Question about Xerox WorkCentre XD120F Laser Printer
HOW CAN I STOP THE COPIES FROM SHIFTING EVERYTIME?
EVERY TIME I MAKE A COPY THE IMAGE THAT I'M TRYING TO COPY SHIFTS COMPLETELY OVER FROM LEFT TO RIGHT. I'VE CALLED XEROX AND THEY STOP SERVICING THIS MODEL AND I LIKE TO KNOW HOW TO FIX THIS ISSUE. SOMEONE HELP
    President:
  • 2,072 Answers
Wide blank area on Lead Edge, or Misregistration possibly accompanied by noise. The noise may be described as a clicking, buzzing noise while making copies. The noise may stop for short periods while making copies. Cause:
The registration Sol. pawl is not capturing the clutch to keep it from turning. This is caused by the Registration Sol. return spring being out of position, or when installing the Main Drive Assy., the pawl is "trapped" in the actuated position.
Posted on Apr 17, 2008
  • Rick Kasper Apr 17, 2008
    Check the condition of the front and rear Paper Tray Snubbers. Repair as required.
    2-Check if paper is loaded properly in the Paper Tray.
    3-Clean the Paper Feed and the Registration Rollers and the Single Sheet Bypass Transport Rollers with Film Remover and a lint-free cloth. Check the components for wear or damage. Replace as required. (Feed Roller PL 5.1 item 20, Lower Registration Roller PL 5.1 item 7, Bypass Roller. The XD100 Family of Machines have several Models that use a Single sheet Bypass Transport Roller (PL 5.2 Item 12).
    4-Check the Registration Buckle adjustment 51-2.
    5-Sheet Skew or E2 on 2nd side copy being run in duplex. The Duplex Drive Roller has developed deposits on the drive surface. Clean the deposits off the rollers.(Tip 134402)
    6-Copy skewed on second side only. Uneven pressure on the door produced uneven pressure at the Registration Roller. Shim the lower frame for the lower latch .75 mm, using the shims from the Fuser Shim Kit 600K41560 and some super glue.(Tip 163880) This will tightened up the door.
Why does my 2003 S Type Jaguar shifts hard in lower gears?
You're probably shifting wrong. Or there's a problem with your gear ratio or clutch. are you grinding the gears or is it just shifting weird?
Sep 14, 2014 | 2003 Jaguar S-Type
Why is car abruptly jolting to a stop in reverse and not moving?
Sounds like the transmission is shifting into both reverse and a forward gear at the same time. Time for a tranny overhaul. But first check the transmission fluid level.
Jun 08, 2014 | 2004 Mazda 6
I was driving to work this morning and was in 3rd gear, went to down shift at a stop sign and its stuck in 3rd gear. 1988 jeep wrangler. It has been grinding the gear for a few weeks now everytime I change...
The 3rd Gear Synchro is worn or damaged, which is why it grinds when you try to upshift or downshift into 3rd gear. When it goes out completely you will have a very hard time shifting into 3rd gear, since the Synchro lines up the gears to make shifts smooth and easy.
Aug 24, 2011 | 1995 Jeep Wrangler
97 chevy tahoe 5.7 engine 2 wheel drive. im having problems in shifting into 3rd an 4th gears. some days itl shift in the morning an give some touble thur the day. while on other days it wont shift in the...
The torque converter clutch issue, won't effect the
shifting issues
I would stop using it,unless your prepared to
completely rebuild it, in a few weeks.
It has to be diagnosed and resolved, now,quickly.
Having once owned a trans shop, I don't like the
fact your driving it at all,hung shifts for 7 miles
will do it in
Mar 17, 2011 | 1997 Chevrolet Tahoe
How do I paste a photograph into a painting? Every time I copy and paste it only copies a blank image.
Try this. Load the photo into MS Paint and use the select tool to select the part of the image you want to copy. Once you've done that, open up Corel and paste it in there.
It may also be that the photo you are trying to import is not a JPEG, so Corel might not be recognizing it.
Jan 06, 2011 | Corel Painter Essentials 4 for PC, Mac...
Trans shifts very hard after 5 minutes of stop and go traffic
A reason for hard shifting could be a problem with many things with various degrees of seriousness. It could be your ATF( automatic transmission fluid) is low or broken down and old. This would cause the hardness and the reason for stop and go traffic effecting it. Another possibility is your transmission is just shot, and the timing gears inside are worn and not properly shifting at the correct RPM causing a **** during shifting.
Some possibilties, not all!
~Lucas
Mar 27, 2009 | 2003 Buick LeSabre
Printing crooked from one drawer, and no option to print from another drawer
Try this spray on a little WD40 on the GLASS and wipe it off.
Yes, you heard me correctly, make sure you wipe it off leaving no residue, but it's still slippery.
the problem may be coming from the glass being too dry and the paper is getting stuckand shifting.
If the paper itself was going crooked it would get jammed or ripped. There is no room for the paper to go through the path crooked so the only way for it to copy crooked is somewhere in the optics.
try doing 1-2 on the glass itself and see if it copies crooked.
The envelope tray is a By-pass tray and can be used for any size paper.You can switch which tray it copies from on the panel tray button.
Aug 28, 2008 | Canon imageRUNNER 2200
No Copies
It could possibly be your main charge assembly. If there is no charge on your drum, it can lead to blank copies.
May 20, 2008 | Sharp AL-1641CS All-In-One Laser Printer
Image/screen shifting with mouse position
I realized my issue was that the screen was "slightly" zoomed in using the universal access panel in the system preferences. Turning it off, or zooming out completely solved the problem.
Feb 21, 2008 | Apple Cinema Display 23" HD Monitor
Xerox WorkCentre XD120F Laser Printer Logo
85 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
