Question about AT&T Lucent MLS-12D Phone
Need to program and extension on my phone.
How do I program an extension on my phone?
  • Anonymous Aug 05, 2008
    Where can I get a programing manual for my phone? I don't want to keep looking for the answers on line. We have several MLS-12D phone systems in our office
Uyjyyb .huyuyrjrdd.gtuyug/gguuyg.nh u
Posted on Jun 23, 2008
Nortel Norstar T7316 programming extention to button. Won't let me program extension 230.
Just think about it, why would you want to auto dial yourself? You don't need an autodial key for yourself so the system don't allow you to program it.
Sep 25, 2017 | NorStar Meridian M7310 Phone
PANASONIC KX-T7731 PHONE I HAVE MY EXTENSIONS PROGRAMMED BUT I NEED TO CHANGE THE NAMES FOR EACH EXTENSION AND I CANNOT FIGURE OUT HOW. THE PREVIOUS SECRETARY HAS BEEN GONE FOR 3 YEARS BUT HER NAME STILL...
I"d start by pressing the Caps Lock button on my keyboard to ask a question and use that key marked Shift to capitalize the first letter of a sentence and proper names.
Extension names are programmed in SYSTEM programming. Access to that is done from the phone connected to the first extension in your system, usually 101, with a system password. In a TA Series, it's program 604. In some others, it's program 004.
Carl
May 24, 2011 | Panasonic KX-T7731 Corded Phone
I have panasonic kx-t7730. How to set the intercom name and number?
Changing the name and extension number can be done through system admin programming from a phone extension allowed by the class of service assigned to that extension by the phone system installer. Typically the attendant phone is allowed this ability. From the programming phone press **1234(1234 is the default password) to access programming. Once in programming dial 003 for extension numbering then press . Enter the current extension number of the phone you want to change followed by the new extension number then press . Lift the handset to end programming. Access programming again by pressing **1234. Dial 004 for extension name programming then press . Enter the new extension number you programmed then enter the name for the extension. Press then lift handset to end programming.
It is possible that your phone has not been assigned an extension number, in that case system installer programming would need to be accessed to assign the port an extension number. The port number the phone is connected to would have to be determined. This could require tracking the wiring back to where it is connected into the phone system. If this is the case I advise calling a qualified service technician.
Dec 08, 2010 | Panasonic KX-T7730 Corded Phone
Can you program a 18D phone to bring back up an incoming call number? Does that have to be programmed per each phone or from extension 10 for all phones?
Yes :-)
It has to be programmed from extension 10 and from the phone. One sets the destination and the other sets the button. Technically, you can do everything from the main phone, but it's easier to do the system programming from the main and the extension programming from the extension, that way you can see the button you're assigning to the feature.
Check out the quick guide here. http://public.carl.airpost.net/Avaya/Partner%20ACS%20quick.pdf
Page 38 gives you the #31x commands to set up CID, and page 110 gives you the featrure codes you need to assign to the extenson buttons.
Carl
Jul 07, 2010 | Lucent PARTNER18 Corded Phone
I need to know how to page another extension. Our Avaya phones do not have the intercom button. I thought there should be a function code to program a button for Intercom, but I'm not finding it. I need to...
There are 2 buttons right below Line 1 and Line 2. Those are both intercoms.
When paging a phone, you just insert a * (star) before the extension number.
SO, Intercom*11, will page extension 11
To program on a button, feature 00, press the button you want to program, then press the left intercom and *xx (where xx is the extension number)
As far as paging all the phones, you will need to have them in a calling group (1-4), hten you can page the group to page them all.
Jan 19, 2010 | Avaya 700340193 Corded Phone
How do i add a new phone to an existing system? I have connected the phone & just need to assign an extension number for it so that the other phones can see the system, thank you
If you have installed it on a new extension, it already has a number. By default, on a TA-series system, the jack and extension are the same, so Jack 12 is extension 112. Quickest way is to plug the phone in and dial 0. The main phone rings and the display will give you the extension number.
To program the buttons, press PROGRAM the button and dial 1 plus the extension number. The lines should already be programmed by default, but they are 0 plus 01, 02, 03 etc. Press STORE after each button you program.
If you want to program ringing and line access differently than it already is, you need to look in the Programming Manual for the specific phone system. The Panasonic cabinet is going to be white with a silver tag or a model number stenciled or embossed on the case. Something like TA-824 or TA-624 would probably be your system model.
Carl
Dec 15, 2009 | Panasonic KX-T7730 Corded Phone
Program a new Nortel m7310 phone with an existing extension
If the extension was a swap of the old M7310 with a new(ish) M7310 no additional programming should be necessary. However if the phone was replaced with another type of nortel set(M7208, M7324,T7313 etc.) then the phone will default to its base features. To re-program the feature keys press feature *3, the button you wish to program, and the feature code for that button
Sep 28, 2009 | NorStar M7310 Corded Phone
CHANGING PROGRAM OF EXTENSION
The only way to change what extension a phone is, is to move the plugs that go into the phone system around. Someone needs to move the plugs, you can not program this remotely, so you will need a tech on site.
Apr 15, 2009 | Avaya Corded Phone avaparp18d
Problems with Intercom
Yes, you just need to program those buttons on your phone. Press "feature" then "redial" then press the button you want to program, then press "1" then it's extension # (example: 1-0-0 to program the button for extension 100) then press "feature". After you've programmed those extensions, the intercom should work.
Dec 20, 2007 | NEC Electra Elite DTU 16D-2 Corded Phone
AT&T Lucent MLS-12D Phone Logo
Top AT&T Lands Phones Experts
Paul C.
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
