Question about Dell 962 Photo All-In-One InkJet Printer
Copying problem Hi,i would like to know why theres a line in the paper every time i make a copy
  • 41 Answers
could u plzz be more specific abt the line in the paper, i wish to know do u have the same issues if you are printing from the computer as well.
Try the following steps...
1) open the lid of the printer and clean the scanner glass
2) scan a document to the computer and check if you are getting the line even on the scanned image, if yes then its an issue with the printer
Posted on Apr 26, 2008
When making copies, there's a line running through every copy-- along the entire length of the paper
If line appear on drum scratched change drum & cleaning blade.otherwise change only cleaning blade
Mar 24, 2013 | Canon PC-940 Black and White Copier
I have a brother 770 fax. When making copies or sending faxes the paper has long black narrow lines running from the top to bottom. Please help.
Hi There!
One reason why you're having a black line on the copies you make and faxes that you send it's because the scanner glass inside the fax machine is dirty. Here's what you can do to resolve you're issue.
-Make sure the printer is off and unplugged from the power outlet for your safety. -Open the control panel, Prepare a dry lint free cloth and isopropyl alcohol, dampen the cloth with a small amount of alcohol. -Inside the fax machine look for a the long scanner glass clean it with the dampened cloth, using hand try to feel if there are debris or dirt and concentrate on cleaning that part. -Directly above the glass you will see a white strip clean that also with the dampened cloth
Once you're done cleaning, close the cover and plug it back in. Try to copy a blank sheet of paper and if you can still see the same line clean it again for about 3-5 times, Make sure to make a copy everytime you clean the glass.
Hope this helps!
May 08, 2011 | Brother IntelliFAX 770 Plain Paper Thermal...
Our HP laserjet M1522n has a vertical line going through the paper when using the top feed. the line doesn't appear on copies made thru the computer or on the flatbed, only thru the self feed. any one??...
If you open your "self feed" cover, you should be able to see the scan glass that originals pass over to copy. Clean that glass thoroughly. There is some dirt or whiteout (liquid paper) on it which causes the shadow or line on copies. Let me know.
Oct 15, 2009 | HP LaserJet M1522n MultiFunction Printer
Every time I fax or copy a perfect sheet of paper both the fax received and the copy have a 2 inch wide solid black line on the right. How do I fix the machine?
Have you tried replacing the ribbon cartridge? If that doesn't resolve the problem, then there is a fault with the thermal imaging head. You did say both Recieved faxes and copies, correct? If faxes you send out are clear, then the above mentioned would be correct. Let me know, please.
Oct 12, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
1/4" weak, blurred line from top to bottom of page on every copy...has new drum, cleaned optics and glass, including **** glass...
hi, if the class is clean and the drum is not bad, this means is the fuser unit role cause this problem, but sometimes the cleaning blade too do this when it becomes bad and it doesnot clean the drum well. to help you trouble shoot this problem do this:
open the document feeder donot put any paper on class, and hit start, let the ,machine copy when the feeder is up and no paper, the copy will come black paper, check it if u still see the line there this means the fuser, if not its cleaning blade or drum.
let me know wat happen and if u have pics will help too.
Best Regards
Mar 10, 2009 | Canon imageRUNNER 2000 Copier
Pana KX-FL511 will not take mlt. pgs to copy, black lines, hot
It's time to upgrade. The THERMAL head is about to **** out.
Jan 30, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Lines on the paper after copying and receiving fax
look on top of the toner cartridge for a blue slider.
do it 10 times.
Jan 29, 2009 | Brother IntelliFAX 2800 Laser Fax
A straight line on paper
need more info.
white line - black line ????
copying from glass or doc feeder or both ?????
Oct 09, 2008 | Canon NP 6035 Copier
Brother MFC 5840-CN - line appearing on copies
I have no idea whats happening here.. But it sounds a bit like when he prints from the pc, it uses a different paper stock? Could it be the paper from a direct copy is being used from a different source or tray? Or maybe it's like a 'draft' copy?
I know thats not much help, but if you want, I can spend some time investigatiing this.. But as over a hundred people have never bothered to reply to my posts, I'm a bit reluctant to waste time, unless it's appreciated.. Let me know if you really want to get involved at a deeper level..
May 22, 2008 | Brother MFC-5840CN All-In-One InkJet...
Minolta keeps jamming
Hi Daryl, what does the paper look like? Is there a "nick" in the leading edge of the paper or any signs of damage to the paper? Remove it carefully an look, but be careful cause the toner isn't fused yet, so it will get on your hands and clothes.
Nov 15, 2007 | Konica Minolta DiALTA Di200 Copier
Dell 962 Photo All-In-One InkJet Printer Logo
Top Dell Office Equipment & Supplies Experts
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
