Question about Akai PDP-4249G 42 in. EDTV-Ready Plasma Television
AKia pdp-4249g My remote batteries died and need to reprogram remote. The screen is blue going thru auto signal search and says no signal. I do not have original remote to reset tv.
  • el vagbundo Jul 30, 2008
    my tv turns on for abouth two second detecting channels then turns off by itself.thanks
I HAVE PROBLEM,THE SCREEN SAYS AUTO SELECT SEARCHING,THEN NO SIGNAL FOUND THEN THE TV TURNS OFF BY ITSELF
Posted on Jun 25, 2008
My Pioneer PDP5070HD remote control malfunctions: if I press any button on the remote, the screen size cycles continuously thru all the screen formats and will not stop until the batteries are removed...
It sounds that the keypad inner have dirty. The remote control switches on to that function, and keeps stays to that. It need to be cleaned. If you wish to get more details about how to check and clean a remote control, check these sites. http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Pull up previous posts or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Aug 29, 2013 | Pioneer PDP-5070HD 50 in. Plasma...
Tip
RESET ALL CODES AND PRESETS
IF YOU GET LOCKED OUT OF YOUR TV OR ITS MENUS IN ANY WAY USE THE REMOTE AND 1-PRESS BRIGHTNESS 2-PRESS FREEZE 3-PRESS MENU 4-PRESS ENTER THE SCREEN WILL FLIP BLACK FOR A SECOND AND THEN HIT MENU A FEW TIMES TO BACK OUT OF THAT TASK. THIS IS THE UNIVERSAL V-CHIP FOR THIS TV AND MANY OTHER RESETS.
on Sep 21, 2007 | Akai PDP-4249G 42 in. EDTV-Ready Plasma...
My JVC model AV27330 has a constant blue screen. I can go thru Video 1, video 2, video 3 and then says chn 04 but should be 03 - when I push channel button down channel 105 shows or the other way channel...
You need to use the original remote and call up the customer menu; select auto program or channel program and see if reprogramming will help.
If no JVC remote you have only one other choice----connect a DVD or VCR to one of the video inputs and see if the set functions that way.
SD TECH
Aug 09, 2010 | JVC AV-27530 27" TV
PDP 5073TMC... No remote will work any function. the remote(s) are fine, batteries good, etc. the "infrared" cable is plugged into the back lower unit, the red or green light on the tv remote eye glow if...
There is either a bad remote sensor in the set or a system control problem. Both work with each other so it is hard to say. It will take a little troubleshooting to figure this one out. I would bet on the remote sensor being bad. Have a repair shop check it out. This should be an cheap repair. Thanks
Oct 24, 2009 | Akai PDP-4249G 42 in. EDTV-Ready Plasma...
Tv is stuck on blue screen
i would suggest cycling thru the inputs- av1 av2 rgb hdmi. blue screen is indicator of no input.
Apr 07, 2009 | Televison & Video
NO SIGNAL on TV
There should be a quick setup guide that came with this unit,
to get the tuners going you need to follow the procedure for setup, (as the stations will need to be found).
probably along the lines of press menu, select Setup, choose tuning, choose auto setup.
You probably have done this already, but does no harm to ask.
Oct 16, 2007 | Akai PDP-4249G 42 in. EDTV-Ready Plasma...
AUTO SIGNAL DETECTING NO SIGNAL
Yes, I seem to have fixed the problem on my Akai using some creative google finds. One of two things worked - not sure which:
1. Leave the set unplugged overnight - it must let the electronics reset when the residual charges clear
2. For my Akai (remotes and models vary), hit in remote's sequence quickly - brightness, freeze, menu, enter - this places you in some screen that offers a hard reset option. That didn't work right away, but i did it before the option above and then the set worked again.
My problem was really odd because it worked for the component inputs and you could see the video and TV signals inside the PIP windows, but not full screen as primary input. Why the TV could 'see' the signals in a PIP windows but not detect them as primary I have no idea.
Oct 13, 2007 | Akai PDP-4249G 42 in. EDTV-Ready Plasma...
Akai model pdp4249g
Hello drifter,The design of the tv enables the auto search to detect any input signal you have selected. It could be TV (off air, video signals etc) so just switch on whatever inputs to the akai plasma befote you switch the Akai plasma on and let it do the work for you. just relax and watch the tv. recap 1. switch on the input eg video deck, DVD, VCD, or satellite dish. 2. switch on your AKAI PLASMA and 3. wait for the akai to search for your input signals. TRy this simple procedure and if it doesnt work just post back the message. The DON
Jun 15, 2007 | Akai PDP-4249G 42 in. EDTV-Ready Plasma...
Akai pdp4249g plasma monitor
Do you have any kind of anteanna? Go into the user menu and choose channel, then choose air or cable then do a auto programming this will pull in all the channels that is available and save them to the memory
Apr 10, 2007 | Akai PDP-4249G 42 in. EDTV-Ready Plasma...
Akai PDP-4249G 42 in. EDTV-Ready Plasma Television Logo
306 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
