I we have just bought a Philips DVP3120, we were given a phone number to call to make it a multi zone player. The number doesn't work. Any suggestions on how to go about to make this dvd player work!
    Guru:
  • 1,463 Answers
Hi bjamin24
have a look here dvd search
riz.
Posted on Apr 16, 2008
Need to get my philips dvd player 3120 onto muliti
Using the remote controller:
Press [SETUP]
Select Preference page
Press [1] [3] [8] [9] [3] [1]
Select region code using [UP] / [DOWN] buttons.
Apr 25, 2009 | Philips Televison & Video
Open DVD player to all DVD zones
Here's a few things you can try. Please remember to switch your player off and back on again after each thingy you try^^ It saves it on some memory thingy^^
1) Go to Setup page
2) Preference page
3) Press 138931
4) Press up/down key to select region code
or
# Turn On unit
# Press the Setup button on the remote
# Navigate to the Preferences page using the Right arrow key
# Press the Down arrow once to enter the Preference page
# Enter 1, 3, 8, 9, 3 and 1 on the remote
# You will now see the current region code displayed
# Use the Up/Down arrow keys to select the region required or 0 for all regions
# Press the Play or OK button on the remote
if your zone is not saved to your dvd player. then do not switch the unit off and on again. throughout my experiences most require to do so, but since I don't work with a lot of Philips models I can only hope it helps^^
Good luck and let me know^^
Mar 31, 2009 | Philips DVP5140 DVD Player
How can i make Philips DVP3120 DVD Player multiregion?
Try this procedure
# Turn On unit
Cheers
Dec 05, 2008 | Philips DVP5990 DVD Player
ADVERTISE OF DVD NOT TO BE SEEN
The player is probably in the 'demo' mode; check your user guide for instructions for turning it off.
Oct 05, 2008 | Philips DVP5140 DVD Player
REMOTE CODE FOR PHILLIPS DVD DVP3140
I don't know if this will work for you since your Philips universal remote is a different model. I tried all the codes listed for a Philips DVD player in my Philips SRU3004/27 universal remote manual. Two of them partially worked (wouldn't let me scan forwards and backwards). The last one they listed did work, code 1214. I suggest trying all the codes in the handout that comes with the remote for Philips DVD players. Make sure each number you press registers (the indicator light on the remote will blink). Philps also lists these codes on their web site. Good luck!
May 26, 2008 | Philips DVP3140
Dvd player dvd3020
This is a known problem with the DVP3020.
I am assuming that your lens cleaner is for CD as well.
Although identical, CDs & DVDs store data completely differently, which means DVD players need two lasers to read both formats.
It sounds like the DVD laser has failed on your player, which is why it will still play your lens cleaner.
Unfortunately the cost of replacing the laser outweighs the value of the player.
The DVP3020 has been replaced by the DVP3120 which is far more reliable.
The DVP3120 with a multi-region modification can be bought for £17.99 from CheapestElectrical.
Click here for details:
http://www.cheapestelectrical.co.uk/catalogue.php?category=6&title=DVD+%26+Video
May 13, 2008 | Philips DVP3020 DVD Player
Can't play a cd-RW on dvd player dvp3120
The Philips dvp3120 in compatible with CD-RWs if the disk is recorded as a VCD (Video CD format). Chances are that you have not used this format. To learn more see http://dvr.about.com/od/capturetvwithacomputer/tp/dvdrec.htm
May 04, 2008 | Televison & Video
Philips DVP3120
You can follow the following instructions to make your philips dvp3120 player multi region!!!!!
1. Turn on the unit
2. Open the loading tray
3. Press the "Setup" button on the remote
4. Navigate to the "Preferences" page using the right arrow key
5. Enter 138931
6. You will now see the current region code displayed
7. Use the Up/Down arrow keys to select the region required or "0" for all regions
8. Press the "Play" button on the remote
Jan 27, 2008 | Televison & Video
DVP 3120
I have a problem with my DVP 3120. Nothings happended when I pressed the numbers and now it won't select the preferences page anymore. Maybe I have to reset it too (but I didn't have to typ in any region) but how do I do that?
I wonder if anyone had that same problem and how they solved it. Thanks in advance.
Renee
Jan 01, 2008 | Philips DVP5140 DVD Player
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
