Question about HP Compaq Presario V2000 Notebook
Wireless not working...
I have a Compaq Presario V2000 laptop and the wireless does not work. I am suposed to have some sort of internal card, and my computer says that I am connected, but when I try to use the internet it says that it cannot be displayed. I also have a button to turn it off and on, and that does not work, either. I have been able to use the wireless in the past, about two years ago at home. Since I started college I decided not use my wireless and just connect to their network via a Cat 5 cable. Now that I would like to use my wireless again, it won't let me.
I don't know much about computers, but any help is appreciated! Thank you!
  • 472 Answers
If you want to use the College wireless system, then you will have to conatct the administration and they will point you in the right direction.
Although the service is normally free for students, you need to have the IP, subnet and gateway assigned to the laptop to access the service. They may also request your Mac address from your laptop. This is just the unique identifier to help protect the network from outside users.
Even check with a few of the others you will see at lunch using theirs, they will be happy to point you in the right direction.
Posted on Apr 16, 2008
I was able to connect to my HP Compaq Presario V2000 Laptop to my WiFi Network using NetGear. When I reconfigured the network I could connect to all other network like Dell Lptop , Nokia Smart Phone and HP...
Hi!
Your Compaq V2000 has an Intel Pro Wireless 2200 BG wireles adapter. (doesn't support N, but that's not the point I think)
If your new network configuration is based on WPA/WPA2 encyption, this adapter has some known problems to establish a connection. It works great with WEP, but not so well with WPA.
Sometimes the issue can be solved by installing the latest versions of drivers and software for the wireless adapter.
If it still doesn't work, a known workaround is to disable via device manager all other network adapters in the computer (ethernet adapter), leaving active only the Intel Pro 2200 wireless adapter.
Hope it helped,
Bogdan
Sep 25, 2011 | HP Compaq Presario V2000 Notebook
My compaq presario V2000 will only connect to dialup
To connect to your DSL internet you will need an ethernet port or wireless card on your laptop. Your laptop should have an ethernet port, it will look like a phone jack but a little bigger. In the off chance that you don't have an ethernet port on your laptop you can also purchase an ethernet to usb adpater. You may have a wireless card installed on your laptop, but if not you can purchase a usb wireless adapter. To use your internet wirelessly in your home you'll also need a wireless router. All of these things can be purchased at your local electronics store (walmart, best buy, kmart, frys) and usually are fairly easy to setup with the included instructions.
Feb 15, 2010 | HP Compaq Presario V2000 Notebook
Hard drive compatibility with compaq presario v2000
Hi this hard drive will work with your laptop all it needs to be is to have a SATA connection cable
2.5 inch = laptop
3.5 inch = Computer
Hope this helps
Muzzi_123
Nov 14, 2009 | HP Compaq Presario V2000 Notebook
How could you get the wireless card to work on firefox len05. i can plug cat5e cable to work on line. but since i dump the windows. on my on firefox to use the compaq presariov2000. and install cent05....
ok, Firefox being an application, I am somewhat confused about what you are trying to do. If your computer is connecting to the network on wireless then you shouldn't have to do anything to get Firefox to work. If your Computer is not connecting to wireless through the card it is most likely because you don't have the correct drivers for the operating system you installed. Since the computer came with Windows on it you will need to search the web for the proper drivers for your system and device.
Oct 07, 2009 | HP Compaq Presario V2000 Notebook
Wireless adapter not functioning-
Do the following :
  1. Turn Laptop off, then disconnect adapter and remove battery. Re assemble and restart.
  2. Try clicking the button activating the wireless card.
  3. Reinstall wireless card drivers, select drivers from Compaq Presario V6205NR Notebook PC
  4. If all that did not work, then the internal adapter is faulty. Buy an external wlan adapter:WLAN Adapter WL-167G-£12.90 new
Sep 26, 2009 | Compaq Presario Notebook
Compaq Presaro V2000 will not power on after mini-pci card removed
HELLO,PRESS AND HOLD THE POWER ON BUTTON FOR A FEW SECONDS UNTIL YOU GET A POWER LIGHT.ONCE YOU GET THE LIGHT,THE LAPTOP SHOULD BOOT UP NORMALLY.IF THAT DOESNT WORK,REMOVE THE BATTERY AND TRY TO POWER UP WITH JUST THE AC ADAPTER PLUGGED IN.ONCE YOU GET BOOTED,INSTALL THE BROADCOM WIRELESS CARD SOFTWARE FIRST FROM THE CD THAT CAME WITH THE ADAPTER.THE SET-UP WILL THEN ASK YOU TO INSTALL THE CARD AFTER THE DRIVERS HAVE BEEN LOADED.YOU SHOULD BE ABLE TO GET ONLINE ONCE ALL THE STEPS HAVE BEEN COMPLETED.GOOD LUCK
Aug 17, 2008 | HP Compaq Presario V2000 Notebook
Wireless card and sound won't work
did you download the driver files from compaq's website www.compaq.com
Jun 18, 2008 | HP Compaq Presario V2000 Notebook
Modem and media card not recognized on HP Presario V2000, AMD, XP Prof, Vers. 2002 SP2
alll the drivers can be downlaoded from the compaqs site . u need to enter the seril number of machine . if that devices are shown in device manger with an yellow qn mark .then that devices will work if proper drivers are laoded . give me ur computer serial no . i will send the link to that files
Jan 29, 2008 | HP Compaq Presario V2000 Notebook
Using Skype - Intneral mic no longer works
Its due to your internal laptop MIC's failure! Plz check at any Compaq Service station! Becoz its internal hardware error! Becoz there r no seperate drivers for MIC! If your speakers are working great then MIC should work or else try to get repaired it!
Dec 02, 2007 | HP Compaq Presario V2000 Notebook
HP Compaq Presario V2000 Notebook Logo
133 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
