Question about Frigidaire GLWS1233A Top Load Washer
FRIGIDAIRE WASHER , MY CLOTHES COME OUT STILL WET
THE WASHER STARTED MAKING A SCREACHING NOISE DURING THE SPIN CYCLE THAT GOT LOUDER AND THEN SMELLED LIKE BURNT RUBBER.... EVERYTHING ELSE WORKS . PLZ CAN YOU HELP ME.
  • jwaugaman Jun 30, 2008
    Our washer makes a terrible screeching sound during the spin cycle. The one front leg keeps coming off and it will not stay on. Water leaks from somewhere in the back of the washer (we cannot find out where it's coming from) and it "walks" as it washes.
  • James Davis May 11, 2010
    Did the water drain out?
I just finished taking mine apart.. the head of a bolt snapped of causing the spindle to drop ... when the basket spins it touches/scraps the bottom... I went to Rona and bought the same size bolt. It works fine now
Posted on May 29, 2008
Same thing happened to me. The belt just went and I think the bearing is going as well. ANyone know if there are any manuals on the breakdown of these machines?
Posted on Apr 20, 2008
My washer/dryer combo Frigidaire washer dosn't spin water out of clothes completely after spin cycles the clothes is still very wet. On the 1st spin cycle drum dosn't spin just makes noise,the 2nd and...
Good Afternoon Friend,
I understand your Frigidaire laundry center, model# FGX831CS, is not spinning water out of your clothes completely. I see that on the first spin cycle the drum is not spinning and is just making noise, and on the second spin cycle the drum spins to the left very slowly and loudly. First check to see if your washer is overloaded. Try taking some clothes out and spinning them again. Secondly, make sure that the load is not out of balance. Try rearranging the clothes to allow for proper spinning. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 19, 2014 | Frigidaire FGX831CS Top Load Stacked...
I have a eterna EWA5600G king size washer that is making a very loud sceaching sound
check the drive belt from the motor to the gearbox it might be louse that would make it screach and week agitating
Dec 01, 2011 | Washing Machines
I have a Frigidaire GLTF2070DS Front Load Washer and during the spin cycle, it started making this horrific noise. I started another load of laundry and now it does not spin. What could be the problem?
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
Sep 07, 2010 | Frigidaire GLTF2070DS Front Load Washer
Excess water in clothes after spin cycle
Unblock the outflow pipe from the machine that goes into the sump under the sink. (have a pot ready for water overflow) This will help drain the water. If the spin cycle is making a screetching sort of noise then it is possible that the carbon brushes will need changing. This affects the spinning if the brushes are worn.
Nov 05, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer making buzzing sound during spin cycle,then stopped during wash still has water in tge clothes,buttons light up as if going to work but nothing happens jusy buzzing noise
If I understand correctly, the washer made a sound in the spin cycle but didn't actually spin the clothes dry?
If so you may have something in the pump that is not allowing it to pump out. Disassemble the pump and make sure it is clear of any debris.
Jul 21, 2008 | Frigidaire Washing Machines
Front load Frigidaire Gallery washer
You are having a door switch problem change it out and you will have a new washing machine.
Dec 14, 2007 | Frigidaire GLTR1670A Front Load Washer
Noise during spin cycles
GE WPXH214ACC Washer drum makes loud noise when spinning sometimes. We've had it since 2005 & never had this happen before. Washer is level, must stop & redistribute clothes to correct. Just started happening now.
Oct 12, 2007 | Washing Machines
Frigidaire GLWS1233A Top Load Washer Logo
167 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
