Question about Nintendo Wii Console
CD will not eject
There ia a CD inside the console, when turn on the power it will not read the CD. And the CD will not eject from Wii Console.
  • 1 more comment
  • Anonymous Apr 17, 2008
    the
  • hobagleash Sep 11, 2008
    ditto and it's modded
  • Peter Thompson
    Peter Thompson May 11, 2010
    Have you had the console mod chipped?
Yes, I have.
Posted on Apr 17, 2008
Unable to read disc I have 20 something games it wont read any of them
Here are the steps that worked for some:
1. Completely power down the console.
2. Power up the console and get to the Wii Menu.
3. Eject any disc currently in the console.
4. Press the eject button again, without any discs in the drive.
5. Insert the disc that you would like to play.
If this doesn't work then contact Wii customer support.
Jan 10, 2010 | Nintendo Wii Console
Disc is stuck inside goes on will not eject or
You will find a small whole in front of the disc. Quite small, say a niddle head size just take a pin approx 3 inches and poke it slowly inside. You shall feel the pushing of a soft touch feather button like on your keyboard and your CD will come out. Don't forget to push eject button before poking the pin. and kindly do rate my solution.
Jul 17, 2009 | Nintendo Wii Console
Hi my wii will not turn on but I have a game disc inside. How do I remove the disc without power? Is there a manual eject?
since the Wii has an optical drive, what you need to do is to insert a straightened paper clip into a tiny hole that is located on the front of the drive, typically right next to the eject switch. Once you’ve inserted the clip, the stuck CD should be easily ejected.
Jun 24, 2009 | Nintendo Wii Console
Ejecting Wii disc while power is off
Your disc is stuck in Wii Console, It needs to eject manually. You might check out Wii Fix Guide, that gives step by step information on Dis-Assembling with screenshots, even a novice can fix the disc eject problem with the help of this DIY Guide. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Jan 29, 2009 | Nintendo Wii Console
Disc won't eject
Your disc is stuck in Wii Console, It needs to eject manually. You might check out Wii Fix Guide, that gives step by step information on Dis-Assembling with screenshots, even a novice can fix the disc eject problem with the help of this DIY Guide. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide.
Jan 20, 2009 | Nintendo Wii Console
Wii not ejecting disc
Unplug the power cord for an hour then plug it back in and try it.
Aug 28, 2008 | Nintendo Wii Console
Nintendo Wii
get it cleaned out
May 11, 2008 | Nintendo Wii Console
Wii loader problem
have you tried to unplug it then plug it back in? cuz it might not be able to get fixed.
Apr 28, 2008 | Nintendo Wii Console
Wii
hello micky1965
Try holding down the eject button for at least 10 seconds after turning on the console. If that doesn't work (or you've already tried that). Try the following steps.
1. Unplug Wii from power outlet.
2. Plug in Wii again.
3. Press power button.
4. Press Eject button for at least 10 seconds.
5. If the disc doesn't eject try holding down the power button for 10 seconds and then the eject button again.
If that fails then either return the console to exchange for a new one or contact Nintendo consumer support. Info follows:
Nintendo Consumer Service Contact Information:
Telephone: 1-800-255-3700
Email webform:
| Nintendo - Customer Service | Contact Us! |
I wouldn't attempt to manually remove the disc (by trying to disassemble your Wii) as it may void your warranty. It could simply be a faulty console in which case Nintendo should replace it within 2 weeks (according to posts I've read). It seems to be a somewhat common problem.
If holding down the eject button doesn't work, there's really not much else you can do. Sometimes unplugging and replugging does the trick.
I've had problems with discs not ejecting and some combination of the steps I wrote above solved the problem.
riz.
althought i have a guide for opening inside the wii.?
Apr 08, 2008 | Nintendo Wii Console
Wii console will not eject disk
I managed to eject a WII disc out manually very easily:
- Disconnect the drive
- You see the white plastic mechanism on your right side and the wheel connected to the motor
- turn the wheel towards the back side of the drive while pushing the half inch square plastic piece towards the left.
You will see the disc coming out while you are turning the wheel.
Nov 25, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
59 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
