Question about Dell Latitude CP (0001849d-38380-968-p06e) LS-120 (SuperDisk) Drive
Power Every time I put the laptop on ,it will boot for 10 seconds then shuts off
Try to change your ram memory module.
Posted on Apr 28, 2008
Battery not recognised/not charging
Turn the computer off, unplug it, take the battery out. Then hold the power button down for 10 - 15 seconds. Plug the ac adapter back in, but do not put the battery in yet. Boot the computer, then shut it back down. Put the battery back in then boot it again. It should recognize the system now.
Jul 31, 2014 | Sony VAIO VPCEA36FM/W Laptop
Tip
Laptop has no video but ower LED is on and restarting system does not help!
possibly the safety system kicking in
step #1: remove the battery and all other external hardware
step #2: disconnect the power adaptor
step #3: press and hold the power button for 10-20 seconds
step #4: connect the power adaptor only! no battery!
step #5: press the power button to start system.
spet #6; If the system boots and you have video let it boot and run for 10 miniutes ... then shut down and reconnect the battery....
step #7: reboot system If system is still good repeat step#6
continue this process until all hardware is reconnected.....
This is very common among all laptops especially if they are connected to the adaptor for very long periods of time without using the battery. The process of holding the powerbutton with no energy to the laptop drains the power out of all of the capacitors on the system board and thus allows the system to boot normally once energy is reconnected.
on Jan 10, 2010 | Computers & Internet
ACER APSPIRE 5742 TAKE ABOUT 10 TIMES TO BOOT UP.
If there is extreme heat inside the laptop, this happens. Clean the fan and put new thermal pste/thermal pad to processor and chipsets. Also check for power button problem or any stuck keys in the keypad.
Hope this helps
Dec 11, 2012 | Acer Aspire 5742 Notebook
Did a windows update, now computer reboots every 5 seconds
Boot into Safe Mode, press F8 at bootup, then when asked if you want safe mode desktop or system restore choose system restore and restore it to a time before you had this problem.
Feb 13, 2010 | Acer Aspire 3000 Notebook
HP dv9000 screen shutdown
Power controller circuit on the motherboard needs repair by pro.
Oct 08, 2009 | HP Pavilion dv9000z Notebook
Compaq Presario CQ50-139WM will not boot.
first thing i would try is to unplug the powercord from the surge proetctor and from the computer. turn the computer over and take out the battery.
with the battery out, press on the power button for 30 seconds.
now put the battery back in and plug in the computer and try booting it.
sometimes static electricity builds up inside the computer and this will dissipate it.
Oct 02, 2009 | Compaq Computers & Internet
Please wait message
The easiest solution is to unplug the AC adapter and pull the battery. This will shut off the laptop.
Once it is off let it sit about 10-20 seconds then put the battery back in and plug in the AC adapter.
You should now be able to press the power on button and it should boot up. It may give you a screen saying the last time it shutdown it was not good. Just pick to boot with last known good configuration and you will be fine.
Jun 14, 2009 | Compaq Computers & Internet
Laptop boots then shuts automatically off
Try this, if you have a fast hand, the second it boots, push Ctrl+Shift+Esc and end taskeng.exe.
If you can't do it fast enough, try booting into safe mode, going to scheduled tasks, and removing any suspicious ones.
If you don't know how to boot to safe mode, push f8 until you see a screen which allows you to choose safe mode.
Dec 18, 2008 | Toshiba Satellite P105-S6177 Notebook
Boot up problem
Has the power connector at the rear been damaged at all? It sounds like there is no power getting to the laptop.
Dec 29, 2007 | Computers & Internet
Computers & Internet Logo
80 people viewed this question
Alun Cox
