Question about Bosch Nexxt Premium WFMC6400UC Front Load Washer
Door is locked
I ran my washer on a quick wash yesterday, when I heard it beeping I assumed it had finished. On the display the letter "E" was flashing. the start/pause button are flashing also. I turned the washer to the off position and turned it back to another programme, the same display showed"E" and I can't get the door open. I have laundry stuck in the washer. I called for service but it's an outrageous price, I want to try and trouleshoot myself before I have to pay out $200.00 - and that's without parts.
Thanks
Vanessa
  • mberney11 Oct 17, 2008
    The door to the washer remains locked and the display reads E:04
  • suzanbb9 Nov 16, 2008
    I have the same problem - running a load using HOT, added an item during the wash cycle, when I closed the door it started flashing E: and beeping - can't open the door and can't get it to do anything.
  • 487 Answers
Ok this can be a bit messy.
It can be that the water level is too high. Or temp level was too high. Empty the tub by removing the filter behind the service door.
Get a few towels handy because it is quite a bit of water.
Than try to power up again. This should now work.
Posted on Apr 17, 2008
My mass 6 Bosch washing machine is locked up and was blinking in red light letter F what do I do
"Sd" - (Excess suds)
F8 followed by E1 - (water supply error)
F9 followed by E1 - (drain pump system error)
F5 followed by E2 - (door will not lock)
F7 followed by E1 - (motor drive error)
"rL" - (remove load)
Washer making error beeps - Door has not been opened and closed for at least 3 cycles
Washer beeps when HOLD TO START is touched - Door not closed
F# E# code other than as described above appears in display - System Code Error
"nt" (interrupted) - Cycle was paused or cancelled
Clean Washer LED flashing at end of wash cycle - The washer has run 30 wash cycles and is indicating a reminder to run the Clean Washer cycle https://removeandreplace.com/2015/05/05/washing-machine-error-codes-front-and-top-load
Sep 21, 2017 | Bosch Washing Machines
Door remains locked after wash, no error code or anything.
if there is water left in the machine it will not open pull out the washer if under work top tilt the machine back wards the door should open thwn clean filter and try
Dec 02, 2012 | Washing Machines
When I try to use the washer I press the Express Wash Cycle as usual. The panel lights up as usual but when I press the start button it dosen't start. I don't hear the front load door lock as usual and...
'F' for fault, 'dL' for door lock and you don't hear it operating. It's pretty clear there is a problem either with the lock operating solenoid (highly likely 'cos you don't hear it operate) or the door lock sensor (not so likely).
Either you need to replace it or it needs replacing by a service engineer. Sorry, no other option ;-0(
Good luck,
John C
Mar 04, 2011 | Kenmore Elite 45986 Front Load Washer
Hi, I have a Zanussi Timeline 1400 front loader and after it has completed a wash, it will not do another wash for some time. If you select a program it will think about it and then say it is complete with...
Try this..
Reading Error Codes
1. Wake the washer by pressing any button. 2. Wait 5 seconds. 3. Press and hold the START/PAUSE and CANCEL buttons simultaneously. As long as the buttons are held, the failure code will appear in the display as an "E" followed by two numbers, a number and a letter or two letters. The control will beep and the Door Lock, Wash, Rinse, and Final Spin indicator lights will flash. let me know what code come up.
Jan 30, 2011 | Zanussi ZWF1450W Front Load Washer
My washing machine keeps giving me a error 20 code and dosent finish the cycle
E20 is a general error code to get to the real problem try this..
Reading Error Codes2.gif 1. Wake the washer by pressing any button. 2. Wait 5 seconds. 3. Press and hold the START/PAUSE and CANCEL buttons simultaneously. As long as the buttons are held, the failure code will appear in the display as an “E” followed by two numbers, a number and a letter or two letters. The control will beep and the Door Lock, Wash, Rinse, and Final Spin indicator lights will flash2.gif. let me know what code come up... hope it helps
Sep 14, 2009 | Frigidaire ATF6000ES Front Load Washer
Washer- lights go on, but it won't click/lock to start the load s
it is probably the door lock asm itself but lets try the diagnostic mode. Usually on the newer duets when the lock quits you get a quick series of beeps upon pressing start.
On the old style (red leds, no teardrop) set drain/spin cycle, no spin option press prewash 4 times quickly
new models (green leds, teardrop front) the old way may also work but will only start factory test, no code display. instead with unit off, select any one option key, press and hold 4 secs, release 4 secs and repeat till all lights come on (3 or 4 times) then it will flash any f codes, press that same key again to advance to the next code if any (most recent code first) then it will go to display software versions (n:xx etc)
when it shows C:00 the door should lock at C:01 it will fill with cold water this is the factory test routine it will advance automatically. some steps may take a while but should complete them all and turn off. we are of course interested in if it locks here and advances. a F code may still get displayed.
May 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine finished its last wash and is no longer working ?
All HAIER Washing Machines come with a 3 year parts and labour warranty - Ring them and get them to come and repair..
Apr 10, 2009 | Haier Washing Machines
Whirlpool duet 9400 Washer won't do anything?
Hi.
Please read the Fixya article below explaining how to fix the problems related to control lock on Whirlpool dryers and washers.
The front light lit on my Whirlpool.
Regards.
Dec 27, 2008 | Whirlpool GHW9400 Front Load Washer
Washer will not spin or completely drain
you could have problem with door lock. or lid switch. this part senses if the door is close.
if it is not functioning, it would interpret it as an open door and will not spin.will not drain either.
tnx 4 using fixya,
drcool
Sep 23, 2008 | Washing Machines
Help me!!!!!!!!!!!!!
Ok the washer is telling you we have a problem. I will tell you how to retrieve the code and then ill tell you what that code means
2. Wait 5 seconds.
3. Press and HOLD the Start/Pause and Cancel
E followed by two numbers, a number and a letter or
two letters. The controlwill beep and the Door Lock,
Wash, Rinse,
flash.
Nov 16, 2007 | Frigidaire Affinity ATF7000E Front Load...
Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
207 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
