End Quote --- Thanks to the FixYa guys for thier intererst in this topic and problem Cheers Corpcc
May 12, 2008 | HTC TyTN Smartphone
HTC TyTN Smartphone Logo
1,402 people viewed this question
Top HTC Computers & Internet Experts
Justin
Justin
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
