Question about Refrigerators
Refrigerator is freezing everything, was set at 5 , reset to 3 still freezing everything
  • 8 more comments
  • SUSIE39 Apr 16, 2008
    GE model#gss25tgma ser#fa408475
    it is freezing soft drinks, coke's pepsi ,beer and bottled soft drinks, I set it at (3) 24 hrs ago and it is still freezing
    it is a side by side
    i use this refrigerator mostly for frozen food and refrigeration for soda's and beer i have it set on 3 for the refrigerator for the last 24 hrs because it was freezing on 5 , it just started doing this in the last 3 days ???
    where is the damper door assembly?
    It is 8:00 pm here can i look tomorrow and still contact you then ?
  • SUSIE39 Apr 17, 2008
    Ok my husband took the refrigerator apart and the damper flap is broken , can you just buy the flap or do you have to buy the
    complete part?
    give me the part details and we will order on line
    thank you so much
    went that site at Sears can not find par. i even put in the part # you gave yesterday. Item # 1055112 ?
    I tried the Sears site and could not find it
    do you have a part #
    Genius:
  • 3,422 Answers
Can you please give the make and the model no. so that i can help you fix it.
Waiting for your reply.
Posted on Apr 16, 2008
  • 12 more comments
  • Priya darshan Apr 16, 2008
    If foods, such as fruits and vegetables, in the
    refrigerator are freezing, it can be caused by several things. First,
    check the controls. They should be set at "C" and "5" or "5" and "5".
    The proper fresh food temperature is between 38 and 42 degrees
    Fahrenehit. The freezer should be between 0 and 8 degrees Fahrenheit.
    I believe this is Freezer on Top Model and not side be side.Please correct me if i am wrong.
    Since the cold air coming into the fresh food section
    originates in the freezer above, the rear of the top shelf will be the coldest spot in the fresh food area. Avoid
    placing delicate items that freeze easily on the back half of this shelf.If food is freezing in the produce (fruits and vegetables) or meat pan, it may be that the temperature controls are not
    set high enough. Since cold air naturally falls, the pans can get too cold if the refrigerator is not
    running long enough to maintain good air circulation. Adjust both controls up one notch.
    Ok..
    If food in the bottom of the
    refrigerator is freezing, this could be caused by a refrigerator not
    having enough food to absorb the cold air.
    If food in the door
    is freezing, move the door bins up or down so they are one notch away
    from freezer vents (Side by Side models only).The fresh food control should be at the normal
    setting of 5.
    The problem is usually the damper door assembly
    What usually happens is that the damper door cracks and gets stuck in
    the wide open position. Look in there and see. If this is what’s
    happened to yours, then you’ll need to replace the entire damper assembly.
    First disconnect the power cord,wait for 10min and then proceed.
    Under the controls at the ceiling of the refrigerator is a item call
    the auto damper. It's located in the left rear top. Start removing
    the covers at the top of the refrigerator until you gain access to this
    control. Once you find it, tell me if the damper door is open.
    Perhaps the lever that controls the damper door is just broken or the
    damper door itself. It's mechanical in a sense as there are no
    electric wires going to it. Air temp controls the opening and closing
    of the door.
    I have got some diagrams for you.It will help you out.
    CLICK HERE
    Sure..
  • Priya darshan Apr 17, 2008
    Hi again,
    You will have to buy the whole thing.Don't worry just call up the sears people and order the part.
    I'll give you the part details from where you can buy online.
    If you wanna call a tech you can do that as well..
    Yes, please give me a min. i'll let you know from where to get it.
    And please don't forget to rate or accept the solution as fixed since your problem is solved..
    Ok, please go HERE and then choose your model,then under that you will see a search box in that type "damper" and you will get it.
    sorry please CLICK HERE
    Ok,Please CLICK HERE
    The no. which i gave you was just the item no. to show you the diagram not the part no.
    Just go to the link which i gave you and then order it.
    No,don't go for the sears one please CLICK HERE
    In the bottom left you will find the search box in that type damper.then you will get the part
Hi, my refrigerator Panasonic NR-B320T non stop running, both vegetable and freezer sections are GETTING FREEZED even though the temperature are set at 1 (cold not at 3, the coldest).
check your user hand book as most fridge settings work the lower the number the colder the setting
so 1 is around 1-3 degrees , 3 is 4-6 degrees, 4 is 7-10 degrees
it is the freezer that works 1 is minus 5 and 5 is minus 20 degrees
it would explain why everything is freezing up
it would also explain the non stop running as the fridge is battling to keep the low setting
Nov 23, 2016 | Panasonic Refrigerators
try tuning the control to a lower setting . if on 5 go to 4 or 3
Feb 06, 2015 | Kenmore Refrigerators
Why is refrig so cold its freezing liquids
Good Morning Friend,
I understand that your Frigidaire refrigerator, model# FRS23KF7AB, is so cold that it is freezing liquids inside the refrigerator area. I also see that you have it set on the warmest setting. First, I suggest setting the controls to the factory setting. Secondly, reset your appliance, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. When power is restored, leave the setting on the factory setting, and give your refrigerator 24 hours to stabilize at the factory setting. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your refrigerator status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 15, 2014 | Frigidaire FRS23KF7AB Side by Side...
I have a true double door commercial refrigerator. it stay below freezing even though I set the temperature very low. it is freezing everything.
thermostats on those things are notoriously bad. probably a bad thermostat. should have numbers 1 - 9 and usually set on 5
Aug 18, 2013 | True Refrigerators
Fridge freezing everything
THIS REF. WORKS BEST WITH THE REF. SET ON 4 OR 5 AND THE FREEZER AT 2 1/2 OR 3. HAVING A HIGH FREEZER TEMPATURE CAN HAVE FREEZING IN THE BOTTOM DRAWER OF TH REF. MAINLY BECAUSE OF THE RETURN AIR VENT TO THE FREZER IS BEHIND THAT DRAWER.
Apr 25, 2010 | Maytag 21.9 Cu. Ft. Bottom-Mount...
My GE Profile Performer refrigerator is freezing fruits and veget
PUT THE REF. ON 5 AND SET THE
FREEZER ON 2 1/2 AND SEE IF THIS WORKS
Apr 23, 2010 | GE Profile PSW26P Stainless Steel Side by...
Fridge temp is set on 1 and milk and eggs are still freezing.
This is a common problem and it has to do with the electronic temperature sensor. Check with Sears to see if there is either a recall or a TSB (Technical Service Bulletin) for your model. They may try to get you to buy a new circuit board, but the solution is actually the temp sensor itself. (www.searspartsdirect.com) will give you the scematic as well as the part number. Just enter your model and press enter.
Mar 05, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Everything in Fridge side is freezing
your thermostat is probably defective. is an electronic or mechanical thermostat? there is a website called repairclinic.com. where you can enter your model number and get tech. help along with part #'s., its a very good website
May 08, 2009 | Refrigerators
Refrigerator freezes everything even on the lowest setting
Is everything really frozen or just the top shelf stuff? You may have a thermistor (temp sensor) problem if the compressor just runs and runs and runs all the time. Take a glass of water and place a thermometer in it for about 3 hours then take a temp. reading. That will let you know what the real temps are. See if you can cause the compressor to kick off and on by changing the temp settings (go to real low for about 5 minutes then back up to high). Let us know what happens.
Dec 24, 2006 | Sanyo SR-3620 Compact Refrigerator
Refrigerators Logo
109 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
