Question about Garmin StreetPilot C330 GPS Receiver
No signal just got this c330 and it is stuck in kansas. it says locating satelites?
  • hortons06 Nov 02, 2008
    won't find sat signal
  • alfreida Nov 07, 2008
    Was running then stoped and gave no signal from satilite
No signal satelites
Posted on Oct 29, 2008
  • Garmin Master
  • 638 Answers
You will have to leave the unit out in the open so it can 'see' the satellites. It might need from 20-30 minutes to acclimatize itself to the new location. It is set at Kansas because that's where the manufacturer is, so that is the last recorded satellite signal.
Posted on Apr 21, 2008
My garmin street pilot c330 won't aquire satillite. this unit is 2 years old, but never out of the box. i got it from my son and tried to set up. when you turn it on all of the data in the unit is...
Try connecting in your car and leave it on and let it charge while you are driving it may eventually find the satellite, it probably remembers the last satellite it found which was in Kansas. You may not be getting a signal where your are right now so run some errands and leave it connected in your car.
You can also go to the garmin web site and try updating the unit. You will need a usb cable and will need to install garmin updater. Make sure the unit is fully charged.
If this does not work you can call garmin and they are usually very helpful. Here is the garmin link which will help answer some more questions.
http://www.garmin.com/garmin/cms/site/us/support/
Let me know what solved the problem. thanks for using fixya
May 14, 2011 | Garmin StreetPilot C330 GPS Receiver
I have a Garmin c330. It will not pick up a signal from anywhere. I will drive down the road to try and pick one up and it still doesn't. It will ask me if I am in Kansas I say no and it says acquiring...
The satellite chip ( SIIRF) is possible burned out
It starts always at the last place it was programmed or the default place of issue.
It may be quite expensive to fix as it requires a new motherboard. Not usually covered by warranty as they can be damaged by overcharging aqnd connecting to DC when starting engine.
Jun 30, 2009 | Garmin StreetPilot C330 GPS Receiver
Cannot acquire satellites and freezes
use the web-updater at garmin
or update the firmware at garmin,
turn WAAS on
turn GPS signal off
go outside after the update
turn GPS signal back on ( takes upto 15 mins to locate satelites )
should be good
Regards
Richard.
Apr 21, 2009 | Garmin StreetPilot C330 GPS Receiver
No signal - stuck in Kansas
Try this and see if it fixes it for you...first disable bluetooth on your unit.
1. Power off the unit.
2. HOLD down the power button and you will see "Pre Boot Mode" appear on the lower part of the display. KEEP HOLDING the power button down and the display will flicker, do this until the pre boot mode message disappears. This seems to take a long time (60 seconds at least).
3. Once the pre boot mode message disappears release the power button and your device will perform some activites to recover from problem.
Jan 02, 2009 | GPS
New Garmin 330 stuck on kansas
Take the unit outside and turn it on. Then select View Maps, at the top of the screen it will say either "Locating satellites" or "Acquiring Satellites". Once the garmin has locked onto the overhead satellites, then it will say "Ready to Navigate".
Locating Satellites take longer than Acquiring Satellites.
Jun 10, 2008 | Garmin StreetPilot C330 GPS Receiver
Can't change location-appears as if still in Kansas despite downloads
You need to go outside and turn on the Garmin until it has acquired a satellite lock (15-20 minutes). Kansas is the default location (Garmin Headquarters). Once you have acquire satellites, the Garmin will remember the last position as the starting position when the power is turned off. You know you have acquire a satellite lock once "Ready to Navigate" appears on the top of the screen.
Jan 03, 2008 | Garmin StreetPilot C330 GPS Receiver
Home address
Click 'Where to', select 'My Locations' Select 'favorites' Click 'Home' then select 'EDIT' in the lower right hand corner. Than selet 'DELETE' that should clear the home addy out for you.
Best of luck.
Dan
Dec 26, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
307 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
